Home » Eclipse Projects » e(fx)clipse » Bundle org.eclipse.fx.osgi not found :-((Encountering some errors when creating first Eclipse RCP JavaFX based App )
Bundle org.eclipse.fx.osgi not found :-( [message #1729259] |
Tue, 12 April 2016 09:01  |
Hi Everyone,
Apologies in advance if this is a rookie mistake but i have encountered some a problem writing my first eclipse rcp application using JavaFX.
By following several tutorials i got a got a basic application, with a few buttons in a main window, working no problem.
I then wanted to play around with using JavaFX themes and so followed this tutorial
efxclipse-1-2-0-themes-are-osgi-services (can't link due to no messages ) .
Unfortunately it didn't work and I now get the following messages in my console:
!ENTRY org.eclipse.osgi 4 0 2016-04-12 13:26:28.966
!MESSAGE Bundle org.eclipse.fx.osgi not found.
!ENTRY org.eclipse.equinox.ds 1 0 2016-04-12 13:26:29.514
!MESSAGE Could not bind a reference of component org.eclipse.fx.core.internal.JUtilLoggerFactory. The reference is: Reference[name = registerHandler, interface = java.util.logging.Handler, policy = dynamic, policy-option = greedy, cardinality = 0..n, target = null, bind = registerHandler, unbind = unregisterHandler, updated = null]
!ENTRY org.eclipse.equinox.ds 1 0 2016-04-12 13:26:29.900
!MESSAGE Could not bind a reference of component org.eclipse.fx.ui.theme.internal.DefaultThemeManager. The reference is: Reference[name = registerTheme, interface = org.eclipse.fx.ui.services.theme.Theme, policy = static, policy-option = greedy, cardinality = 0..n, target = null, bind = registerTheme, unbind = unregisterTheme, updated = null]
Apr 12, 2016 1:26:30 PM org.eclipse.fx.ui.workbench.fx.PartRenderingEngine <init>
INFO: No current theme is set
Some googling suggested possible solutions. One was to unsure -Dosgi.framework.extensions=org.eclipse.fx.osgi was set in the product launch (it is). The other suggested i check that the org.eclipse.fx.osgi fragment was in the correct place for a local archive. But this doesn't seem relevant as my target platform uses the 2.3.0 update site.
Any help or suggestion would be appreciated!
Re: Bundle org.eclipse.fx.osgi not found :-( [message #1729313 is a reply to message #1729259] |
Tue, 12 April 2016 15:11   |
Well somehow you don't contribute a theme hence? Did you generated the
application using the tooling? Is there a Theme-Instance and is it
contributed to as a DS-Service?
Tom
On 12.04.16 19:17, Bob Bobson wrote:
> Hi Everyone,
> this tutorial
> console:
> 2.3.0 update site.
Current Time: Fri Jul 25 23:54:20 EDT 2025
Powered by FUDForum. Page generated in 0.04625 seconds
