Home » Eclipse Projects » BPMN 2.0 Modeler » v1.3.0: Strange Behavior of 'Edit Script Task'(v1.3.0 / Edit Script Task)
v1.3.0: Strange Behavior of 'Edit Script Task' [message #1726148] Thu, 10 March 2016 02:43 Go to next message
Hello Colleagues,
I was curious about Neon & v1.3.0
When I Double Click a Script Task, a Dialog opens.
However, the Attributes shows that it would be opened, but nothing appears.
I have to Click the Attributes; now it shows that it is closed, so I have to Click it again to open it.
Thanks a lot,
-- Cs. Veg
  • Attachment: 1.png
    (Size: 8.21KB, Downloaded 207 times)
  • Attachment: 2.png
    (Size: 8.21KB, Downloaded 213 times)
Re: v1.3.0: Strange Behavior of 'Edit Script Task' [message #1726243 is a reply to message #1726148] Thu, 10 March 2016 12:08 Go to previous messageGo to next message
This should be fixed soon. If you have time, can you verify that this problem does not appear in the Mars version?
Re: v1.3.0: Strange Behavior of 'Edit Script Task' [message #1726247 is a reply to message #1726243] Thu, 10 March 2016 12:36 Go to previous message
Thank you very much!
eclipse4.6_M5_bpmn.1.3 -- SAME ERROR
eclipse4.5.2_bpmn.1.2.3 -- SAME ERROR
eclipse4.5.1_bpmn.1.2.2 -- OK
Previous Topic:Text box height of the Script field of Script Tasks
Next Topic:bindAttribute did not work in case of copy&pase
Current Time: Sun Aug 31 13:31:58 EDT 2025
Powered by FUDForum. Page generated in 0.03834 seconds
