Home » Language IDEs » ServerTools (WTP) » Use other project source in web project question
Use other project source in web project question [message #172685] Thu, 29 June 2006 00:07 Go to next message
Originally posted by: calendarw.hotmail.com
I have a web project that will be use some of class in another project, so I
added the project in web project build path, when I run the web project in
server, it will not load the related project so it occur some like class not
found exception. So how I can load the related project to solve this
problem?
Jr. P
Re: Use other project source in web project question [message #172710 is a reply to message #172685] Thu, 29 June 2006 12:56 Go to previous messageGo to next message
Originally posted by: dserodio.gmail.com
calendarw @ Jr.P wrote:
> problem?
The web project build path is only used for building, not for running.
For this, you'll need to add a "J2EE Module Dependency".
HTH,
Daniel Serodio
Re: Use other project source in web project question [message #172744 is a reply to message #172710] Thu, 29 June 2006 17:34 Go to previous messageGo to next message
Originally posted by: anderws.endinfosys.com
"Daniel Serodio" <dserodio@gmail.com> wrote in message
news:e810og$ign$1@utils.eclipse.org...
>> Hi,
>> so I
>> in
>> not
>> problem?
> HTH,
> Daniel Serodio
However, the 'J2EE Module dependencies' does not show projects that are in
the
'Java Build Path' -> 'Projects'. So they can not be added.
In a similiar fashion, we use 'User Libraries' for external dependencies,
these are not
picked up for the current project. When in fact I would like them picked up
recursively.
For example I have a UI project that is dependent on user lib 'ADF lib', and
project 'Persist' which is dependent on user lib 'Hibernate lib'
Even if I had to specify them via 'J2EE Module Dependencies', it would
sure beat having to either put them in common or copy them each time the
webapp
was refreshed.
If it makes a difference, I'm running with 'Run modules directly from
workspace' turned
off on running JST 1.5.0v20060515, if that makes a difference.
Re: Use other project source in web project question [message #172751 is a reply to message #172744] Thu, 29 June 2006 22:24 Go to previous messageGo to next message
um....
I tried to link the source file and set export into the web project build
path and it look like work, is it good?
Jr. P
"Dean" <anderws@endinfosys.com> wrote in message
news:e81h20$hqi$1@utils.eclipse.org...
>>> Hi,
>>> so I
>>> in
>>> not
>>> problem?
>> HTH,
>> Daniel Serodio
> the
> these are not
> up recursively.
> and
> webapp
> was refreshed.
> workspace' turned
Re: Use other project source in web project question [message #172805 is a reply to message #172751] Fri, 30 June 2006 11:46 Go to previous message
Found it. The projects that showed in j2ee dependent have project facets
java and utility. Added those facets to the missing projects. And they
appeared. Restarted the server and it works.
Removed the three projects from the build path and they still don't show up
in the j2ee dependent modules list.
Looked at each of the these products and the src and test directories are
checked and grayed on the export screen.
Took a 4th project that has the 3 other projects on build path (and does
display in the j2ee dependent modules list) on its export screen checked the
3 other projects to export. Added this to the ui project j2ee dependents.
A jar is created for the 4th project but not the other three. The request
still failed with a missing class def.
Noticed that a file was changed by this action
'.settings/org.eclipse.wst.common.component' so copied the
<dependent-module> element and adjusted the name for the 3 projects that it
requires. Now the projects appear in the web libraries, but there is no jar
created for them.
"calendarw @ Jr.P" <calendarw@hotmail.com> wrote in message
news:e82213$7h6$1@utils.eclipse.org...
> um....
> Jr. P
>>>> Hi,
>>>> so I
>>>> in
>>>> class not
>>>> problem?
>>> HTH,
>>> Daniel Serodio
>> in the
>> these are not
>> up recursively.
>> and
>> webapp
>> was refreshed.
>> workspace' turned
Previous Topic:TCP monitor SOAP requests
Next Topic:Importing existing web project with Callisto
Current Time: Wed Jul 23 00:42:39 EDT 2025
Powered by FUDForum. Page generated in 0.03069 seconds
