Home » Eclipse Projects » Sirius » Minimal Runtime Configuration(Target Configuration)
Minimal Runtime Configuration [message #1725532] Fri, 04 March 2016 03:34 Go to next message
I have a question about the minimal runtime. Is there a documentation of how to select features of the Sirius runtime. We want to have a minimal configuration with only the features needed to run our editor.
Thanks and regards,
Lars
Re: Minimal Runtime Configuration [message #1725787 is a reply to message #1725532] Mon, 07 March 2016 11:08 Go to previous messageGo to next message
Le 04/03/2016 15:53, Missing name Mising name a écrit :
> Hello,
Hi.
The org.eclipse.sirius.runtime feature contains everything a typical
Sirius runtime needs, excluding the parts only needed for the specifier.
The feature contains support for all standard Sirius dialects (diagrams,
tables and trees). If you only use some of them and really need
something minimal, you'll need to create your own feature inspired by
org.eclipse.sirius.runtime with the dialects you don't need removed.
You'll also need the runtime support for whichever query languages you
use in your VSMs, i.e. org.eclipse.sirius.runtime.aql if you used AQL
(recommended) and/or org.eclipse.sirius.runtime.acceleo if you used
Acceleo 3/MTL. The "var:/feature:/service:" pseudo-languages are
implemented in the core and do not need additional dependencies.
You may also need to have org.eclipse.sirius.runtime.ide.eef or
org.eclipse.sirius.runtime.ide.xtext if you want EEF or Xtext integration.
Pierre-Charles
Pierre-Charles David - Obeo
Re: Minimal Runtime Configuration [message #1725893 is a reply to message #1725787] Tue, 08 March 2016 05:55 Go to previous messageGo to next message
Hello Pierre-Charles,
thank you for the information.
I checked with our setup and we have additionally the org.eclipse.runtime.ide.ui and org.eclipse.runtime.ide.xtext features included. The first one we need because we have quite a lot of dependencies to classes like DDiagramEditor or DDiagram or ModelProjectManager which come from the diagram.ui or sirius.ui bundle. The latter I am not sure whether we need it, but we use a combination of an XText language based approach together with Sirius.
My concern is that both the org.eclipse.sirius.ui and org.eclipse.sirius.common.xtext both need org.eclipse.jdt.core as a hard dependency. Since our tool has no requirement towards java, we would rather avoid adding jdk bundles to our product. Any idea for a solution?
Lars
Re: Minimal Runtime Configuration [message #1726669 is a reply to message #1725893] Tue, 15 March 2016 10:55 Go to previous messageGo to next message
Hi Lars,
Indeed you point out a JDT/Sirius coupling.
For details :
- org.eclipse.sirius.ui plugin contains ModelingToggleNatureAction which
use JDT API to get a IProject, not sure if this is really usefull
- org.eclipse.sirius.common.xtext plugin has a dependency to JDT to
support case of XText DSL using JVM types, see [1].
Could you raise a bugzilla to highlight this issue?
[1] http://cedric.brun.io/graphical-textual-table-trees-its-your/
Best Regards.
> Lars
Esteban Dugueperoux - Obeo
Re: Minimal Runtime Configuration [message #1727210 is a reply to message #1726669] Mon, 21 March 2016 06:52 Go to previous messageGo to next message
Le 15/03/2016 15:55, Esteban Dugueperoux a écrit :
> Hi Lars,
> For details :
It looks like it is not really needed anymore. I have a patch pending
(https://git.eclipse.org/r/67965) which would remove it.
Re: Minimal Runtime Configuration [message #1727378 is a reply to message #1727210] Tue, 22 March 2016 10:25 Go to previous message
>> Hi Lars,
>> For details :
This is now merged and will be in Sirius 4.0M6. See
This one is now optional, see https://git.eclipse.org/r/#/c/68926/ (also
merged for 4.0M6).
There was already one actually: http://eclip.se/458751. See my comment
there for more details on the dependencies remaining.
Previous Topic:Retrieve the Node of an Element
Next Topic:Rename in EObject creates new Diagram
Current Time: Sat Jul 26 12:11:46 EDT 2025
Powered by FUDForum. Page generated in 0.04633 seconds
