Home » Newcomers » Newcomers » Eclipse hanging and freezing(Eclipse hangs and freezes on my desktop, but not my laptop)
Eclipse hanging and freezing [message #1728081] |
Wed, 30 March 2016 16:45  |
Following various YouTube videos I had thought I installed Eclipse 4.6.0 and Java on both my desktop and laptop, which both run Ubuntu 15.10 x64, the same way, but the experience is very different on one system compared to the other.
On my laptop Eclipse responds normally and I am able to create new projects, and access the preferences window fine, but on my desktop it freezes frequently (completely), or preferences or create project windows will not appear unless I move/minimize the main windows first.
The log file on my laptop is very short, and looks much like everything is working, but the log file on my desktop is much, much longer, and appears to contain errors. To try and stop Eclipse from freezing I manually removed it from /opt, and then deleted anything matching the string Java using the software centre, before using terminal to adding the webupd8team/java repo and installing oracle-java8-installer.
Could someone please perhaps make sense of what the issue may be from the log?
Forum will not allow me link to pastebin as I am new member:
!SESSION 2016-03-30 21:18:34.009 -----------------------------------------------
eclipse.buildId=4.6.0.I20151209-2300
java.version=1.8.0_77
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_IE
Framework arguments: -product org.eclipse.epp.package.cpp.product
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.cpp.product
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-30 21:18:34.424
!MESSAGE [SCR] Component definition XMLs not found in bundle org.eclipse.cdt.ui. The component header value is OSGI-INF/consoleservice.xml
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-30 21:18:38.275
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-30 21:18:38.359
!ENTRY org.eclipse.epp.logging.aeri.ui 2 36 2016-03-30 21:18:38.535
!MESSAGE End-point 'org.eclipse.epp.logging.aeri.ui.servers.ide' failed with exception: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. ; version: 1.100.0.v20151216-0616
!STACK 0
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192)
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1949)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:302)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:296)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1509)
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:216)
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:979)
at sun.security.ssl.Handshaker.process_record(Handshaker.java:914)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1062)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1375)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1403)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1387)
at org.apache.http.conn.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:290)
at org.apache.http.conn.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:259)
at org.apache.http.impl.conn.HttpClientConnectionOperator.connect(HttpClientConnectionOperator.java:125)
at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:319)
at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:363)
at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:219)
at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:195)
at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:86)
at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:108)
at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:184)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:57)
at org.apache.http.client.fluent.Executor.execute(Executor.java:206)
at org.eclipse.epp.internal.logging.aeri.ui.m0.IO.request(IO.java:202)
at org.eclipse.epp.internal.logging.aeri.ui.m0.IO.refreshConfiguration(IO.java:65)
at org.eclipse.epp.internal.logging.aeri.ui.m0.ServerConnection.startUp(ServerConnection.java:98)
at com.google.common.util.concurrent.AbstractIdleService$2$1.run(AbstractIdleService.java:54)
at com.google.common.util.concurrent.Callables$3.run(Callables.java:93)
at java.lang.Thread.run(Thread.java:745)
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:387)
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:292)
at sun.security.validator.Validator.validate(Validator.java:260)
at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:324)
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:229)
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:124)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1491)
... 26 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141)
at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126)
at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280)
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:382)
... 32 more
!ENTRY org.eclipse.equinox.event 4 0 2016-03-30 21:19:12.639
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/application/ApplicationElement/tags/REMOVE] {ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@7a3643e3 (elementId: stickyFolderRight, tags: [active], contributorURI: null) (widget: CTabFolder {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@6315bb4, toBeRendered: false, onTop: false, visible: true, containerData: 2500, accessibilityPhrase: null), Widget=CTabFolder {}, AttName=tags, EventType=REMOVE, Position=1, OldValue=Maximized} to handler org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler@7d95a717
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.IllegalStateException: Application does not have an active window
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:66)
at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler$1.run(UIEventObjectSupplier.java:56)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:234)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4646)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler.handleEvent(UIEventObjectSupplier.java:53)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:85)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(EcoreEList.java:249)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.remove(NotifyingListImpl.java:725)
at org.eclipse.emf.common.util.AbstractEList.remove(AbstractEList.java:462)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.subscribeTopicToBeRendered(PartRenderingEngine.java:166)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler.handleEvent(EventObjectSupplier.java:80)
at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setToBeRendered(UIElementImpl.java:303)
at org.eclipse.e4.ui.workbench.addons.cleanupaddon.CleanupAddon$2.run(CleanupAddon.java:317)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:183)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3807)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3446)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:818)
at org.eclipse.jface.window.Window.open(Window.java:794)
at org.eclipse.ui.internal.ide.ChooseWorkspaceDialog.prompt(ChooseWorkspaceDialog.java:89)
at org.eclipse.ui.internal.ide.actions.OpenWorkspaceAction.promptForWorkspace(OpenWorkspaceAction.java:264)
at org.eclipse.ui.internal.ide.actions.OpenWorkspaceAction.run(OpenWorkspaceAction.java:227)
at org.eclipse.ui.internal.ide.actions.OpenWorkspaceAction$OpenDialogAction.run(OpenWorkspaceAction.java:62)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:473)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:565)
at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:397)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4494)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1339)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1363)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1348)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1133)
at org.eclipse.jface.action.ActionContributionItem.lambda$8(ActionContributionItem.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3832)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3443)
at org.eclipse.ui.internal.dialogs.WorkbenchPreferenceDialog.open(WorkbenchPreferenceDialog.java:211)
at org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPreferencesAction.java:63)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1122)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1023)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:157)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:691)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:604)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:670)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:609)
at org.eclipse.equinox.launcher.Main.run(Main.java:1516)
at org.eclipse.equinox.launcher.Main.main(Main.java:1489)
Caused by: java.lang.IllegalStateException: Application does not have an active window
at org.eclipse.e4.ui.internal.workbench.ApplicationPartServiceImpl.getActiveWindowService(ApplicationPartServiceImpl.java:44)
at org.eclipse.e4.ui.internal.workbench.ApplicationPartServiceImpl.requestActivation(ApplicationPartServiceImpl.java:88)
at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.unzoom(MinMaxAddon.java:826)
at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.subscribeTopicTagsChanged(MinMaxAddon.java:372)
at sun.reflect.GeneratedMethodAccessor1.invoke(Unknown Source)
... 99 more
!SESSION 2016-03-30 21:19:18.366 -----------------------------------------------
Command-line arguments: -data /media/daire/HDD2/Documents/eclipse_workspace/linux -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.cpp.product
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-30 21:19:18.781
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-30 21:19:21.777
!ENTRY org.eclipse.epp.logging.aeri.ui 2 36 2016-03-30 21:19:23.176
!STACK 0
... 26 more
... 32 more
!ENTRY org.eclipse.ui 4 0 2016-03-30 21:20:59.895
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (org.eclipse.swt.SWTException: Widget is disposed)
at org.eclipse.swt.SWT.error(SWT.java:4522)
at org.eclipse.swt.SWT.error(SWT.java:4437)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:186)
at org.eclipse.ui.internal.actions.NewWizardShortcutAction.run(NewWizardShortcutAction.java:133)
Caused by: org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:4408)
at org.eclipse.swt.widgets.Widget.error(Widget.java:482)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:419)
at org.eclipse.swt.widgets.Tree.getSelection(Tree.java:1706)
at org.eclipse.jface.viewers.TreeViewer.getSelection(TreeViewer.java:228)
at org.eclipse.jface.viewers.TreeViewer.setSelection(TreeViewer.java:299)
at org.eclipse.jface.viewers.AbstractTreeViewer.setSelectionToWidget(AbstractTreeViewer.java:2533)
at org.eclipse.ui.navigator.CommonViewer.setSelectionToWidget(CommonViewer.java:437)
at org.eclipse.jface.viewers.AbstractTreeViewer.setSelectionToWidget(AbstractTreeViewer.java:2989)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1465)
at org.eclipse.jface.viewers.TreeViewer.preservingSelection(TreeViewer.java:354)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1419)
at org.eclipse.jface.viewers.StructuredViewer.refresh(StructuredViewer.java:1542)
at org.eclipse.jface.viewers.ColumnViewer.refresh(ColumnViewer.java:535)
at org.eclipse.ui.navigator.CommonViewer.refresh(CommonViewer.java:347)
at org.eclipse.ui.navigator.CommonViewer.refresh(CommonViewer.java:490)
at org.eclipse.jface.viewers.StructuredViewer.refresh(StructuredViewer.java:1478)
at org.eclipse.jface.viewers.StructuredViewer.setFilters(StructuredViewer.java:1635)
at org.eclipse.ui.internal.navigator.NavigatorFilterService.updateViewer(NavigatorFilterService.java:270)
at org.eclipse.ui.internal.navigator.resources.actions.WorkingSetActionProvider.setWorkingSetFilter(WorkingSetActionProvider.java:279)
at org.eclipse.ui.internal.navigator.resources.actions.WorkingSetActionProvider.setWorkingSetFilter(WorkingSetActionProvider.java:262)
at org.eclipse.ui.internal.navigator.resources.actions.WorkingSetActionProvider.setWorkingSet(WorkingSetActionProvider.java:309)
at org.eclipse.ui.internal.navigator.resources.actions.WorkingSetActionProvider.initWorkingSetFilter(WorkingSetActionProvider.java:257)
at org.eclipse.ui.internal.navigator.resources.actions.WorkingSetActionProvider$4.run(WorkingSetActionProvider.java:347)
... 35 more
!ENTRY org.eclipse.cdt.core 1 0 2016-03-30 21:21:43.974
!MESSAGE Indexed 'project1' (0 sources, 0 headers) in 0.001 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!SESSION 2016-03-30 21:22:18.893 -----------------------------------------------
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-30 21:22:19.303
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-30 21:22:19.304
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-30 21:22:22.256
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-30 21:22:22.257
!ENTRY org.eclipse.epp.logging.aeri.ui 2 36 2016-03-30 21:22:24.065
!STACK 0
... 26 more
... 32 more
[Updated on: Thu, 31 March 2016 03:58] by Moderator
Re: Eclipse hanging and freezing [message #1728111 is a reply to message #1728081] |
Thu, 31 March 2016 03:51   |
After researching the errors I edited my eclipse.ini to include the 4 lines beginning -vm:
-startup
plugins/org.eclipse.equinox.launcher_1.3.200.v20151021-1308.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.300.v20151013-1129
-product
--launcher.defaultAction
openFile
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256m
openFile
--launcher.appendVmargs
-vm
/usr/lib/jvm/java-8-oracle/bin/java
-Dosgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start
-Dosgi.framework.extensions=org.eclipse.fx.osgi
-vmargs
-Dosgi.requiredJavaVersion=1.8
-Xms256m
-Xmx1024m
Although this seems to have stopped some of the errors, I just deleted my workspace using Nautilus, opened Eclipse, and the tried opening the preferences window. The preferences window only appears if I close project explorer. I just tested creating a new project and it did complete in a few seconds, but it is now hanging trying to delete the same project. I tried closing the Eclipse window, even with the timer cursor going around, and right clicking it from the launcher to select quit, but there was no response until I think I accidentally moved the entire Eclipse window, and then the dialogue prompt appeared asking me if I was sure I wanted to remove proj1. It removes fine once the window was visible.
When I select the project menu and then exit nothing happens. Only if I grab the entire window from the title bar, or close the project explorer window, does the exit dialogue appear for a split second before eclipse crashing and closes itself.
If relevant my work space is on an NTFS Windows shared drive - although Eclipse for Ubuntu has its own workspace. Log:
!SESSION 2016-03-31 08:30:44.375 -----------------------------------------------
Framework arguments: -product org.eclipse.epp.package.cpp.product -Dosgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start -Dosgi.framework.extensions=org.eclipse.fx.osgi
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.cpp.product -Dosgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start -Dosgi.framework.extensions=org.eclipse.fx.osgi
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-31 08:30:44.814
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-31 08:30:44.815
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-31 08:30:47.839
!SESSION 2016-03-31 08:39:19.950 -----------------------------------------------
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-31 08:39:20.415
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-31 08:39:24.455
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-31 08:39:24.456
!ENTRY org.eclipse.cdt.core 1 0 2016-03-31 08:39:40.794
!MESSAGE Indexed 'proj1' (0 sources, 0 headers) in 0.002 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!SESSION 2016-03-31 08:42:56.037 -----------------------------------------------
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-31 08:42:56.475
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-31 08:42:59.623
!SESSION 2016-03-31 08:43:28.620 -----------------------------------------------
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-31 08:43:29.048
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-31 08:43:32.085
!SESSION 2016-03-31 08:45:16.606 -----------------------------------------------
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-31 08:45:17.028
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-31 08:45:20.130
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-31 08:45:20.131
!SESSION 2016-03-31 08:45:27.982 -----------------------------------------------
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-31 08:45:28.409
!ENTRY org.eclipse.cdt.ui 4 0 2016-03-31 08:45:31.555
Current Time: Sun Jul 27 04:09:57 EDT 2025
Powered by FUDForum. Page generated in 0.08913 seconds
