Home » Eclipse Projects » Eclipse 4 » Styling MPartStack tab-height with relative height
Styling MPartStack tab-height with relative height [message #1727602] Thu, 24 March 2016 07:04 Go to next message
I am styling the tab height of MPartStack via a custom CSS file in my e4 RCP application:
.MPartStack {
     swt-tab-height: 25px;
However, this hard-coded 25px does not work an all platforms, in particular when the application is running in Windows 10 with a HiDPI screen. On HiDPI 25px is not enough, even smaller than the text. But then 25px works on OS X Retina.
Is there any why to set the height relative to the font height?
Or add padding above and/or below the text?
This SWT Mapping Wikipage seems to imply only fixed values are possible. So what are you doing then? Writing custom renderers?
Re: Styling MPartStack tab-height with relative height [message #1727622 is a reply to message #1727602] Thu, 24 March 2016 09:47 Go to previous messageGo to next message
Have you tried to use em instead of px? Haven't tried it myself yet, but in CSS this should do the trick IIRC.
Re: Styling MPartStack tab-height with relative height [message #1727659 is a reply to message #1727622] Thu, 24 March 2016 16:45 Go to previous messageGo to next message
I just tried "25em" instead. That has no styling effect whatsoever.
Re: Styling MPartStack tab-height with relative height [message #1727802 is a reply to message #1727659] Sun, 27 March 2016 14:29 Go to previous message
I now configured a custom renderer:
.MPartStack {
	swt-tab-renderer: url('bundleclass://name.abuchen.portfolio.ui/name.abuchen.portfolio.ui.renderers.CTabRendering');
with a trivial implementation:
public class CTabRendering extends CTabFolderRenderer
    public CTabRendering(CTabFolder parent)
        super(parent);
    protected Point computeSize(int part, int state, GC gc, int wHint, int hHint)
        if (part != PART_HEADER)
            return super.computeSize(part, state, gc, wHint, hHint);
        int height = gc.textExtent("Default", SWT.DRAW_TRANSPARENT | SWT.DRAW_MNEMONIC).y + 12; //$NON-NLS-1$
        Rectangle trim = computeTrim(part, state, 0, 0, 0, height);
        return new Point(trim.width, trim.height);
(Alternatively, one could / should iterate over the tabs and compute individual sizes. However, in my use case, I do not have icons and alternative fonts).
Previous Topic:E4 Preferences Dialog
Next Topic:Hello World
Current Time: Thu Jul 24 23:42:35 EDT 2025
Powered by FUDForum. Page generated in 0.08427 seconds
