Home » Eclipse Projects » BPMN 2.0 Modeler » Customtask features no longer recognized(Customtask features no longer recognized)
Customtask features no longer recognized [message #1727173] Sun, 20 March 2016 18:09 Go to next message
Hello Rob.
I installed version 1.3.0 beta and find that the:
ModelDecorator.findEStructuralFeatureInDocumentRoot has changed fundamentally. Specifically I have a problem with line 1025:
if (typeName.equals(owningEClass.getName())) {
this means that feature extTask, with typeName Task should have owningclass Task but in reality it is DocumentRoot given how the customtask plugin is made. I guess with the newer versions of EMF we could now enhance the bpmn2 model directly but why change a working concept?
If this is intentional, please tell us how we should now add custom features from an EMF model.
Cheers
Martin
Re: Customtask features no longer recognized [message #1727246 is a reply to message #1727173] Mon, 21 March 2016 10:44 Go to previous messageGo to next message
Hi Martin,
Can you give me some more details about the type of extension feature you are trying to add? Is your case similar to the customtask example plugin that is shipped with the "BPMN2 Modeler - Examples" feature?
If you could share the relevant bits of your plugin.xml, ecore, and java classes that would help.
Bob
Re: Customtask features no longer recognized [message #1727278 is a reply to message #1727246] Mon, 21 March 2016 13:04 Go to previous message
Hello Bob.
My setup is identical with the customtask plugin except that I use a model extension instead of a custom task.
By the way, with the same version of the modeler (1.3.0 beta), I get a dump with the custom task plugin.
I'll post the relevant pieces a bit later when I have access to the computer in question.
Cheers
Martin.
Previous Topic:BPMN2 Modeler 1.2.4.CR1 - looks good to me!
Next Topic:Replacing Tab doesn't work
Current Time: Mon Jul 21 09:14:36 EDT 2025
Powered by FUDForum. Page generated in 0.07883 seconds
