Home » Modeling » TMF (Xtext) » specify STRING in my DSL, so I can use templates inside the string(use plain eclipse templates inside my DSL comment string)
specify STRING in my DSL, so I can use templates inside the string [message #1705437] Sat, 15 August 2015 07:47 Go to next message
in my DSL, I have defined some comment as STRING:
AComment: {AComment}
'comment=' commentText=STRING?
For convenience, I want to provide some templates in the DSL preference page which holds text blocks to be used inside the comment string
Problem:
I have not found a way to specify the context of the template so it will show up if I press CTRL-space inside the string.
Question:
Is there a trick to do the job with some clever grammar or so?
Why:
in xtend, when I call CTRL+space inside the ''' ''' string, it will insert the «»
Re: specify STRING in my DSL, so I can use templates inside the string [message #1729300 is a reply to message #1705437] Tue, 12 April 2016 13:32 Go to previous messageGo to next message
Did you find how to implement this functionality?
Re: specify STRING in my DSL, so I can use templates inside the string [message #1729338 is a reply to message #1729300] Wed, 13 April 2016 04:28 Go to previous messageGo to next message
unfortunately, noone gave me a hint
Re: specify STRING in my DSL, so I can use templates inside the string [message #1729412 is a reply to message #1729338] Wed, 13 April 2016 19:51 Go to previous messageGo to next message
Well, it seems templates is not the way to go; you can see here the Xtend default templates.
Re: specify STRING in my DSL, so I can use templates inside the string [message #1729420 is a reply to message #1729412] Thu, 14 April 2016 01:09 Go to previous message
xtend actually parses Strings. ntl you can xtend the behaviour how contexts are created. here is a wild guess (not really tested)
public class MyDslTemplateProposalProvider extends DefaultTemplateProposalProvider {
	private ContextTypeIdHelper helper;
	@Inject
	public MyDslTemplateProposalProvider(TemplateStore templateStore, ContextTypeRegistry registry,
			ContextTypeIdHelper helper) {
		super(templateStore, registry, helper);
		this.helper = helper;
	protected void createTemplates(TemplateContext templateContext, ContentAssistContext context,
			ITemplateAcceptor acceptor) {
		System.out.println("context: " + context);
		super.createTemplates(templateContext, context, acceptor);
	protected TemplateContext[] createTemplateContexts(ContentAssistContext context) {
		return super.createTemplateContexts(context);
	protected IFollowElementAcceptor createFollowElementAcceptor(Collection<TemplateContextType> result) {
		return new FollowElementAcceptor(result) {
			public Boolean caseTerminalRule(TerminalRule object) {
				addContextType(helper.getId(object));
				return super.caseTerminalRule(object);
public class MyDslXtextTemplateContextTypeRegistry extends XtextTemplateContextTypeRegistry {
	@Inject
	public MyDslXtextTemplateContextTypeRegistry(IGrammarAccess grammarAccess, Provider<XtextTemplateContextType> ctxTypeProvider, ContextTypeIdHelper helper) {
		super(grammarAccess, ctxTypeProvider, helper);
	protected void registerContextTypes(IGrammarAccess grammarAccess,
			Provider<XtextTemplateContextType> ctxTypeProvider) {
		List<TerminalRule> terminalRules = GrammarUtil.allTerminalRules(grammarAccess.getGrammar());
		for (TerminalRule terminalRule : terminalRules) {
			String value = getHelper().getId(terminalRule);
			if (value!=null) {
				XtextTemplateContextType type = ctxTypeProvider.get();
				type.setName("Terminal '"+terminalRule.getName()+"'");
				type.setId(value);
				addContextType(type);
		super.registerContextTypes(grammarAccess, ctxTypeProvider);
public class MyDslContextTypeIdHelper extends ContextTypeIdHelper{
	@Inject
	private MyDslGrammarAccess ga;
	public String getId(AbstractRule rule) {
		if (rule instanceof TerminalRule) {
			String id = ga.getGrammar().getName()+"."+rule.getName();
			return id;
		return super.getId(rule);
@FinalFieldsConstructor
class MyDslUiModule extends AbstractMyDslUiModule {
	override bindITemplateProposalProvider() {
	def Class<? extends ContextTypeIdHelper> bindContextTypeIdHelper() {
		return MyDslContextTypeIdHelper
	override bindContextTypeRegistry() {
Previous Topic:Xtext Intellij integration
Next Topic:Default Scope Shadowing
Current Time: Sun Jul 27 16:24:03 EDT 2025
Powered by FUDForum. Page generated in 0.03071 seconds
