How to generate binding (key) for a CompilationUnit? [100$ reward for solution] [message #1726164] |
Thu, 10 March 2016 04:14  |
Hi, I'm making ASTs for a whole project and I don't know how to generate bindings:
getDefaultParser().createASTs(files.toArray(new String[files.size()]), null, createBindings(files), fileAstRequestor, null);
private String[] createBindings(List<String> files)
String[] bindings = new String[files.size()];
for(int i = 0; i < files.size(); i++)
bindings[i] = createBinding(files.get(i));
return bindings;
private String createBinding(String file)
return file.replace(File.separatorChar, '.');
But how is that right? I see that here's a problem and I'm doing something wrong, because some of bindings are not resolved
UPD:
Anyone who will help me to resolve this problem will receive 100$ on his paypal
[Updated on: Fri, 18 March 2016 02:38] by Moderator
Re: How to generate binding for a CompilationUnit? [message #1726267 is a reply to message #1726164] |
Thu, 10 March 2016 15:22   |
Ok, so first, the bindingKeys parameter on createASTs() expects binding keys, not bindings. You are supplying file path names, and those are not binding keys. Second, you can't create binding keys, you can only safely use binding keys that you have gotten from an IBinding. (The algorithm is not published and can't be expected to remain constant between releases.) See JavaDoc for IBinding.getKey(). So the parser is not finding any of the "bindings" that you've specified. If any bindings are being resolved, they're being resolved simply by the normal actions of the parser. (Default parser resolves all of the bindings that it can.)
So, um, some bindings are not resolved. What can you share that will help narrow down that statement?
FUDForum. Page generated in 0.08209 seconds
