Re: Raspberry Pi 2 B FlipFlop Tutorial [message #1778421 is a reply to message #1770211] |
Thu, 14 December 2017 01:45   |
Hello members!
I follow this link: "https://www.eclipse.org/4diac/documentation/html/installation/raspi.html"
While building forte for Rasberrypi3 model B I following step mentioned in Building FORTE on the RPI-> Preparing then 2)Building .
While building forte on rasberrypi, after running "make", two warning appears
1) Warning: the program should also define "void operator delete[](void*, std::size_t)"
2) Waring: conversion to 'TfroteFloat {aka float}' from 'CIEC_DWORD::TValueType {aka unsigned int}' may alter value. At "if ( CIEC_DWORD::scm_nMaxVal < pa_roVal) {
However, forte exe has been genrated after these two warning multiple time in b"in/posix/src directory".
Now I using 4DIAC IDE 1.8.4, on win7 after installation of jdk 1.8.
I write blink test program in 4DIAC, it do everything fine, and output is exactly like mentioned in attachments of first post of Awais Tanveer: message #1770065.
Please note that i didnot complete cross compilation steps. I just run forte exe on rasberrypi, then using 4DIAC, download blink test program on rasberrypi.local:61499.
Please guide! urgent response please.
FUDForum. Page generated in 0.83265 seconds
