Home » Modeling » TMF (Xtext) » Can't get scoping to work
Can't get scoping to work [message #1727780] Sun, 27 March 2016 10:16 Go to next message
I want to achieve this:
int x ;
	x = 10; //right
	int a = 10;
	a = x; //right
a = 10; // wrong
int b = a; // wrong
This is my grammar:
grammar org.xtext.Cbb with org.eclipse.xtext.common.Terminals
generate cbb "http://www.xtext.org/Cbb"
Module:
	(statements+=Statement)*;
Statement:
	Variable |
	Block |
	IfStatement |
	WhileStatement |
	DoWhileStatement |
	ForStatement |
	SwitchStatement;
IfStatement:
	'if' '(' condition=Expression ')'
	thenBlock=Block
	('else' 'if' '(' elseifConditions+=Expression ')'
	elseifthenBlocks+=Block)*
	(=>'else' elseBlock=Block)?;
WhileStatement:
	'while' '(' condition= Expression ')'
	whileBlock=Block;
DoWhileStatement:
	'do'
	doWhileBlock=Block
	'while' '(' condition=Expression ')'';';
ForStatement:
	'for''('((init=Variable)|(';'))(condition=Expression)?';'(increment=Expression)?')'
	forBlock=Block;
SwitchStatement:
	'switch' '('expr=Expression')'
		('case' values+=integer_value ':'
			(caseStatements+=Statement)*
			('break'';')?
		('default'':'
			(defaultStatements+=Statement)*
Block:
	{Block} '{' (blockStatements+=Statement)* '}';
Variable:
	VariableDeclaration | VariableAssignment;
VariableDeclaration:
	type=Type name=ID (op='=' expr=Expression)?';' |
	'const' type=Type name=ID op='=' expr=Expression';';
VariableAssignment:
	assignee=[VariableDeclaration] op=assignment_operator expr=Expression';';
Expression returns Expression:
    BooleanExpression;
BooleanExpression returns Expression:
	Comparison
	({Expression.left=current} op=BooleanOperator right=Comparison)*;
Comparison returns Expression:
	Equal
	({Expression.left=current} op=ComparisonOperator right=Equal)*;
Equal returns Expression:
    Addition
    ({Expression.left=current} op=EqualityOperator right=Addition)*;
Addition returns Expression:
    Multiplication
    ({Expression.left=current} op=AdditionOperator right=Multiplication)*;
Multiplication returns Expression:
    Bitwise
    ({Expression.left=current} op=MultiplicationOperator right=Bitwise)*;
Bitwise returns Expression:
	Prefixed
	({Expression.left=current} op=BitwiseOperator right=Prefixed)*;
Prefixed returns Expression:
    {BooleanNegation} =>"!" expression=Atomic |
    {BitwiseNot} =>"~" expression=Atomic |
    Atomic;
Atomic returns Expression:
    lp='(' expr=Expression rp=')' |
    {IntegerLiteral} value=integer_value |
    {BooleanLiteral} value=boolean_value |
    {IntegerIncrementDecrement} (increment_decrement_operator ref=[VariableDeclaration]|ref=[VariableDeclaration] increment_decrement_operator) |
    {VariableReference} ref=[VariableDeclaration];
Type:
    {IntegerType} 'int' |
    {BooleanType} 'bool';
AdditionOperator:
MultiplicationOperator:
BitwiseOperator:
ComparisonOperator:
EqualityOperator:
BooleanOperator:
boolean_value:
	'true' | 'false';
assignment_operator:
increment_decrement_operator:
integer_value:
	'-'?INT+;
I tried to follow the smallJava exercise https://github.com/LorenzoBettini/packtpub-xtext-book-examples/blob/master/org.example.smalljava
but with no luck.
My scope provider code is like this:
def dispatch IScope symbolsDefinedBefore(Block b, EObject o) {
		Scopes::scopeFor(b.blockStatements)
Re: Can't get scoping to work [message #1727782 is a reply to message #1727780] Sun, 27 March 2016 11:00 Go to previous messageGo to next message
This will work neither with xtext 284 nor with xtext 2.9.x
If you use xtext 284 or change the parent class to AbstractDeclarativeScopeProvider
Then the method Name is scope_<refereceOwner>_<referenceName>
In xtext 29x you have to override getScope(EObject,EReference) and do if else on the parameters
Re: Can't get scoping to work [message #1727783 is a reply to message #1727782] Sun, 27 March 2016 11:05 Go to previous messageGo to next message
In xtext 28x scope_RefType works as well
Re: Can't get scoping to work [message #1727784 is a reply to message #1727783] Sun, 27 March 2016 11:11 Go to previous messageGo to next message
I am using 2.9.x
Would you give me a simple example using the
to make a scope for the "Block" rule?
Re: Can't get scoping to work [message #1727785 is a reply to message #1727784] Sun, 27 March 2016 11:13 Go to previous messageGo to next message
The block rule needs no scoping. Do you mean variableassignment
Re: Can't get scoping to work [message #1727786 is a reply to message #1727785] Sun, 27 March 2016 11:15 Go to previous messageGo to next message
I mean VariableAssignment and also VariableReference in Expression
Re: Can't get scoping to work [message #1727787 is a reply to message #1727786] Sun, 27 March 2016 11:27 Go to previous messageGo to next message
just a starting point covering only a few cases, the rest is your job
def IScope getVariableScope(EObject context) {
		if (context == null) {
			return IScope.NULLSCOPE
		// get the block we are inside
		var block = EcoreUtil2.getContainerOfType(context, Block);
		if (block != null) {
			return Scopes.scopeFor(
				// var decls in that block
				block.blockStatements.filter(VariableDeclaration),
				// use name attribute
				QualifiedName.wrapper(SimpleAttributeResolver.NAME_RESOLVER),
				// the variable from outer blocks
				getVariableScope(block.eContainer)
		// get the module we are inside
		var module = EcoreUtil2.getContainerOfType(context, Module)
		if (module != null) {
			return Scopes.scopeFor(module.statements.filter(VariableDeclaration))
		//TODO handle possible other cases, handle order if relevant
Re: Can't get scoping to work [message #1727788 is a reply to message #1727787] Sun, 27 March 2016 11:37 Go to previous messageGo to next message
Thanks a lot. I will give it a shot.
Re: Can't get scoping to work [message #1727789 is a reply to message #1727788] Sun, 27 March 2016 11:44 Go to previous messageGo to next message
I have used the code you gave me. But the function itself doesn't get invoked at all. I have set a breakpoint and used debugging mode and it never triggers.
Re: Can't get scoping to work [message #1727790 is a reply to message #1727789] Sun, 27 March 2016 11:45 Go to previous messageGo to next message
How does your scope Provider class look like and which xtext Version do you use
Re: Can't get scoping to work [message #1727791 is a reply to message #1727790] Sun, 27 March 2016 11:46 Go to previous messageGo to next message
guess you missed that one
class MyDslScopeProvider extends AbstractMyDslScopeProvider {
	override getScope(EObject context, EReference reference) {
		if (reference == MyDslPackage.Literals.VARIABLE_ASSIGNMENT__ASSIGNEE) {
			return getVariableScope(context)
		super.getScope(context, reference)
Re: Can't get scoping to work [message #1727792 is a reply to message #1727791] Sun, 27 March 2016 12:03 Go to previous messageGo to next message
I have added this too
def IScope getVariableReferenceScope(EObject context) {
				getVariableReferenceScope(block.eContainer)
I though have an error. I guess it is because the 'NamesAreUniqueValidator'.
int x = 0 ;
	x = 10;
	int a = 10;
	a = x;
int a = 10; // Duplicate Statement 'a'
int b = a;
How can I make the NamesAreUniqueValidator scope oriented?
Re: Can't get scoping to work [message #1727793 is a reply to message #1727792] Sun, 27 March 2016 12:06 Go to previous messageGo to next message
debug the code and have a look what it does. or simply throw it out and implement your own validation
Re: Can't get scoping to work [message #1727794 is a reply to message #1727793] Sun, 27 March 2016 12:13 Go to previous messageGo to next message
I have one question. How can I have a scope for the VariableDeclaration statement although it doesn't have a reference []?
I also don't know where to find the implementation for the NamesAreUniqueValidator, This is why I am asking you if there is a way to make it scope oriented.
Re: Can't get scoping to work [message #1727795 is a reply to message #1727794] Sun, 27 March 2016 12:20 Go to previous messageGo to next message
i do not understand this question. please elaborate. scoping and names are unique validation have ZERO in common.
names are unque validation is about things haveing names and thus beeing exported from the file.
you include NamesAreUniqueValidator somewhere in your code. (in the workflow or in the scope provider class)
if you want to know how it works debug it and NamesAreUniqueValidationHelper
Re: Can't get scoping to work [message #1727796 is a reply to message #1727795] Sun, 27 March 2016 12:25 Go to previous messageGo to next message
I want each of these to be valid. Is this possible?
	int a = 10;
	int a = 10;
int a = 10;
Re: Can't get scoping to work [message #1727797 is a reply to message #1727796] Sun, 27 March 2016 12:33 Go to previous messageGo to next message
i explained you: the names are unique validation checks if names are you unique.
so you would have to remove it, modify it, or make it unique.
you did no post any attempt yet. so why no
import java.util.List
import org.eclipse.xtext.EcoreUtil2
import org.eclipse.xtext.naming.DefaultDeclarativeQualifiedNameProvider
import org.eclipse.xtext.naming.QualifiedName
import org.xtext.example.mydsl.myDsl.Block
import org.xtext.example.mydsl.myDsl.Module
class MyQNP extends DefaultDeclarativeQualifiedNameProvider {
def QualifiedName qualifiedName(Block block) {
//TODO make this more elegant
val index = EcoreUtil2.indexOf(block.eContainer.eGet(block.eContainingFeature) as List, block, 0)
val result = if (block.eContainer instanceof Module) {
QualifiedName.create("_"+index)
} else {
getFullyQualifiedName(block.eContainer).append(QualifiedName.create("_"+index))
println(result)
return result
Re: Can't get scoping to work [message #1727799 is a reply to message #1727797] Sun, 27 March 2016 13:25 Go to previous messageGo to next message
So If I provide the qualified names myself, The NamesAreUniqueValidator will use them automatically?
Re: Can't get scoping to work [message #1727800 is a reply to message #1727799] Sun, 27 March 2016 13:36 Go to previous messageGo to next message
yes. of course you have to bind the nameprovider. something like
class MyDslRuntimeModule extends AbstractMyDslRuntimeModule {
	override bindIQualifiedNameProvider() {
		MyQNP
Re: Can't get scoping to work [message #1727801 is a reply to message #1727800] Sun, 27 March 2016 13:46 Go to previous message
Thanks a lot.
You are the best.
Previous Topic:Import objects from XMI-based model into my DSL
Next Topic:Xtext Display line numbers
Current Time: Fri Jul 25 23:59:10 EDT 2025
Powered by FUDForum. Page generated in 0.04786 seconds
