Home » Modeling » OCL » Global operation for oclAny
Global operation for oclAny [message #1726348] Fri, 11 March 2016 11:33 Go to next message
Hi all,
while reading some of the last topics (e.g. 1, 2) I got the idea to play a little bit with operations inside an OCL file (not OCLinEcore).
My goal was define an operation which can be called on any OCLExpression, like e.g. oclIsUndefined can. Reading the others topics and using google was very helpful, but now I'm getting stucked at the following point:
import MyEcoreModel : 'MyEcoreModel.ecore#/'
import oclTypes : 'http://www.eclipse.org/ocl/1.1.0/OCL/Types'
context oclTypes::AnyType def: newGlobalOperation(arg : oclTypes::AnyType) : oclTypes::AnyType = null
package MyEcoreModel
context MyClass1
    inv test : self.newGlobalOperation(true)
endpackage
In the invariant test there is no operation "newGlobalOperation" available, I do not understand why. Adding the operation to the class directly as follows works:
context MyClass1
    inv test : self.newGlobalOperation()
endpackage
But there are two problems: First, the parameter/argument has been omitted and when I'm trying to add it, the invariant could not be parsed. Second, The newGlobalOperation is only available the MyClass1, but not for MyClass2.
Can anyone help me with this problem?
Nils
Re: Global operation for oclAny [message #1726350 is a reply to message #1726348] Fri, 11 March 2016 12:21 Go to previous messageGo to next message
There are two Eclipse OCL's.
The Classic Eclipse OCL supports an Ecore and a UML binding. It has a
number of limitations particularly in regard to extensibility.
'http://www.eclipse.org/ocl/1.1.0/OCL/Types' is the Library URI for the
Classic implementation.
The new Unified Pivot-based Eclipse OCL prototypes an extensible
UML-aligned implementation. It has an extensible library, with an Xtext
editor for it. It also has an Xtext editor for a Complete OCL document.
Using Complete OCL you can do something like
package ocl
context OCLExpression
def newGlobalOperation(arg : OclAny) : OclAny
But as I write this, I am really confused by your example. I don't see
why you use AnyType at all to define something for OCLExpression. It is
all at the wrong metalevel. You probably want to define
package ocl
context OclElement
def newGlobalOperation(arg : OclAny) : OclAny ...
since the Pivot-based OCL prototypes an OCL specification that
OclElement is the implicit supertype of all user-defined types (e.g.
MyClass1).
[OCL 2.0 had a special type called OclElement, but did not explain what
it was for and did not use it for anything. OCL 2.2 therefore removed
it. The Pivot-based OCL re-introduces it with a modeled definition. See
http://git.eclipse.org/c/ocl/org.eclipse.ocl.git/tree/plugins/org.eclipse.ocl.pivot/model/OCL-2.5.oclstdlib
Ed Willink
On 11/03/2016 16:33, Nils Przigoda wrote:
> Hi all,
> https://www.eclipse.org/forums/index.php/t/1074939/,
> https://www.eclipse.org/forums/index.php/t/1073767/) I got the idea to
> following point:
> context MyClass1
> endpackage
> context MyClass1
> inv test : self.newGlobalOperation() endpackage
> Regards,
> Nils
Re: Global operation for oclAny [message #1726424 is a reply to message #1726350] Sun, 13 March 2016 08:04 Go to previous messageGo to next message
Hi Ed,
thanks for your answer! I tried OCLExpression besides the AnyType, but OclElement was not coming into my mind, because I was only trying the classical OCL. However, with the following lines it does work for me in the OCL editor:
import ocl : 'http://www.eclipse.org/ocl/3.1.0/Pivot'
context ocl::OclElement def: newGlobalOperation(a : OclAny) : OclAny = null
context MyClass1
    inv test1 : self.newGlobalOperation(true)
context MyClass2
    inv test2 : self.newGlobalOperation(true)
endpackage
One problem is still existing, when I'm parsing the document, I'm getting an exception:
org.eclipse.ocl.SyntaxException: 2:1:2:53 "import ocl : 'http://www.eclipse.org/ocl/3.1.0/Pivot'" misplaced construct(s)
	at org.eclipse.ocl.util.OCLUtil.checkForErrors(OCLUtil.java:350)
	at org.eclipse.ocl.OCL.parse(OCL.java:317)
I'm sure that it means that have to organize an import of the OCL pivot file, but how can I do so?
Nils
Re: Global operation for oclAny [message #1726438 is a reply to message #1726424] Sun, 13 March 2016 11:41 Go to previous messageGo to next message
Try
import ocl : 'http://www.eclipse.org/ocl/2015/Pivot'
http://www.eclipse.org/ocl/3.1.0/Pivot is the pre-Mars nsURI before the
Pivot-based code was promoted from examples. I (or more likely lack of
time) decided against providing a backward migration.
Ed Willink
On 13/03/2016 12:04, Nils Przigoda wrote:
> Hi Ed,
> in the OCL editor:
> null
> context MyClass1
> context MyClass2
> endpackage
> Regards
> Nils
Re: Global operation for oclAny [message #1726441 is a reply to message #1726438] Sun, 13 March 2016 15:06 Go to previous messageGo to next message
I've just tried it with
in Eclipse Mars, and the errors is still the same.
Re: Global operation for oclAny [message #1726563 is a reply to message #1726441] Mon, 14 March 2016 12:42 Go to previous messageGo to next message
It works fine for me even with the old nsURI in Mars.2.
This is a waste of both our times. I should have insisted on a full
repro: See https://wiki.eclipse.org/OCL/ForumNetiquette
Ed Willink
Re: Global operation for oclAny [message #1727081 is a reply to message #1726348] Fri, 18 March 2016 13:22 Go to previous messageGo to next message
Here is zip-file of mini project where I re-produced the above mentioned exception with
Version: Mars.1 Release (4.5.1)
Build id: 20150924-1200
Please let me know what I'm doing wrong, thanks in advance!
Re: Global operation for oclAny [message #1727096 is a reply to message #1727081] Fri, 18 March 2016 17:36 Go to previous messageGo to next message
You are mixing Classic and Pivot OCL.
When you import org.eclipse.ocl.ecore you use the old Ecore Parser that
has no support for import statements; rather you need to magically load
the EPackage.Registry programmatically and install additional features
programmatically.
If you look in the documentation you will find the same example for OCL
parsing for both variants. If you want the newer moree flexioble
Pivt-based OCL then use it consistentluy.
Ed Willink
Re: Global operation for oclAny [message #1728934 is a reply to message #1727096] Fri, 08 April 2016 09:53 Go to previous messageGo to next message
Hi Ed, thanks a lot! I did not realized that I was mixing it. After playing a little bit I've now implemented your ideas (i.e. using OclElement) and updated the project configuration and code. However, there is still some unexpected behavior, at least to me. To make the example a bit more realistic, I tried to define an oclIsDefined method as global operation using the following line:
context ocl::OclElement def: oclIsDefined() : Boolean = null
But this does not work on a probably undefined Boolean attribute. For example, parsing the invariant
inv inv2 : self.boolAttr.oclIsDefined()
leads to
Constraint:	invariant inv2: self.boolAttr.oclBadOperation()
When adding an extra line in the OCL file
context ocl::Boolean def: oclIsDefined() : Boolean = null
this works.
I've attached a small project, where the error occurs.
I'm now asking myself: Why is OclElement not working on Booleans and also integers?
Re: Global operation for oclAny [message #1728953 is a reply to message #1728934] Fri, 08 April 2016 11:58 Go to previous messageGo to next message
The inheritance relationships are all modelled in
/org.eclipse.ocl.pivot/model/OCL-2.5.oclstdlib so that in the
Pivot-based OCL prototype for a future OCL.
OclAny is the root implicit supertype of everything (currently including
CollectionTypes).
OclElement is the implicit supertype of user-defined classes (i.e not
PrimitiveTypes)
OclType is the implicit supertype of types.
Ed Willink
> But this does not work on a probably undefined Boolean attribute. For example, parsing the invariant inv inv2 : self.boolAttr.oclIsDefined() leads to Constraint: invariant inv2: self.boolAttr.oclBadOperation()
> When adding an extra line in the OCL file context ocl::Boolean def: oclIsDefined() : Boolean = null this works.
Re: Global operation for oclAny [message #1728966 is a reply to message #1728953] Fri, 08 April 2016 13:19 Go to previous message
Thanks for the explanation, Ed! Changing OclElement it OclAny solved my problem!
Previous Topic:Computing derived attribute values with dynamic EMF
Next Topic:OCL git repository
Current Time: Wed Jul 23 15:37:00 EDT 2025
Powered by FUDForum. Page generated in 0.05206 seconds
