Home » Archived » Jubula » SOLVED Table - row remove
icon5.gif  SOLVED Table - row remove [message #1726974] Thu, 17 March 2016 17:09 Go to next message
Hi everyone,
i'm new in Jubula, I started few days ago. I'm testing very simple app in Java/Swing. It's a table with 2 options - remove or add rows (via Menu or Buttons).
I need test removing third row from this table with button.
So I did :
1. Select->Table->Select Cell
2. Click on Button
3. Check->Table->Check cell with cell spec
But there is some problem with checking. I want remove 3. row and the next step is checkin this row - if is there a value which is shifted from 4. row.
Can you tell me, where the id the problem? What am I doing wrong?
I hope you understand me, my english is not very good. Rolling Eyes
Thanks for your time.
MY APP:
index.php/fa/25341/0/
MY TEST RESULT:
index.php/fa/25342/0/
  • Attachment: app.jpg
    (Size: 71.57KB, Downloaded 371 times)
  • Attachment: test.PNG
    (Size: 11.89KB, Downloaded 354 times)
[Updated on: Sat, 19 March 2016 05:45] by Moderator
Re: SOLVED Table - row remove [message #1727326 is a reply to message #1726974] Tue, 22 March 2016 04:16 Go to previous message
Hi Irena,
could you solve your problem? If you have any more problems you can check out the Jubula Reference Manual and the Jubula User Manual.
Oliver
Previous Topic:Indeterministic RCP AUT started response
Next Topic:AUT Configuration environment variable
Current Time: Mon Jul 21 03:49:44 EDT 2025
Powered by FUDForum. Page generated in 0.02881 seconds
