Home » Eclipse Projects » Sirius » [SOLVED] Select Viewpoint doesn't show when using XText metamodel/grammar
[SOLVED] Select Viewpoint doesn't show when using XText metamodel/grammar [message #1726375] Fri, 11 March 2016 18:35 Go to next message
I have a design file (let's say myDesign.odesign) and an Ecore metamodel. My Ecore is generated by creating an ECore project. These two work fine. However, I need to change my Ecore meta model with XText grammar and the metamodel that is now generated with XText. When I create the modeling project and create my xtext instance file, and then select viewpoint, it doesn't show the viewpoint I designed so that I can select it !
I don't know how to make it work when using XText metamodel. I know it is possible since "Sirius Xtext Integration" example is doing the same.
Bests,
Parsa
[Updated on: Fri, 01 April 2016 12:16] by Moderator
Re: Select Viewpoint doesn't show when using XText metamodel/grammar [message #1726640 is a reply to message #1726375] Tue, 15 March 2016 06:40 Go to previous messageGo to next message
Hi Parsa,
A Viewpoint is selectable if you Modeling Project contains a semantic
resource with the file extension for which you have defined the
Viewpoint in your odesign. Do you have changed this file extension?
Note that with Xtext you can generate a default grammar from an existing
..ecore instead of doing a .ecore from a grammar.
Best Regards.
Le 12/03/2016 00:35, Parsa Pourali a écrit :
> select it !
> Bests,
> Parsa
Esteban Dugueperoux - Obeo
Re: Select Viewpoint doesn't show when using XText metamodel/grammar [message #1726826 is a reply to message #1726640] Wed, 16 March 2016 13:10 Go to previous messageGo to next message
Hi Esteban,
Thanks for you comment. I actually created a file with the right extension but it didn't work ! My files have the extension of "forml". In the odesign the model file extension was "*", it didn't work ! I changed it to "forml", again it didn't work ! The only time it works is that I add the model file as project dependency (right click on Project Dependency -> Add Model) in the modelling project.
It is weird as it works really good with EMF projects but not with xtext projects. Should I generate edit or editor from Genmodel ?
Parsa
Re: Select Viewpoint doesn't show when using XText metamodel/grammar [message #1726872 is a reply to message #1726826] Thu, 17 March 2016 04:13 Go to previous messageGo to next message
Indeed it is normal because only XMIResource are automatically added as
semantic resources to a Sirius session.
Technically this is managed by
org.eclipse.sirius.business.api.resource.LoadEMFResource class.
Best Regards.
Le 16/03/2016 18:10, Parsa Pourali a écrit :
> Hi Esteban,
> Parsa
Re: Select Viewpoint doesn't show when using XText metamodel/grammar [message #1726984 is a reply to message #1726872] Thu, 17 March 2016 21:00 Go to previous message
OK, I see,
I found that another solution would be changing the Xtext grammar, assuming System is the root of your grammar:
System:
	((worldmodel=WorldModel)? & (behaviourmodel=BehaviourModel)?);
should be changed to
System:
	{System} //create action
Thanks a lot !
Parsa
[Updated on: Fri, 01 April 2016 12:15] by Moderator
Previous Topic:Reuse of models
Next Topic:Diagram extensions hiding each other?
Current Time: Mon Jul 21 00:23:39 EDT 2025
Powered by FUDForum. Page generated in 0.04226 seconds
