Home » Eclipse Projects » Spatiotemporal Epidemiological Modeler (STEM) » Dragging components into a scenario
Dragging components into a scenario [message #1727410] Tue, 22 March 2016 16:31 Go to next message
I am having trouble dragging components, such as models and sequencers, into a scenario. Online tutorials make it seem like you should be able to just drag the components into the scenario, but I am unable to do this. Any suggestions?
Re: Dragging components into a scenario [message #1727413 is a reply to message #1727410] Tue, 22 March 2016 16:36 Go to previous messageGo to next message
I, for one, could use significantly more context. Exactly what are you talking about? Which online tutorials?
Re: Dragging components into a scenario [message #1727414 is a reply to message #1727413] Tue, 22 March 2016 16:44 Go to previous messageGo to next message
Here is a link to the tutorial I was referring https://wiki.eclipse.org/Creating_a_STEM_Scenario
The author makes a solver and then drags it into the scenario. This is what I am having trouble with. I created a stochastic solver but am unable to move it into the scenario I would like to run.
[Updated on: Tue, 22 March 2016 22:32] by Moderator
Re: Dragging components into a scenario [message #1728210 is a reply to message #1727414] Thu, 31 March 2016 18:37 Go to previous message
Please make sure you open the scenario in the "Resource Set" window. You can not drag components into other components in the project explorer. To do this, double click the scenario in the project explorere and you will see it appear in the large Resource Set window to the right. Then drag your solver (or other compnent) from the project explorer to the Scenario in the Resource Set. The operation is an Eclipse Rich Client feature. I have seen this take two tries on Mac until you get used to it. If you still have problems please send email to stem-dev. Please observe. this weeks integration build has a problem so please use STEM 3.0M2 release for now and watch for news on the integration build.
Previous Topic:Problems with this weeks STEM Integration Build
Next Topic:Error With Gui display in Simulation perspective
Current Time: Sat Jun 07 07:50:49 EDT 2025
Powered by FUDForum. Page generated in 0.04663 seconds
