Home » Eclipse Projects » NatTable » Cell decoration
Cell decoration [message #1726276] Thu, 10 March 2016 18:15 Go to next message
I've found here https://eclipse.org/nattable/documentation.php?page=editing (Text editor control decoration) an example how to use ControlDecoration with the editor of the cell. Can it be used with cells (cell is not a control, right? It's just painted on canvas)
What I want to do is a table validation, where cells with errors have such an error decorator at the corner of the cell with the tooltip on mouse hovering
Re: Cell decoration [message #1726328 is a reply to message #1726276] Fri, 11 March 2016 08:41 Go to previous messageGo to next message
Then you need to use a CellPainterDecorator and use that decorator painter in case your cell contains invalid data. Since that means you have a weak validation (because your data model can contain invalid data, which is not possible in case you have strict validation on editing), you need some additional configuration as explained in my blog post: http://blog.vogella.com/2013/03/02/crossweak-validation-in-nattable-by-dirk-fauth/
Re: Cell decoration [message #1726496 is a reply to message #1726328] Mon, 14 March 2016 06:11 Go to previous message
Thanks. And also I want to show error image at the CornerLayer, if errorrs in table are found.
I've add IConfigLabelAccumulator to CornerLayer and also there is IConfiguration with specific style with CellPainter. But I don't see any image at the corner (though in table cells with according label I can see image). And I've noticed that accumulateConfigLabels() of my corner ConfigLabelAccumulator is never called
Previous Topic:Programmatically sorting works only when column is visible
Next Topic: auto increment or copy cell values on dragging column
Current Time: Tue Jul 22 09:25:21 EDT 2025
Powered by FUDForum. Page generated in 2.14007 seconds
