Home » Modeling » Model-to-Model Transformation » Cross-referencing UML profiles in ATL(Cross-referencing UML profiles from within Eclipse ATL)
Cross-referencing UML profiles in ATL [message #1727730] Fri, 25 March 2016 18:51 Go to next message
I have an issue with ATL translation in Eclipse when the UML model contains cross-references to a UML profile. I exported a UML2 model via MagicDraw export feature, and it puts the following headers in the exported model:
xmlns:Company_Library="http:///schemas/Company_Library/_mci5gB9YEeWGPsqlZErtvg/0"
Furthermore inside the UML model, I am referencing the port of a "connector" from the following piece:
<ownedConnector xmi:id="_17_0_2_2_f5f036c_1422441878678_115434_20754" name="" visibility="public">
<end xmi:id="_17_0_2_2_f5f036c_1422441878678_431675_20755" partWithPort="_17_0_2_2_f5f036c_1422441279950_334585_18801">
<role xmi:type="uml:Port" href="Company_Library.profile.uml#_17_0_2_1_68d022b_1370974096642_633421_14584"/>
</end>
<end xmi:id="_17_0_2_2_f5f036c_1422441878693_441124_20756">
<role xmi:type="uml:Port" href="Company_Library.profile.uml#_17_0_2_2_f5f036c_1422205317634_642500_19398"/>
</end>
</ownedConnector>
Inside my ATL script, I reference the port via the "role" attribute:
connector.end.at(dest_index).role.__xmiID__
However while running the ATL translation script within Eclipse, it is unable to reference the role defined by:
which is a port defined inside Company_Library.profile.uml.
Questions:
1. How do I modify my Ant script to allow the cross-reference to succeed? I already enabled <option name="allowInterModelReferences" value="true"/>. Do I need to explicitly load the Company_Library profile as a UML model, something like:
<atl.loadModel name="Company_Library.profile.uml" metamodel="UML2" path="<path_to_Company_Library.profile.uml">?
2. Do I need to place Company_Library.profile.uml inside a "schemas" folder since the UML2 model header specifies "Company_Library" namespace to be within the "schemas" folder?
Any suggestions will be greatly appreciated.
Re: Cross-referencing UML profiles in ATL [message #1727766 is a reply to message #1727730] Sun, 27 March 2016 02:40 Go to previous message
You will probably get a better response from the ATL newsgroup.
Your problem seems non-trivial so you may need to provide a repro rather
than an overview.
Ed Willink
On 26/03/2016 21:38, Kevin Mansfield wrote:
> Hello,
> exported model:
> </end>
> </end>
> </ownedConnector>
> Questions:
Previous Topic:When is a transformation declarative or imperative?
Next Topic:[QVTo] how to use two target sources?
Current Time: Mon Jul 21 22:34:30 EDT 2025
Powered by FUDForum. Page generated in 0.06006 seconds
