Home » Modeling » TMF (Xtext) » Problem: Validator/Generator cannot navigate through AST/Index/ResourceSet from Unit-Tests(Xtext 2.9.1 UnitTest with ResourceSet)
Problem: Validator/Generator cannot navigate through AST/Index/ResourceSet from Unit-Tests [message #1725978] Tue, 08 March 2016 14:11 Go to next message
Hello *,
I would like to implement unit tests for mydsl. Specifically for the validator and the generators.
Both the Validator, and the generators query the index (ResourceSet) to objects in the AST - and find nothing. Why not? (Please see attached file).
In unit test I set up a ResourceSet of three models and can navigate through the AST also. However, the validator and the generators can not access the ResourceSet (or find anything).
Why is that?
The most important code snippets (for example ValidatorTest):
Unit-Test:
@RunWith(XtextRunner)
@InjectWith(MyDslInjectorProvider)
class MyDslValidatorTest {
	static val DATATYPES = '''
		datatypes {
			type Integer
			type String
			type Date
			type Timestamp
//	static val CONFIGURATION = '''
//		configuration ConfigX {
	@Inject extension ParseHelper<Model>
	@Inject extension ValidationTestHelper
	@Inject extension Provider<XtextResourceSet>
	var resourceSet = null as XtextResourceSet
	@Before
	def void setup() {
		resourceSet = get
		resourceSet.classpathURIContext = this
		DATATYPES.parse(URI.createURI("datatypes.mydsl"), resourceSet)
		// TESTCASE: no config should raise an error in MyDslValidator
		// val config = resourceSet.createResource(URI.createURI("config.mydsl"))
		// config.load(new StringInputStream(CONFIGURATION), emptyMap)
	@Test
	def testCheckConfiguration() {
		val model = '''
			package foo.bar
			entity MyEntity
				ValidFrom : Timestamp
		'''.parse(URI.createURI("model.mydsl"), resourceSet)
		model.assertError(MyDslPackage.Literals.MODEL, 'ERR-CODE-0815')
Validator:
	@Inject extension ResourceExtension
	@Check
	def checkConfiguration(Model it) {
		if (eResource.allConfigurations.nullOrEmpty) {
			error("no config? no cookies!", MyDslPackage.Literals.MODEL__PACKAGE, 'ERR-CODE-0815')
What's wrong in my example? *headscratch*
Please - help ;-)
Tobias
Re: Problem: Validator/Generator cannot navigate through AST/Index/ResourceSet from Unit-Tests [message #1725981 is a reply to message #1725978] Tue, 08 March 2016 14:51 Go to previous messageGo to next message
the problem is that validators silently catch errors.
if you catch for exceptions you will get
	at org.eclipse.xtext.resource.impl.ResourceSetBasedResourceDescriptions.getResourceDescription(ResourceSetBasedResourceDescriptions.java:111)
	at org.xtext.example.mydsl.extensions.ResourceExtension.getAllResourceDescriptions(ResourceExtension.java:41)
	at org.xtext.example.mydsl.extensions.ResourceExtension.getAllObjectDescriptions(ResourceExtension.java:54)
	at org.xtext.example.mydsl.extensions.ResourceExtension.getAllConfigurations(ResourceExtension.java:63)
	at org.xtext.example.mydsl.validation.MyDslValidator.checkConfiguration(MyDslValidator.java:36)
so the problem is your impl of the resourceextensions
class ResourceExtension {
	@Inject ResourceDescriptionsProvider indexProvider
	@Inject IResourceServiceProvider.Registry registery
	private def IContainer.Manager getManager(Resource it) {
		registery.getResourceServiceProvider(URI).containerManager;
	private def getAllResourceDescriptions(Resource it) {
		val index = indexProvider.getResourceDescriptions(it)
		val resourceDescByURI =  index.getResourceDescription(URI)
		manager.getVisibleContainers(resourceDescByURI, index).map[resourceDescriptions].flatten
(alternatively call iresourcedescriptions.setContext manually)
Re: Problem: Validator/Generator cannot navigate through AST/Index/ResourceSet from Unit-Tests [message #1725983 is a reply to message #1725981] Tue, 08 March 2016 15:10 Go to previous message
Hello Christian,
thank you for your fast reply!
Your solution works fine!
...and Exception Handling in Validator is a good point.
Tobias
Previous Topic:[SOLVED] Resolve cross references from a different DSL during Maven build
Next Topic:Standalone command-line compiler
Current Time: Mon Jul 21 06:12:12 EDT 2025
Powered by FUDForum. Page generated in 0.05060 seconds
