ClassCastException for console view from BPMEditor [message #1726999] |
Fri, 18 March 2016 03:29  |
Hello Colleagues,
With the latest nightly build from bpmn modeler and Mars.2 i have observed repeatedly ClassCastException being thrown when switching between java editor and/or focusing console view.
Unfortunately from error logs it seems to be being thrown from DefaultBPMN2Editor.
It seems to be because in DefaultBPMN2Editor > selectionChanged(IWorkbenchPart part, ISelection selection)
doing the cast of selection without checking for type.
Iterator iter = ((IStructuredSelection) selection).iterator();
java.lang.ClassCastException: org.eclipse.jface.text.TextSelection cannot be cast to org.eclipse.jface.viewers.IStructuredSelection
at org.eclipse.bpmn2.modeler.ui.editor.DefaultBPMN2Editor.selectionChanged(DefaultBPMN2Editor.java:647)
at org.eclipse.ui.internal.e4.compatibility.SelectionService.notifyListeners(SelectionService.java:237)
at org.eclipse.ui.internal.e4.compatibility.SelectionService.notifyListeners(SelectionService.java:170)
at org.eclipse.ui.internal.WorkbenchWindow$WWinPartService.partActivated(WorkbenchWindow.java:3101)
at org.eclipse.ui.internal.WorkbenchPage$14.run(WorkbenchPage.java:4912)
at org.eclipse.ui.internal.WorkbenchPage.firePartActivated(WorkbenchPage.java:4909)
at org.eclipse.ui.internal.WorkbenchPage.access$19(WorkbenchPage.java:4897)
at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partActivated(WorkbenchPage.java:203)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$3.run(PartServiceImpl.java:245)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartActivated(PartServiceImpl.java:242)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:711)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:639)
at org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer.activate(AbstractPartRenderer.java:106)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer$9.widgetSelected(StackRenderer.java:1088)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4362)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1113)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1137)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1122)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:788)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:3158)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1841)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:330)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4180)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3769)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:694)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:606)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
BR,
Bhuvan
FUDForum. Page generated in 0.08229 seconds
