Home » Modeling » TMF (Xtext) » [SOLVED] How to get ride of the scrollbars in EmbeddedEditor
[SOLVED] How to get ride of the scrollbars in EmbeddedEditor [message #1728494] Mon, 04 April 2016 21:40 Go to next message
I am trying to view xtext embedded editor. However it shows the scrollbars which are really disturbing, e.g. when a single line is enough to show the text !
my code is as below:
EmbeddedEditorFactory factory = new EmbeddedEditorFactory();
		xtextInjector.injectMembers(factory);
		xTextEmbeddedEditor = factory.newEditor(new IEditedResourceProvider() {
			public XtextResource createResource() {
				return xtextResource;
		}).showErrorAndWarningAnnotations().withParent(xtextEditorComposite);
		xtextPartialEditor = xTextEmbeddedEditor.createPartialEditor(prefix,
				editablePart, suffix, true);
		xtextEditorComposite.update();
I found that in WithParent() method in the EmbeddedEditorFactory there is a code as below which forces scroll bars !
public EmbeddedEditor withParent(final Composite parent) {
			if (editorBuild)
				throw new IllegalStateException();
			editorBuild = true;
//			/*fProjectionSupport =*/installProjectionSupport(this.fSourceViewer);
			final CompositeRuler annotationRuler;
			if (annotationTypes != null && annotationTypes.length != 0) {
				annotationRuler = new CompositeRuler();
			} else {
				annotationRuler = null;
			final XtextSourceViewer viewer = this.sourceViewerFactory.createSourceViewer(
					parent,
					annotationRuler,
					null, // overviewRuler
					false, // showAnnotationOverview
					SWT.BORDER | SWT.V_SCROLL | SWT.H_SCROLL);
			final XtextSourceViewerConfiguration viewerConfiguration = this.sourceViewerConfigurationProvider.get();
			viewer.configure(viewerConfiguration);
Also, can you please guide me to some code examples for this slide :
http://fr.slideshare.net/meysholdt/lightweight-xtext-editorsasswtwidgets
Bests,
Parsa
[Updated on: Tue, 05 April 2016 16:58] by Moderator
Re: How to get ride of the scrollbars in EmbeddedEditor [message #1728600 is a reply to message #1728494] Tue, 05 April 2016 14:21 Go to previous messageGo to next message
Hi Parsa,
this is unfortunately not easy to extend.
You'll need to copy change and override the whole method and then bind your subclass to Builder.
Sven
Re: How to get ride of the scrollbars in EmbeddedEditor [message #1728611 is a reply to message #1728600] Tue, 05 April 2016 16:57 Go to previous message
Hi Sven,
Thank you for your reply,
I have copied the whole class body (EmbeddedEditorFactory and EmbeddedEditorActions classes) and it is working fine now.
Parsa
Previous Topic:DSL validation across multiple files
Next Topic:Embedded Editor Auto Completion does not work properly.
Current Time: Sat Jul 26 21:21:09 EDT 2025
Powered by FUDForum. Page generated in 0.05090 seconds
