Home » Eclipse Projects » WindowBuilder » JEP 223: New Version-String Scheme - Window Builder not working
JEP 223: New Version-String Scheme - Window Builder not working [message #1725405] Thu, 03 March 2016 05:20
Ubuntu 15.10 64bit, java 32bit JDK-9 and Eclipse Mars 2 32bit ( Mars 1 incompatible with JDK-9 > 24.12.2015 )
Window builder has problem with recognition JDK-9 ( the same problem had Mars 1 but Mars 2 working OK ), design page warning:
Eclipse is running under 0, but
this Java project has a 1.7 Java compliance level, so will not be able to load classes
from this project. Use a lower level of Java for the project, or run Eclipse using a newer Java
version.
Best regards
Krzysztof
Previous Topic:Catch drop events into WB editor from other views
Next Topic:Subclasses of Swing Designer Wizards
Current Time: Sun Jul 20 22:32:07 EDT 2025
Powered by FUDForum. Page generated in 0.27622 seconds
