Home » Eclipse Projects » e(fx)clipse » TreeItem problem in JavaxFX with EMF Edit (Different behavior when creating an TreeItem object insteand of creating one as parameter.)
icon5.gif  TreeItem problem in JavaxFX with EMF Edit [message #1729143] Mon, 11 April 2016 09:55 Go to next message
Hallo together,
i set up an project, in which in want to use an EMF Model for an JavaFX Application.
Sadly i got stuck at different points in that project.
The first one is very confusing me and i hope you can help.
Following Code is working:
        ComposedAdapterFactory adapterFactory;
    	adapterFactory = new ComposedAdapterFactory(ComposedAdapterFactory.Descriptor.Registry.INSTANCE);
    	adapterFactory.addAdapterFactory(new ResourceItemProviderAdapterFactory());
    	adapterFactory.addAdapterFactory(new FinanceAppItemProviderAdapterFactory());
	adapterFactory.addAdapterFactory(new ReflectiveItemProviderAdapterFactory());
    	EditingDomain editingDomain;
    	BasicCommandStack commandStack = new BasicCommandStack();
    	editingDomain = new AdapterFactoryEditingDomain(adapterFactory, commandStack);
    	TreeView<Object> treeView = new TreeView<>();
    	treeView.setRoot(new AdapterFactoryTreeItem(modelData.get(0), adapterFactory));
    	treeView.getRoot().setExpanded(true);
    	AdapterFactoryTreeCellFactory cellFact;
    	cellFact = new AdapterFactoryTreeCellFactory(adapterFactory);
    	treeView.setCellFactory(cellFact);
And this try gives me an exception:
    	TreeItem<Object> rootItem = new AdapterFactoryTreeItem(modelData.get(0), adapterFactory);
    	System.out.println(rootItem.getValue().getClass());
    	treeView.setRoot(new AdapterFactoryTreeItem(rootItem, adapterFactory));
The difference in one box:
treeView.setRoot(new AdapterFactoryTreeItem(modelData.get(0), adapterFactory)); // is working
treeView.setRoot(new AdapterFactoryTreeItem(rootItem, adapterFactory));  // throws an exception
The exception is:
java.lang.IllegalArgumentException: Provided root object cannot be adapted.
If you need more information please let me know.
Thanks and regards
Fabian
Re: TreeItem problem in JavaxFX with EMF Edit [message #1729172 is a reply to message #1729143] Mon, 11 April 2016 14:44 Go to previous messageGo to next message
Not sure what you expect in the case not working you have wrapped your
root object into a TreeItem and pass that on but AdapterFactoryTreeItem
expects EObjects hence it fails.
Tom
On 11.04.16 16:51, Fabian Kopatschek wrote:
> Hallo together,
> Application.
> commandStack);
> adapterFactory));
> commandStack);
> adapterFactory));
> adapterFactory);
> The exception is:
> Thanks and regards
> Fabian
Re: TreeItem problem in JavaxFX with EMF Edit [message #1729174 is a reply to message #1729172] Mon, 11 April 2016 15:03 Go to previous messageGo to next message
Just found the mistake.
instead of:
it should be:
treeView.setRoot(rootItem);
Now is my problem, that only the rootItem is displayed. How can i get a tree with it's children?
The class of the rootItem has a list of objects from another class. Both classes has the abstract class ModelItem as SuperType.
Regards Fabian
Re: TreeItem problem in JavaxFX with EMF Edit [message #1729176 is a reply to message #1729174] Mon, 11 April 2016 15:10 Go to previous messageGo to next message
So has your "modelData.get(0)" containment children? Your setup looks
like the one I see in
http://git.eclipse.org/c/efxclipse/org.eclipse.efxclipse.git/tree/demos/org.eclipse.fx.demo.contacts.app/src/org/eclipse/fx/demo/contacts
so it should work.
Tom
> instead of:
> adapterFactory);
> it should be:
> adapterFactory);
> Regards Fabian
Re: TreeItem problem in JavaxFX with EMF Edit [message #1729178 is a reply to message #1729176] Mon, 11 April 2016 15:44 Go to previous messageGo to next message
Thanks Tom,
the containment was the key. I missed that part.
I have one other question. The tree only appears in the scene if i add it via code to the layout.
If i try to map it with the SceneBuilder via fx:id in the menu "Code". The tree does not appear.
Fabian
Re: TreeItem problem in JavaxFX with EMF Edit [message #1729179 is a reply to message #1729178] Mon, 11 April 2016 15:49 Go to previous message
Okay,
i found my mistake. I did create a new TreeView object instead of using the connected object.
Now i can go on with my learning.
Thanks for the help.
Fabian
Previous Topic:Error rendering menu
Next Topic:Restart Service not starting application after build
Current Time: Fri Jul 25 22:44:05 EDT 2025
Powered by FUDForum. Page generated in 0.04389 seconds
