Home » Modeling » EMF » [XCore] The Body of the method
[XCore] The Body of the method [message #1728880] Fri, 08 April 2016 04:42 Go to next message
As we know, the methods are defined with op keyword in xcore file. I want to save the body of the method in ecore file. How can I develop it?
Is it possible to save the body of the method in an annotation with key="body" and value="the body of the defined method".
Re: [XCore] The Body of the method [message #1728891 is a reply to message #1728880] Fri, 08 April 2016 05:46 Go to previous messageGo to next message
Parisa,
That's exactly what happens under the covers before we invoke EMF's
generator.
From the context menu of the *.xcore file you can do File -> New ->
Other -> Eclipse Modeling Framework -> EMF Generator Model to create a
*.ecore/*.genmodel from your *.xcore resource. In the *.ecore you
should see the body annotations on the EOperations.
On 08.04.2016 10:42, Parisa Moosavi wrote:
> it?
Re: [XCore] The Body of the method [message #1728977 is a reply to message #1728891] Fri, 08 April 2016 15:52 Go to previous messageGo to next message
I though the same as you but you can see in the files which are attached that the body of the defined operation in the xcore file is not saved in the ecore file.
below is an example of xcore file
@Ecore(nsURI="http://www.eclipse.org/emf/2002/EcoreI")
package ecoreI
class Phonebook{
	contains Person[1..*] AllPersons
	@GenModel(documentaion="test a documentaion")
	op void getCurrentPosition() {
		var str = 'final text example'
	op double getLongitude() {
		return 1
	op double getLatitude() {
		return 1
	op void getPersonNearToMe() {
class Person{
	String Surname
	String Forename
	String MobileNumber
	String OfficeNumber
	contains Address[] address
	op Address getAddress0() {
		return null
	op Person getPersonWithAddress(Address address) {
class Address{
	String City
	String Street
	String ZIP
	String Number
and that is the generated ecore file from xcore.
<ecore:EPackage xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="ecoreI" nsURI="http://www.eclipse.org/emf/2002/EcoreI" nsPrefix="ecoreI">
  <eClassifiers xsi:type="ecore:EClass" name="Phonebook">
    <eOperations name="getCurrentPosition" unique="false">
      <eAnnotations source="http://www.eclipse.org/emf/2002/GenModel">
        <details key="documentaion" value="test a documentaion"/>
        <details key="body" value=""/>
      </eAnnotations>
    </eOperations>
    <eOperations name="getLongitude" unique="false" eType="ecore:EDataType ../../org.eclipse.emf.ecore/model/Ecore.ecore#//EDouble">
      </eAnnotations>
    </eOperations>
    <eOperations name="getLatitude" unique="false" eType="ecore:EDataType ../../org.eclipse.emf.ecore/model/Ecore.ecore#//EDouble">
      </eAnnotations>
    </eOperations>
    <eOperations name="getPersonNearToMe" unique="false">
      </eAnnotations>
    </eOperations>
    <eStructuralFeatures xsi:type="ecore:EReference" name="AllPersons" lowerBound="1"
        upperBound="-1" eType="#//Person" containment="true" resolveProxies="false"/>
  </eClassifiers>
  <eClassifiers xsi:type="ecore:EClass" name="Person">
    <eOperations name="getAddress0" unique="false" eType="#//Address">
      </eAnnotations>
    </eOperations>
    <eOperations name="getPersonWithAddress" unique="false" eType="#//Person">
      </eAnnotations>
      <eParameters name="address" unique="false" eType="#//Address"/>
    </eOperations>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="Surname" unique="false"
        eType="ecore:EDataType ../../org.eclipse.emf.ecore/model/Ecore.ecore#//EString"/>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="Forename" unique="false"
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="MobileNumber" unique="false"
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="OfficeNumber" unique="false"
    <eStructuralFeatures xsi:type="ecore:EReference" name="address" upperBound="-1"
        eType="#//Address" containment="true" resolveProxies="false"/>
  </eClassifiers>
  <eClassifiers xsi:type="ecore:EClass" name="Address">
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="City" unique="false" eType="ecore:EDataType ../../org.eclipse.emf.ecore/model/Ecore.ecore#//EString"/>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="Street" unique="false"
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="ZIP" unique="false" eType="ecore:EDataType ../../org.eclipse.emf.ecore/model/Ecore.ecore#//EString"/>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="Number" unique="false"
  </eClassifiers>
</ecore:EPackage>
Re: [XCore] The Body of the method [message #1728980 is a reply to message #1728977] Fri, 08 April 2016 16:43 Go to previous messageGo to next message
Parisa,
For me it looks like this:
<details key="body" value="&lt;%java.lang.String%> str =
&quot;final text example&quot;;"/>
</eAnnotations>
</eOperations>
.../../org.eclipse.emf.ecore/model/Ecore.ecore#//EDouble">
<details key="body" value="return 1;"/>
</eAnnotations>
</eOperations>
</eAnnotations>
</eOperations>
</eAnnotations>
</eOperations>
lowerBound="1"
</eClassifiers>
<details key="body" value="return null;"/>
</eAnnotations>
</eOperations>
eType="#//Person">
</eAnnotations>
</eOperations>
unique="false"
.../../org.eclipse.emf.ecore/model/Ecore.ecore#//EString"/>
unique="false"
upperBound="-1"
</eClassifiers>
unique="false"
unique="false"
</eClassifiers>
</ecore:EPackage>
You've really created a new *.genmodel from the *.xcore model? What
version of EMF/Xcore do you have?
On 08.04.2016 21:52, Parisa Moosavi wrote:
> package ecoreI
> class Phonebook{
> return 1
> return 1
> class Person{
> String Surname
> String Forename
> String MobileNumber
> String OfficeNumber
> return null
> class Address{
> String City
> String Street
> String ZIP
> String Number
> </eAnnotations>
> </eOperations>
> </eAnnotations>
> </eOperations>
> </eAnnotations>
> </eOperations>
> </eAnnotations>
> </eOperations>
> lowerBound="1"
> </eClassifiers>
> </eAnnotations>
> </eOperations>
> eType="#//Person">
> </eAnnotations>
> </eOperations>
> unique="false"
> unique="false"
> upperBound="-1"
> </eClassifiers>
> unique="false"
> unique="false"
> </eClassifiers>
> </ecore:EPackage>
Re: [XCore] The Body of the method [message #1728983 is a reply to message #1728980] Fri, 08 April 2016 17:22 Go to previous messageGo to next message
EMF - Eclipse Modeling Framework Xcore SDK 1.1.1.v20130903-0948
Re: [XCore] The Body of the method [message #1728984 is a reply to message #1728983] Fri, 08 April 2016 17:50 Go to previous messageGo to next message
I have tried to update it but when I want to update the xtext will be updated and I must use xtext 2.5. Sad
do you have any idea to update xcore but not xtext.
Re: [XCore] The Body of the method [message #1728994 is a reply to message #1728984] Sat, 09 April 2016 00:52 Go to previous messageGo to next message
Parisa,
So you're using a very old version. Xcore uses Xtext of course, so the
latest release requires the latest release of Xtext. So I guess you're
kind of suck...
> updated and I must use xtext 2.5. :(
Re: [XCore] The Body of the method [message #1729623 is a reply to message #1728994] Sat, 16 April 2016 04:28 Go to previous messageGo to next message
I have updated the Xcore and Xtext has been updated but it doesn't work any more. I see this errors:
1    [Worker-1] ERROR org.eclipse.xtext.service.CompoundModule  - java.lang.reflect.InvocationTargetException
java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
	at org.eclipse.xtext.service.MethodBasedModule.invokeMethod(MethodBasedModule.java:138)
	at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:50)
	at org.eclipse.xtext.service.CompoundModule.configure(CompoundModule.java:35)
	at org.eclipse.xtext.service.AbstractGenericModule.configure(AbstractGenericModule.java:33)
	at org.eclipse.xtext.service.DefaultRuntimeModule.configure(DefaultRuntimeModule.java:76)
	at org.eclipse.emf.ecore.xcore.AbstractXcoreRuntimeModule.configure(AbstractXcoreRuntimeModule.java:25)
	at com.google.inject.spi.Elements$RecordingBinder.install(Elements.java:223)
	at com.google.inject.spi.Elements.getElements(Elements.java:101)
	at com.google.inject.spi.Elements.getElements(Elements.java:92)
	at com.google.inject.util.Modules$RealOverriddenModuleBuilder$1.configure(Modules.java:152)
	at com.google.inject.AbstractModule.configure(AbstractModule.java:59)
	at com.google.inject.internal.InjectorShell$Builder.build(InjectorShell.java:133)
	at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:103)
	at com.google.inject.Guice.createInjector(Guice.java:95)
	at com.google.inject.Guice.createInjector(Guice.java:72)
	at com.google.inject.Guice.createInjector(Guice.java:62)
	at org.eclipse.emf.ecore.xcore.ui.internal.XcoreActivator.createInjector(XcoreActivator.java:67)
	at org.eclipse.emf.ecore.xcore.ui.internal.XcoreActivator.getInjector(XcoreActivator.java:55)
	at org.eclipse.emf.ecore.xcore.ui.XcoreExecutableExtensionFactory.getInjector(XcoreExecutableExtensionFactory.java:26)
	at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:51)
	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:262)
	at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
	at org.eclipse.xtext.internal.ResourceServiceProviderDescriptor.getExtension(ResourceServiceProviderDescriptor.java:46)
	at org.eclipse.xtext.internal.AbstractResourceServiceProviderDescriptor.get(AbstractResourceServiceProviderDescriptor.java:20)
	at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl$InternalData.getServiceProvider(ResourceServiceProviderRegistryImpl.java:46)
	at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl.getResourceServiceProvider(ResourceServiceProviderRegistryImpl.java:109)
	at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl.getResourceServiceProvider(ResourceServiceProviderRegistryImpl.java:129)
	at org.eclipse.xtext.ui.resource.UriValidator.isValid(UriValidator.java:27)
	at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl$1.getURI(Storage2UriMapperJavaImpl.java:308)
	at org.eclipse.xtext.ui.resource.SourceAttachmentPackageFragmentRootWalker.handle(SourceAttachmentPackageFragmentRootWalker.java:279)
	at org.eclipse.xtext.ui.resource.PackageFragmentRootWalker.traverse(PackageFragmentRootWalker.java:107)
	at org.eclipse.xtext.ui.resource.PackageFragmentRootWalker.traverse(PackageFragmentRootWalker.java:95)
	at org.eclipse.xtext.ui.resource.PackageFragmentRootWalker.traverse(PackageFragmentRootWalker.java:65)
	at org.eclipse.xtext.ui.resource.SourceAttachmentPackageFragmentRootWalker.traverse(SourceAttachmentPackageFragmentRootWalker.java:168)
	at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.initializeData(Storage2UriMapperJavaImpl.java:321)
	at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.getCachedData(Storage2UriMapperJavaImpl.java:241)
	at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.updateCache(Storage2UriMapperJavaImpl.java:457)
	at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.access$6(Storage2UriMapperJavaImpl.java:450)
	at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl$4.run(Storage2UriMapperJavaImpl.java:646)
	at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2345)
	at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.doInitializeCache(Storage2UriMapperJavaImpl.java:658)
	at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.initializeCache(Storage2UriMapperJavaImpl.java:566)
	at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.initializeCache(Storage2UriMapperJavaImpl.java:525)
	at org.eclipse.xtext.ui.resource.Storage2UriMapperImpl.initializeCache(Storage2UriMapperImpl.java:159)
	at org.eclipse.xtext.builder.builderState.AbstractBuilderState.load(AbstractBuilderState.java:62)
	at org.eclipse.xtext.builder.builderState.AbstractBuilderState.ensureLoaded(AbstractBuilderState.java:69)
	at org.eclipse.xtext.builder.builderState.AbstractBuilderState.isEmpty(AbstractBuilderState.java:217)
	at org.eclipse.xtext.ui.shared.internal.ListenerRegistrar.initialize(ListenerRegistrar.java:44)
	at org.eclipse.xtext.ui.shared.internal.EagerContributionInitializer.initialize(EagerContributionInitializer.java:31)
	at org.eclipse.xtext.ui.shared.internal.Activator.start(Activator.java:115)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
	at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
	at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:478)
	at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
	at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:109)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
	at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
	at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
	at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
	at org.eclipse.core.internal.events.BuildManager.instantiateBuilder(BuildManager.java:906)
	at org.eclipse.core.internal.events.BuildManager.initializeBuilder(BuildManager.java:859)
	at org.eclipse.core.internal.events.BuildManager.getBuilder(BuildManager.java:545)
	at org.eclipse.core.internal.events.BuildManager.getBuilder(BuildManager.java:574)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:244)
	at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:299)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:302)
	at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:358)
	at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:381)
	at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
	at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Caused by: java.lang.reflect.InvocationTargetException
	at org.eclipse.xtext.service.MethodBasedModule.invokeMethod(MethodBasedModule.java:136)
	... 93 more
Caused by: java.lang.NoClassDefFoundError: org/eclipse/xtext/xbase/annotations/validation/UnresolvedAnnotationTypeAwareMessageProducer
	at org.eclipse.emf.ecore.xcore.AbstractXcoreRuntimeModule.bindILinkingDiagnosticMessageProvider(AbstractXcoreRuntimeModule.java:284)
	... 98 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.xtext.xbase.annotations.validation.UnresolvedAnnotationTypeAwareMessageProducer cannot be found by org.eclipse.emf.ecore.xcore_1.2.2.v20150202-0452
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
	... 99 more
!ENTRY org.apache.log4j 4 0 2016-04-16 10:14:32.019
!MESSAGE org.eclipse.xtext.service.CompoundModule  - java.lang.reflect.InvocationTargetException
!STACK 0
	... 93 more
	... 98 more
	... 99 more
108  [Worker-1] ERROR org.eclipse.xtext.service.CompoundModule  - java.lang.reflect.InvocationTargetException
	... 93 more
Caused by: java.lang.NoClassDefFoundError: org/eclipse/xtext/xbase/file/FileLocationsImpl
	at org.eclipse.emf.ecore.xcore.AbstractXcoreRuntimeModule.bindFileLocations(AbstractXcoreRuntimeModule.java:264)
	... 98 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.xtext.xbase.file.FileLocationsImpl cannot be found by org.eclipse.emf.ecore.xcore_1.2.2.v20150202-0452
	... 99 more
!ENTRY org.apache.log4j 4 0 2016-04-16 10:14:32.179
!STACK 0
	... 93 more
	... 98 more
	... 99 more
214  [Worker-1] ERROR org.eclipse.xtext.service.CompoundModule  - java.lang.reflect.InvocationTargetException
	... 93 more
Caused by: java.lang.NoClassDefFoundError: org/eclipse/xtext/xbase/file/JavaIOFileSystemSupport
	at org.eclipse.emf.ecore.xcore.AbstractXcoreRuntimeModule.bindMutableFileSystemSupport(AbstractXcoreRuntimeModule.java:259)
	... 98 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.xtext.xbase.file.JavaIOFileSystemSupport cannot be found by org.eclipse.emf.ecore.xcore_1.2.2.v20150202-0452
	... 99 more
!ENTRY org.apache.log4j 4 0 2016-04-16 10:14:32.219
!STACK 0
	... 93 more
	... 98 more
	... 99 more
256  [Worker-1] ERROR org.eclipse.xtext.service.CompoundModule  - Type org.eclipse.xtext.xbase.file.WorkspaceConfig not present
java.lang.TypeNotPresentException: Type org.eclipse.xtext.xbase.file.WorkspaceConfig not present
	at sun.reflect.generics.factory.CoreReflectionFactory.makeNamedType(Unknown Source)
	at sun.reflect.generics.visitor.Reifier.visitClassTypeSignature(Unknown Source)
	at sun.reflect.generics.tree.ClassTypeSignature.accept(Unknown Source)
	at sun.reflect.generics.visitor.Reifier.reifyTypeArguments(Unknown Source)
	at sun.reflect.generics.reflectiveObjects.WildcardTypeImpl.getUpperBounds(Unknown Source)
	at org.eclipse.xtext.service.MethodBasedModule.getFirstTypeParameter(MethodBasedModule.java:108)
	at org.eclipse.xtext.service.MethodBasedModule.getKeyType(MethodBasedModule.java:99)
	at org.eclipse.xtext.service.ProviderModule.getKeyType(ProviderModule.java:39)
	at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:48)
Re: [XCore] The Body of the method [message #1729625 is a reply to message #1729623] Sat, 16 April 2016 05:07 Go to previous messageGo to next message
Parisa,
It looks like you have the recent versions of both, but the stack traces
make it clear there is some type of incompatibility. Did you install
these from http://download.eclipse.org/releases/mars?
I've added the TMF newsgroup to the reply, because they're more likely
to recognize what might be wrong...
On 16.04.2016 10:28, Parisa Moosavi wrote:
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> ... 93 more
> ... 98 more
> ... 99 more
> !STACK 0
> ... 93 more
> ... 98 more
> ... 99 more
> ... 93 more
> ... 98 more
> ... 99 more
> !STACK 0
> ... 93 more
> ... 98 more
> ... 99 more
> ... 93 more
> ... 98 more
> ... 99 more
> !STACK 0
Re: [XCore] The Body of the method [message #1732925 is a reply to message #1729625] Mon, 23 May 2016 03:01 Go to previous messageGo to next message
Hi Ed,
Because I couldn't find a solution for the error which occurred during the runtime and I should develop my project instead of installing the new version I want to save the body of method myself. Now I want to save the java equivalent body of the operation which I write in xcore Editor in ecore file which I generate automatically. How can I do it? or do you have a better idea or Suggestion?
I have attached an example of my xcore file.
Re: [XCore] The Body of the method [message #1732948 is a reply to message #1732925] Mon, 23 May 2016 05:48 Go to previous message
Parisa,
I'm not sure why you can't update your environment. I don't think
there is another way.
On 23.05.2016 09:01, Parisa Moosavi wrote:
> Hi Ed,
Previous Topic:[CDO] Merging and nested branches
Next Topic:Memory consumption of CompositeChangeDescription and large lists
Current Time: Mon Jul 21 13:50:57 EDT 2025
Powered by FUDForum. Page generated in 0.40233 seconds
