Home » Modeling » GMF (Graphical Modeling Framework) » Adding menu to the palette
Adding menu to the palette [message #1071223] Fri, 19 July 2013 11:31 Go to next message
Hi everyone,
I am trying to add items to a palette of my gmf application.
I created a diagram editor that extends the DiagramDocumentEditor and I've already dinamically customized my palette modifying my PaletteFactory instantiated into createPaletteRoot method.
Anyway I would like to add something different, for istance a main menu or a tool menu to the palette but i don't understand how to do that.
Should i use PaletteViewerProvider ? Is that possible to add a menu or even other widgets to the palette ?
please any suggestions are welcome.
thanks,
Luca.
Re: Adding menu to the palette [message #1072419 is a reply to message #1071223] Mon, 22 July 2013 14:12 Go to previous messageGo to next message
what do you mean by menu? A context menu? A Drawer?
Ralph
Re: Adding menu to the palette [message #1072610 is a reply to message #1072419] Tue, 23 July 2013 02:28 Go to previous messageGo to next message
Hi Ralph,
what I mean it is not a context menu, I would like to add a main menu to the palette if it is possible or something into the the top of it. I need it to have the possibility to let the user select new items to add to the palette.
When my palette it is automatic generated I can see, there are the selection entry, zoom indicator and a menu item to add note, text or note attachment placed at the top of it.
Is it possible to add something else just at the same position ?
thanks,
Luca.
Re: Adding menu to the palette [message #1073652 is a reply to message #1072610] Thu, 25 July 2013 04:40 Go to previous messageGo to next message
Does anyone have any suggestions ?
Please I really got stuck at this point.
I am able to add PaletteContainer, PaletteDrawer, PaletteEntry,PaletteSeparator, PaletteGroup to the PaletteRoot but I do not know how to add a menu or a toolbar to it. Is it possible ?
Luca.
Re: Adding menu to the palette [message #1725258 is a reply to message #1073652] Wed, 02 March 2016 02:53 Go to previous message
Hi Luca,
Could you explain about how to add PaletteDrawer, PaletteEntry to paletteRoot, programmatically?
I also want to listen when User select a entry from PaletteRoot.
Nhan
Luca Salemio wrote on Thu, 25 July 2013 08:40
Luca.
Previous Topic:Links does not get deleted from the model
Next Topic:Scalable Polygon Line Style changing
Current Time: Sat Aug 30 21:33:27 EDT 2025
Powered by FUDForum. Page generated in 0.03058 seconds
