Home » Eclipse Projects » BPMN 2.0 Modeler » bindAttribute did not work in case of copy&pase
bindAttribute did not work in case of copy&pase [message #1726400] Sat, 12 March 2016 09:16 Go to next message
Hi Bob,
there is a strange behavior by my own implementation of a customTask element with a customPropertySection.
The customTask element implements a customPropertySection and binds a new attribute called 'processid'
public void createBindings(EObject be) {
setTitle("Workflow");
// ProcessID
this.bindAttribute(attributesComposite, be, "processid");
index.php/fa/25284/0/
In XML the task/attribute definition in bpmn looks like this:
<bpmn2:task id="Task_2" imixs:processid="6" name="Task 1">
So far, everything works.
When you now do a copy&past of this element the id-editor is not rendered (see screen2.png)
index.php/fa/25285/0/
Closing the editor and reopen it - everything works again fine.
This behavior exists since a long time. So I did not think it is related to latest changes in 1.2.3. I can't figure out what is wrong. I guess something in the implementation of the customTask element is wrong in general?
We have this public bpmn2-example code on github:
https://github.com/rsoika/bpmn2-tutorial
This is also the example code I used mainly for the developer tutorial in the wiki
https://wiki.eclipse.org/BPMN2-Modeler/DeveloperTutorials/CustomPropertyTabs
Maybe you can take a look at the example code of 'ProcessWorkflowPropertySection'
https://github.com/rsoika/bpmn2-tutorial/blob/master/bpmn2.tutorial.plugin/src/bpmn2/tutorial/ui/task/ProcessWorkflowPropertySection.java
I would update the tutorial code and also the wiki if you can give me a hint what's going wrong?
Ralph
  • Attachment: screen1.png
    (Size: 23.22KB, Downloaded 542 times)
  • Attachment: screen2.png
    (Size: 27.83KB, Downloaded 489 times)
Re: bindAttribute did not work in case of copy&pase [message #1726571 is a reply to message #1726400] Mon, 14 March 2016 13:36 Go to previous messageGo to next message
Hi Ralph,
Congratulations, you've found another bug Wink
This is actually caused by the Paste function in DefaultPasteBPMNElementFeature.copyEObject(T eObject). Normally when a new object is constructed (i.e. during loading, or creation through the tool palette) the object is passed through the ModelExtensionDescriptor which adds metadata to the ExtendedPropertiesAdapter for extension features (the "processId" in your case). This does not happen during the Paste operation because...well, I just forgot to handle it.
I have a patch that fixes this easily and with no obvious side-effects. At the end of copyEObject() just before the return t; add these lines:
		ExtendedPropertiesAdapter<T> oldAdapter = ExtendedPropertiesAdapter.adapt(eObject);
		ExtendedPropertiesAdapter<T> newAdapter = ExtendedPropertiesAdapter.adapt(result);
		for (EStructuralFeature oldFeature : oldAdapter.getExtensionFeatures()) {
			FeatureDescriptor fd = newAdapter.getFeatureDescriptor(oldFeature);
			fd.setProperty(ExtendedPropertiesAdapter.IS_EXTENSION_FEATURE, Boolean.TRUE);
Can you please file a bugzilla so we can track this bug?
Thanks!
Bob
Re: bindAttribute did not work in case of copy&pase [message #1726620 is a reply to message #1726571] Tue, 15 March 2016 03:40 Go to previous message
fine - I will do this.
Ralph
Previous Topic:v1.3.0: Strange Behavior of 'Edit Script Task'
Next Topic:New builds available for Mars and Luna
Current Time: Mon Jul 21 00:01:05 EDT 2025
Powered by FUDForum. Page generated in 0.03561 seconds
