Re: [EMF Forms] nested attributes in table control [message #1725963 is a reply to message #1725951] |
Tue, 08 March 2016 11:16  |
Hi Martin,
I see what you want.
No currently multilists are not supported by emfforms, but you can add custom support for this.
You will need to implement your own DMR.
In order to do so you need to create a custom DMR that extends the VFeaturePathDomainModelReference (you can also extend the VDomainModelReference if you like, but the VFeaturePathDomainModelReference has already all the fields you need).
You will then have to provide an own DomainModelReferenceConverterEMF (this is an osgi service) . There you can implement the convertToListProperty() method.
This will be enough to support your requirement.
What I can't guarantee right now is whether the table will be able to handle this use case or not, as we never tested this.
I can provide you more info if you like. We also are happy to accept a contribution for this.
Eugen
FUDForum. Page generated in 0.03568 seconds
