Home » Eclipse Projects » Oomph » clone private git
clone private git [message #1728451] Mon, 04 April 2016 08:41 Go to next message
Hello everybody,
I (non-successfully) tried to clone a GitHub repo. This repo is private. When Oomph executes the clone task below it says that everything worked (no error message nor any other failure indication) but the repo isn't on my hard drive. Did I do something wrong in the task setup?
<setupTask
      xsi:type="git:GitCloneTask"
      id="git.clone"
      remoteURI="myUserName/myRepo.git">
    <annotation
        source="http://www.eclipse.org/oomph/setup/InducedChoices">
      <detail
          key="inherit">
        <value>github.remoteURIs</value>
      </detail>
      <detail
          key="label">
        <value>${scope.project.label} Github repository</value>
      </detail>
      <detail
          key="target">
        <value>remoteURI</value>
      </detail>
    </annotation>
    <description>${scope.project.label}</description>
  </setupTask>
This is what the eclipse wizard produces.
Thanks a lot for your responses
Re: clone private git [message #1728680 is a reply to message #1728451] Wed, 06 April 2016 08:03 Go to previous message
Steffen,
Comments below.
On 04.04.2016 14:41, Steffen Holzer wrote:
> Hello everybody,
We've done that successfully, so there's nothing so special involved...
How does it say that? You see the messages in the log that it's
actually cloning?
> <setupTask
> id="git.clone"
> <annotation
> <detail
> key="inherit">
> </detail>
> <detail
> key="label">
> </detail>
> <detail
> key="target">
> </detail>
> </annotation>
> </setupTask>
If you do Help -> Perform Setup Tasks... and enable Show all triggered
tasks is the clone task there? Is it enable? If you select it and look
at the properties, the Location property should show where it is on the
file system and if the task is disabled there should be a valid clone
located at this location...
Previous Topic:TargetDefinitionGenerator generates incomplete .target file
Next Topic:Targlet with Feature Patch
Current Time: Sun Jul 27 18:44:45 EDT 2025
Powered by FUDForum. Page generated in 0.03993 seconds
