Home » Eclipse Projects » Sirius » Add key listener on an element of diagram
Add key listener on an element of diagram [message #1726618] |
Tue, 15 March 2016 03:23  |
Hi all,
I'd like to add a key listener on elements. For example, when user click on an element on diagram, then he click Tab button on keyboard, the diagram will generate a new element (or doing something).
Can anyone give me a solution?
Thanks and BRs,
Tuan Hoang
Re: Add key listener on an element of diagram [message #1726630 is a reply to message #1726618] |
Tue, 15 March 2016 05:21   |
Sirius doesn't offer mean to do that through odesign. But as Sirius is
based on GMF, you can use GMF API to do that, or GEF as GMF is based on GMF.
Each swt/draw2d event is intercepted by the org.eclipse.gef.EditDomain,
for key press interception EditDomain.keyDown() is called. Looking at
key press after a node selection, the
org.eclipse.gef.tools.SelectionTool is called and this last call
DirectEditKeyHandler which allow to associate jface action to key.
This is not a solution but a clue to a solution.
Best Regards.
Le 15/03/2016 08:24, Tuan Hoang Anh a écrit :
> Hi all,
> Thanks and BRs,
> Tuan Hoang
Esteban Dugueperoux - Obeo
Re: Add key listener on an element of diagram [message #1726742 is a reply to message #1726630] |
Wed, 16 March 2016 01:06   |
Hi Esteban,
Could you please guide me how to intercept swt events by org.eclipse.gef.EditDomain? Does eclipse plugins provide any extension to add more implementation for EditDomain? Is it possible if I want to overwrite a default implementation of Sirius in EditDomain?
Thanks and BRs,
Tuan Hoang
Esteban Dugueperoux wrote on Tue, 15 March 2016 09:21Hi,
Best Regards.
> Hi all,
> Thanks and BRs,
> Tuan Hoang
Re: Add key listener on an element of diagram [message #1726757 is a reply to message #1726742] |
Wed, 16 March 2016 04:24   |
Hi Tuan,
As your question is not specific to Sirius but more GEF/GMF related, I
advice you to look at GEF/GMF documentation, for example [1], [2] and [3].
From what I have seen in looking at GEF/GMF code, a KeyHandler is
referenced by EditPartViewer and this last as the EditDomain are
accessible through EditPart and GMF DiagramEditor.
[1] https://wiki.eclipse.org/GEF_Description
[2] https://wiki.eclipse.org/GEF_Description2#EditDomain
[3] https://www.eclipse.org/articles/Article-Introducing-GMF/article.html
Best Regards.
Le 16/03/2016 06:06, Tuan Hoang Anh a écrit :
> Hi Esteban,
> Thanks and BRs,
> Tuan Hoang
>> Hi,
>> on GMF.
>> org.eclipse.gef.EditDomain, for key press interception
>> EditDomain.keyDown() is called. Looking at key press after a node
>> selection, the org.eclipse.gef.tools.SelectionTool is called and this
>> last call DirectEditKeyHandler which allow to associate jface action
>> to key.
>> Best Regards.
>> > Hi all,
>> click
>> > Thanks and BRs,
>> > Tuan Hoang
>> Need training or professional services for Sirius?
>> http://www.obeodesigner.com/sirius
Re: Add key listener on an element of diagram [message #1726857 is a reply to message #1726757] |
Thu, 17 March 2016 01:01   |
Hi Esteban,
Thank for your support.
As my investigation, I have to create a new org.eclipse.ui.editors extension and override the implementation of EditDomain function to reach my target.
But I want to add the KeyHandler to the Sirius Diagram (Representation), not the Model File, and I don't know the extension of that file.
Is my understanding right or there is another way to do it?
Thanks and BRs,
Tuan Hoang
Esteban Dugueperoux wrote on Wed, 16 March 2016 08:24Hi Tuan,
Best Regards.
> Hi Esteban,
> Thanks and BRs,
> Tuan Hoang
>> Hi,
>> on GMF.
>> to key.
>> Best Regards.
>> > Hi all,
>> click
>> > Thanks and BRs,
>> > Tuan Hoang
Re: Add key listener on an element of diagram [message #1726880 is a reply to message #1726857] |
Thu, 17 March 2016 04:44   |
Hi Tuan,
You have no need to declare a new editor, you must reuse
SiriusDiagramGraphicalViewer which is the Sirius implementation of
EditPartViewer to put your action associated to a key press in the
KeyHandler. To do that you could put a IPartListener to listens
DDiagramEditorImpl opening, get the SiriusDiagramGraphicalViewer, get
the KeyHandler and put your action to an associated KeyStroke.
Best Regards.
Le 17/03/2016 06:01, Tuan Hoang Anh a écrit :
> Hi Esteban,
> reach my target. But I want to add the KeyHandler to the Sirius Diagram
> that file.
> Thanks and BRs,
> Tuan Hoang
>> Hi Tuan,
>> [3].
>> Best Regards.
>> > Hi Esteban,
>> > Thanks and BRs,
>> > Tuan Hoang
>> >> Hi,
>> >> on GMF.
>> >> to key.
>> >> Best Regards.
>> >> > Hi all,
>> >> click
>> >> > Thanks and BRs,
>> >> > Tuan Hoang
Re: Add key listener on an element of diagram [message #1726900 is a reply to message #1726880] |
Thu, 17 March 2016 07:12   |
Hi Esteban,
I did follow your suggestion, and get the KeyHandler successfully.
But it didn't work when I add a new action to an associated KeyStroke.
IEditorPart editorPart = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().getActiveEditor();
if (editorPart != null) {
if (editorPart instanceof DiagramEditor) {
EditPartViewer viewer = ((DiagramEditor) editorPart).getDiagramEditPart().getViewer();
if (viewer instanceof SiriusDiagramGraphicalViewer) {
KeyHandler keyHandler = viewer.getKeyHandler();
if (keyHandler == null) {
keyHandler = new KeyHandler();
keyHandler.put(KeyStroke.getPressed(SWT.TAB, 0), new AutoSuggestionElement());
viewer.setKeyHandler(keyHandler);
The AutoSuggestionElement class implements IAction, but its run() function isn't called when I presses Tab on element.
Can you tell me if I miss something?
Thanks and BRs,
Tuan Hoang
Best Regards.
Re: Add key listener on an element of diagram [message #1726919 is a reply to message #1726900] |
Thu, 17 March 2016 08:33   |
I have never tested that, I only give you a mean reading the GMF code.
Then I cannot tell you if you missed something, it is to you to debug in
GMF code to look why it doesn't works.
Best Regards.
Le 17/03/2016 12:12, Tuan Hoang Anh a écrit :
> Hi Esteban,
> Thanks and BRs,
> Tuan Hoang
> Quote:
>> Hi Tuan,
>> Best Regards.
Re: Add key listener on an element of diagram [message #1728886 is a reply to message #1728827] |
Fri, 08 April 2016 05:05   |
Hi Parsa,
The suggestion from Esteban helped me a lot. I created a Listener whenever new editor was activated and put my action to an associated KeyStroke to viewer's KeyHandler.
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().addPartListener(new IPartListener2() {
public void partVisible(IWorkbenchPartReference partRef) {
// TODO Auto-generated method stub
public void partOpened(IWorkbenchPartReference partRef) {
public void partInputChanged(IWorkbenchPartReference partRef) {
public void partHidden(IWorkbenchPartReference partRef) {
public void partDeactivated(IWorkbenchPartReference partRef) {
public void partClosed(IWorkbenchPartReference partRef) {
public void partBroughtToTop(IWorkbenchPartReference partRef) {
public void partActivated(IWorkbenchPartReference partRef) {
IEditorPart editorPart = partRef.getPage().getActiveEditor();
if (editorPart != null && editorPart instanceof DiagramEditor) {
// Add action when pressing Ctrl + Space
keyHandler.put(KeyStroke.getPressed(SWT.SPACE, 0x20, SWT.CTRL), new YourActionClass());
You can write YourActionClass by implementing IAction interface.
There are some default action that you can refer in org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.
Best Regards,
Tuan Hoang
Parsa Pourali wrote on Thu, 07 April 2016 17:06Hi Tuan,
Could you please provide me with some info on how did you solve this problem ? I'm also looking for a way to capture key press on a Sirius diagram.
Do we need to use any extension points ?
It would be much appreciated if you could kindly help me on this,
Best Regards,
Parsa
Re: Add key listener on an element of diagram [message #1729161 is a reply to message #1729081] |
Mon, 11 April 2016 11:42   |
Hi tuan,
Now I'm sure I'm doing sth wrong
This is my key stroke class:
public class myeditor extends EditorPart {
public myeditor() {
public void doSave(IProgressMonitor monitor) {
public void doSaveAs() {
public void init(IEditorSite site, IEditorInput input) throws PartInitException {
JOptionPane.showMessageDialog(null, input);
site.getPage().addPartListener(new IPartListener2() {
JOptionPane.showMessageDialog(null, "ctrl+Space");
public boolean isDirty() {
return false;
public boolean isSaveAsAllowed() {
return false;
public void createPartControl(Composite parent) {
JOptionPane.showMessageDialog(null, parent);
public void setFocus() {
JOptionPane.showMessageDialog(null, "focus");
and my action class is:
public class YourActionClass implements IAction {
public void addPropertyChangeListener(IPropertyChangeListener listener) {
public int getAccelerator() {
return 0;
public String getActionDefinitionId() {
return null;
public String getDescription() {
return null;
public ImageDescriptor getDisabledImageDescriptor() {
return null;
public HelpListener getHelpListener() {
return null;
public ImageDescriptor getHoverImageDescriptor() {
return null;
public String getId() {
return null;
public ImageDescriptor getImageDescriptor() {
return null;
public IMenuCreator getMenuCreator() {
return null;
public int getStyle() {
return 0;
public String getText() {
return null;
public String getToolTipText() {
return null;
public boolean isChecked() {
return false;
public boolean isEnabled() {
return false;
public boolean isHandled() {
return false;
public void removePropertyChangeListener(IPropertyChangeListener listener) {
public void run() {
JOptionPane.showMessageDialog(null, "ctrlSpace");
public void runWithEvent(Event event) {
public void setActionDefinitionId(String id) {
public void setChecked(boolean checked) {
public void setDescription(String text) {
public void setDisabledImageDescriptor(ImageDescriptor newImage) {
public void setEnabled(boolean enabled) {
public void setHelpListener(HelpListener listener) {
public void setHoverImageDescriptor(ImageDescriptor newImage) {
public void setId(String id) {
public void setImageDescriptor(ImageDescriptor newImage) {
public void setMenuCreator(IMenuCreator creator) {
public void setText(String text) {
public void setToolTipText(String text) {
public void setAccelerator(int keycode) {
you can see that in the run method I just used JOptionpane to show a dialog just to test. and it is not working. I mean the class myeditor is just a class, how can the designer be aware of it if we don't define extensions ?
Thanks a lot,
Bests,
Parsa
Re: Add key listener on an element of diagram [message #1729166 is a reply to message #1729161] |
Mon, 11 April 2016 12:08   |
Hi Parsa,
The problem is in YourActionClass.
You have to enable the IAction class to do run() method.
return true;
public void run() {
Hope your code works fine now.
Best Regards,
Tuan Hoang
Parsa Pourali wrote on Mon, 11 April 2016 15:42Hi tuan,
public myeditor() {
return false;
return false;
return 0;
return null;
return null;
return null;
return null;
return null;
return null;
return null;
return null;
return 0;
return null;
return null;
return false;
return false;
return false;
public void run() {
Thanks a lot,
Bests,
Parsa
Re: Add key listener on an element of diagram [message #1729193 is a reply to message #1729182] |
Mon, 11 April 2016 23:01   |
Hi Parsa,
Where do you exactly implement the keystroke listener:
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().addPartListener(new IPartListener2() { ...
I added this Listener to listen whenever user activates a new Diagram Editor. And my code will register a KeyStroke and associated Action.
You can add it into Activator class of plugin.
public void start(BundleContext context) throws Exception {
super.start(context);
IWorkbenchPage page = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage();
// adding a editor part listener
page.addPartListener(new IPartListener2() { ...
Quote: What do you mean by "viewer's KeyHandler" ?
The KeyHandler handles all normal keystrokes on an EditPartViewer. You can register a new KeyStroke and associated Action, then put to to the KeyHandler. When you focus on an element on diagram, and press the combine KeyStroke (in this case Ctrl + Space), the KeyHandler will call the run() method of associated Action.
Best Regards,
Tuan Hoang
Parsa Pourali wrote on Mon, 11 April 2016 20:36Hi Tuan,
Thank you , I applied your suggestion but I don't still get it work ! I think I am implementing the keystroke method in some stupid class that has no relation to what I want to do :
I was reading your previous posts and thought that I need to use org.eclipse.ui.editors extension point to register the keystroke, but apparently it is not correct. Could you please let me know how do you register your keystroke class ? or what is the extension that I should use ? What do you mean by "viewer's KeyHandler" ?
Thank you for your time and concern,
Bests,
Parsa
Current Time: Tue May 13 08:31:09 EDT 2025
Powered by FUDForum. Page generated in 0.31941 seconds
