Home » Modeling » EMF » [CDO] Querying non persisted EObjects
[CDO] Querying non persisted EObjects [message #1727923] Tue, 29 March 2016 09:01 Go to next message
How is it possible to get non persisted EObjects (CDOState NEW) by CDOQuery?
If you add a new EObject to a resource per EMF Command:
Command addCommand = AddCommand.create(EditingDomain, Object, null, Owner);
EditingDomain.getCommandStack().execute(addCommand);
And execute a CDOQuery to get all instances of that type the new object is missing:
CDOQuery query = CDOTransaction().createQuery("ocl", "ObjectClass.allInstances()", owner);
List<EObject> resultList = query.getResult();
Re: [CDO] Querying non persisted EObjects [message #1727941 is a reply to message #1727923] Tue, 29 March 2016 11:11 Go to previous messageGo to next message
Hi Philipp,
See answers below :
> CDOQuery?
yes it is possible, and only for the OCL query handler. This is tested
by CDO tests, see OCLQueryTest.
We can look at specifically OCLQueryTest.testNewObject() in CDO base code.
> is missing:
Best Regards.
Esteban Dugueperoux - Obeo
Re: [CDO] Querying non persisted EObjects [message #1727985 is a reply to message #1727923] Wed, 30 March 2016 02:14 Go to previous message
Hi Esteban,
thanks for your answer, it's working now.
My first problem was, that the query param considerDirtyState was not set to true.
My second problem was, that I used a CompoundCommand including a setCommand first and an addCommand. I triggered the CDOQuery by listening changes on the object which was related by the setCommand and so the new object was not in the resource. As I changed the command order and triggered the addCommand first, everything was working fine.
Best Regards and thanks alot
Philipp Schweinbenz
Previous Topic:Bundle 'org.eclipse.emf.edit.ui' cannot be resolved
Next Topic:Why am I not seeing EMF types in a project with a Plug-in nature?
Current Time: Wed Nov 05 19:01:55 EST 2025
Powered by FUDForum. Page generated in 0.24158 seconds
