| Installation problem [message #172665] |
Tue, 26 September 2006 23:36  |
Originally posted by: zaffarulla.sympatico.ca
I've just downloaded eclipse-SDK-3.2-win32(4) file of size 20.5 mb it is a
zip file from the url
http://www.eclipse.org/downloads/download.php?file=/eclipse/ downloads/drops/
R-3.2-200606291905/eclipse-SDK-3.2-win32.zip
I did extract the file with winzip what iam getting is eclipse folder and i
have plugins folder underneath and sub folders unde plugins but i could not
find the setup file to install eclipse
what iam doing wrong did i download thewrong file
iam on xp
please help
Zaf
| Re: Installation problem [message #172823 is a reply to message #172687] |
Wed, 27 September 2006 22:28   |
Originally posted by: tech.grillongroup.org
I unpacked the archive into C:\tools\eclipse and the launched the
ECLIPSE.EXE file. After a splash screen and a couple of seconds,
I get an error dialog and a log file appears in the ./configuration folder.
Here is some of the log file content
!SESSION 2006-09-27 20:57:52.247
eclipse.buildId=M20060629-1905
java.version=1.5.0_07
Framework arguments: -vm C:\Program Files\Java\jre1.5.0_06\bin\javaw.exe
Command-line arguments: -os win32 -ws win32 -arch x86 -vm C:\Program
!ENTRY org.eclipse.osgi 4 0 2006-09-27 20:57:53.108
!MESSAGE Bundle org.eclipse.core.runtime@start not found.
!ENTRY org.eclipse.osgi 4 0 2006-09-27 20:57:53.498
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:65)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
{snip}
Sure enough, I do not find a folder or file named
"org.eclipse.core.runtime"
in the tree below C:\tools\eclipse\.
When I inspect the original archive I file the file
"org.eclipse.core.runtime_3.2.0.v20060603.jar"
If I move this file into the plugins folder I get the same
error dialog and a different log file.
!SESSION 2006-09-27 21:00:01.993
!ENTRY org.eclipse.core.runtime 4 0 2006-09-27 21:00:11.337
!MESSAGE FrameworkEvent.ERROR
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Require-Bundle:
org.eclipse.equinox.preferences; bundle-version="[3.2.0,4.0.0)"
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:294)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:329)
at
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1037)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:573)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:495)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:275)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:455)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:189)
at
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:291)
{snip}
| Re: Installation problem [message #172836 is a reply to message #172823] |
Thu, 28 September 2006 01:10  |
Dan,
Are you, by any chance, using the built-in Windows XP "Compressed
Folders" feature to extract the Eclipse archive? It does not work well
with Eclipse archives. Use a "real" ZIP utility such as WinZip or 7-zip.
HTH,
Asaf
Asaf Yaffe
Eclipse TPTP Committer, Platform Project (JVMTI Profiler)
FUDForum. Page generated in 0.09204 seconds
