Home » Newcomers » Newcomers » Package Presentation -> Hierarchical preference not saving(Eclipse MARS doesn't save preferences details)
Package Presentation -> Hierarchical preference not saving [message #1725176] Tue, 01 March 2016 06:38 Go to next message
I'm experiencing some problem saving the package presentation type as Hierarchical on Eclipse Mars:
Version: Mars.1 Release (4.5.1)
Build id: 20150924-1200
Operating System: Windows 7 Professional x64
Please ask if more details are needed.
Re: Package Presentation -> Hierarchical preference not saving [message #1725180 is a reply to message #1725176] Tue, 01 March 2016 07:03 Go to previous messageGo to next message
"Some problem" could mean anything whatsoever. Please describe the
steps that I would need to follow in order to reproduce the problem that
you seem to be seeing.
On 01.03.2016 12:38, Flavio B wrote:
> Hello,
Re: Package Presentation -> Hierarchical preference not saving [message #1725198 is a reply to message #1725180] Tue, 01 March 2016 09:56 Go to previous messageGo to next message
OK, sorry.
You are right.
Well, premise that this bug seems to not be present on another machine I am using (Linux) and another one with Windows 7 Pro, this happens in the installation I am currently using:
Steps to reproduce:
1) Open Eclipse starting C:\Program Files\eclipse\eclipse.exe
2) Switch to JavaEE perspective if not already opened
3) Open Package Explorer
4) Click on the Vew Menu -> Package Presentation -> Hierarchical
index.php/fa/25150/0/
5) See the effects of this change (OK)
6) Close Eclipse
7) Open Eclipse
8 ) Package presentation is reset to Flat in Package Explorer and Step 4 has to be repeated
Re: Package Presentation -> Hierarchical preference not saving [message #1725715 is a reply to message #1725198] Mon, 07 March 2016 04:20 Go to previous messageGo to next message
UP
Ed Merks: was I precise enough with the problem description?
If not, please let me know if I can do better. The problem still persists.
Re: Package Presentation -> Hierarchical preference not saving [message #1725901 is a reply to message #1725715] Tue, 08 March 2016 07:20 Go to previous messageGo to next message
Flavio,
That settings is stored in the dialog settings in the workspace. I.e.,
in
<workspace>/.metadata/.plugins/org.eclipse.jdt.ui/dialog_settings.xml.
Is that file updated when you change the layout? Presumably you are
opening the IDE with the same workspace, otherwise it will be just the
default or whatever is saved for that workspace.
On 07.03.2016 10:20, Flavio B wrote:
> UP
> persists.
Re: Package Presentation -&amp;gt; Hierarchical preference not saving [message #1725909 is a reply to message #1725901] Tue, 08 March 2016 08:30 Go to previous messageGo to next message
Hi!
thanks a lot for replying.
The file you mentioned looks like it's being modified when I start Eclipse, before selecting the workspace (it's weird).
I don't find exactly what is the relevant part and the settings to be checked, but I see there's no change stored on shutdown or when I select the hierarchical package presentation (basically the xml file I opened with an external editor does not get reloaded by the editor since it doesn't detect any change).
I think this is the relevant part:
<section name="org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart">
</section>
I'm not sure what I have to check to find out if the setting has been stored or not.
Re: Package Presentation -&amp;amp;gt; Hierarchical preference not saving [message #1726421 is a reply to message #1725909] Sun, 13 March 2016 07:04 Go to previous messageGo to next message
When I shutdown, the value changes. I.e, if I switch to hierarchical,
it changes to this:
<item value="1" key="layout"/>
So if you don't see it changing when you shutdown (and the dialog
settings should be flushed), then likely there's a shutdown problem of
some sort preventing that from being saved.
You could try showing the Error Log view, clearing it, and seeing if
there are problems logged when you shutdown and restart.
On 08.03.2016 14:30, Flavio B wrote:
> Hi!
> <section
> </section>
> stored or not.
Re: Package Presentation -&amp;amp;gt; Hierarchical preference not saving [message #1726426 is a reply to message #1726421] Sun, 13 March 2016 09:08 Go to previous messageGo to next message
Hi!
I've checked the value <item value="1" key="layout"/> and I see it was already set like that.
It doesn't change whenever I change the package presentation option. I've also made sure to have all the RW permissions on the eclipse directory, and it is OK.
As regard the Error Log view, it doesn't say anything when I change the package presentation.
Re: Package Presentation -&amp;amp;amp;gt; Hierarchical preference not saving [message #1726429 is a reply to message #1726426] Sun, 13 March 2016 09:31 Go to previous messageGo to next message
Flavio,
Comments below.
On 13.03.2016 14:08, Flavio B wrote:
> Hi!
And it stays that way? And it's in the workspace you're opening? You
mentioned something about it being changed. If you change the setting
to flat and quit, does this value change to 2?
As I mentioned, it's apparently saved on shutdown. So try to confirm
that changing it saves changes on shutdown. You can of course try to
change it in the file before you restart to see if that has the expected
impact.
You are looking in the workspace directory, correct?
Again, I mentioned clearing the error log, shutting down, and looking
again when you've restarted.
I think at this point you have all the information you need because
there's nothing else I can tell you to try. Ensure that you're
really looking at the file for the workspace you're opening and
closing. Ensure that the file really changes when you shutdown. If it
doesn't try changing it manually to confirm that this setting really
does have an impact on what you see in the package explore. For me all
those things work as expected.
Re: Package Presentation -&amp;amp;amp;gt; Hierarchical preference not saving [message #1726433 is a reply to message #1726429] Sun, 13 March 2016 10:07 Go to previous messageGo to next message
Wait!
This time I've seen the value has changed to:
<item value="2" key="layout"/>
I tried to change that value to 1 before starting ecplise but nothing changes: still flat view.
I noticed only the following error as regard "ui":
eclipse.buildId=4.5.2.M20160212-1500
java.version=1.7.0_80
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_GB
Framework arguments:  -product org.eclipse.epp.package.jee.product
Command-line arguments:  -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
org.eclipse.egit.ui
Warning
Sun Mar 13 15:04:33 CET 2016
Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: 'C:\Users\fbcyborg'. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
I don't think that could cause the issue I am facing with.
Re: Package Presentation -&amp;amp;amp;amp;gt; Hierarchical preference not saving [message #1726437 is a reply to message #1726433] Sun, 13 March 2016 11:39 Go to previous messageGo to next message
I get the feeling you're telling me contradictory things. Sometimes the
value doesn't change, sometimes it does, sometimes it's changed when
you start, and always the value has no impact when you start. These
things aren't consistent.
On 13.03.2016 15:07, Flavio FB wrote:
> Wait!
> java.vendor=Oracle Corporation
> org.eclipse.egit.ui
> Warning
> options.
Re: Package Presentation -&amp;amp;amp;amp;gt; Hierarchical preference not saving [message #1726442 is a reply to message #1726437] Sun, 13 March 2016 15:07 Go to previous messageGo to next message
yes, I understand your perplexity, I'm sorry for not being so precise.
Anyway, yes... this is my impression: the value has no impact when you start. I double checked the setting file being used (the one of the workspace I am using).
Today it was the first time I noticed that value changing, but it looks like it doesn't work.
These are the steps I am trying to reproduce:
1) Open .metadata\.plugins\org.eclipse.jdt.ui\dialog_settings.xml
2) check the following initial situation:
</section>
3) Open Eclipse
4) Package presentation is: Flat
5) Change Package presentation to: Hierarchical
6) <item value="1" key="layout"/> is unchanged
7) Close Eclipse
8 ) <item value="1" key="layout"/> is unchanged
9) Open Eclipse: value unchanged
10) Repeat step 6
11) Close Eclipse and the value is still unchanged
This is really weird... the value doesn't change anymore! The file is changing anyway when Eclipse is closed, but it's not related to the part we are talking about. Differences are just related to some piece of XML moved up or down.
Thanks for your support.
[Updated on: Sun, 13 March 2016 15:08] by Moderator
Re: Package Presentation -&amp;amp;amp;amp;amp;gt; Hierarchical preference not saving [message #1726460 is a reply to message #1726442] Mon, 14 March 2016 02:47 Go to previous messageGo to next message
Comments below.
On 13.03.2016 20:07, Flavio FB wrote:
> start.
That's not what I see. This leads me to the impression that the file
you're looking at on disk is not really the workspace being used by Eclipse.
> I am using). Today it was the first time I noticed that value
So you talk about the value changing, but the steps below describe them
not changing. That may be, but that means something during shutdown is
failing to save the change.
But then you also claim the value in the file has no impact when you
start up. I doubt that. Then there's also a problem reading the
file. If Eclipse can't read nor write the file, that suggests a
permissions problem.
> <section
> </section>
> 3) Open Eclipse
> 7) Close Eclipse
> 8) <item value="1" key="layout"/> is unchanged
> 10) Repeat step 6
Of course the detail we've been talking about is some piece of XML.
Try the following. Create a new workspace. Note where it is and make
sure that's the one Eclipse is opening. Try the experiment with that.
Copy the *.xml so you have a before and after version you can compare.
Try changing several things such as the top level between project and
workingset and the presentation between flat and hierarchical. Compare
the copied *.xml to see what's changing.
Re: Package Presentation -&amp;amp;amp;amp;amp;gt; Hierarchical preference not saving [message #1726511 is a reply to message #1726460] Mon, 14 March 2016 07:34 Go to previous message
OK,
Here's the XML file content that is created after the following steps:
1) open Eclipse
2) select a path for a new workspace
3) Switch to hierarchical package presentation
4) close eclipse
The file is being created when eclipse closes:
<section name="Workbench">
		<item value="true" key="group_libraries"/>
		<item value="false" key="linkWithEditor"/>
		<item value="1" key="rootMode"/>
		<item value="&lt;?xml version=&quot;1.0&quot; encoding=&quot;UTF-8&quot;?&gt;&#x0D;&#x0A;&lt;packageExplorer group_libraries=&quot;1&quot; layout=&quot;1&quot; linkWithEditor=&quot;0&quot; rootMode=&quot;1&quot; workingSetName=&quot;Aggregate for window 1457954723050&quot;&gt;&#x0D;&#x0A;&lt;customFilters userDefinedPatternsEnabled=&quot;false&quot;&gt;&#x0D;&#x0A;&lt;xmlDefinedFilters&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.ui.PackageExplorer.LibraryFilter&quot; isEnabled=&quot;false&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.ajdt.javamodel.CompilationUnitFilter&quot; isEnabled=&quot;true&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.ajdt.ui.editor.outline.PointcutFilter&quot; isEnabled=&quot;false&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.ui.PackageExplorer.CuAndClassFileFilter&quot; isEnabled=&quot;false&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.pde.ui.ExternalPluginLibrariesFilter1&quot; isEnabled=&quot;true&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;_patternFilterId_*.ajsym&quot; isEnabled=&quot;true&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.ui.PackageExplorer_patternFilterId_RemoteSystemsConnections&quot; isEnabled=&quot;true&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.ui.PackageExplorer.FieldsFilter&quot; isEnabled=&quot;false&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.ajdt.ui.editor.outline.IntroductionFilter&quot; isEnabled=&quot;false&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.internal.ui.PackageExplorer.HideInnerClassFilesFilter&quot; isEnabled=&quot;true&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.ui.PackageExplorer.NonPublicFilter&quot; isEnabled=&quot;false&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.ajdt.ui.editor.outline.AdviceFilter&quot; isEnabled=&quot;false&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.pde.ui.BinaryProjectFilter1&quot; isEnabled=&quot;false&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.mylyn.java.ui.MembersFilter&quot; isEnabled=&quot;false&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.ui.PackageExplorer.LocalTypesFilter&quot; isEnabled=&quot;false&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.ui.PackageExplorer.StaticsFilter&quot; isEnabled=&quot;false&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.ui.PackageExplorer.ContainedLibraryFilter&quot; isEnabled=&quot;false&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.ui.PackageExplorer.NonJavaElementFilter&quot; isEnabled=&quot;false&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.ui.PackageExplorer.NonSharedProjectsFilter&quot; isEnabled=&quot;false&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.ui.PackageExplorer.ClosedProjectsFilter&quot; isEnabled=&quot;false&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.ui.PackageExplorer.NonJavaProjectsFilter&quot; isEnabled=&quot;false&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.ui.PackageExplorer_patternFilterId_*_Roo_*.aj&quot; isEnabled=&quot;true&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.ui.PackageExplorer.PackageDeclarationFilter&quot; isEnabled=&quot;true&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.internal.ui.PackageExplorer.EmptyInnerPackageFilter&quot; isEnabled=&quot;true&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.ajdt.ui.editor.outline.DeclarationFilter&quot; isEnabled=&quot;false&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.internal.ui.PackageExplorer.EmptyPackageFilter&quot; isEnabled=&quot;false&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.ui.PackageExplorer.ImportDeclarationFilter&quot; isEnabled=&quot;true&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.ui.PackageExplorer_patternFilterId_.*&quot; isEnabled=&quot;true&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.ui.PackageExplorer.EmptyLibraryContainerFilter&quot; isEnabled=&quot;true&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.ui.PackageExplorer_patternFilterId_RemoteSystemsTempFiles&quot; isEnabled=&quot;true&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.jdt.ui.PackageExplorer.SyntheticMembersFilter&quot; isEnabled=&quot;true&quot;/&gt;&#x0D;&#x0A;&lt;child filterId=&quot;org.eclipse.m2e.MavenModuleFilter&quot; isEnabled=&quot;false&quot;/&gt;&#x0D;&#x0A;&lt;/xmlDefinedFilters&gt;&#x0D;&#x0A;&lt;/customFilters&gt;&#x0D;&#x0A;&lt;/packageExplorer&gt;" key="memento"/>
	</section>
	<section name="JavaElementSearchActions">
	</section>
	<section name="NewPackageWizardPage">
		<item value="false" key="create_package_info_java"/>
	</section>
</section>
The value is set to 1 when it should be 2: <item value="1" key="layout"/>
Anyway, opening the workspace again the package presentation is Hierarchical as expected. I think there's no write permission problems on the other workspace, since the file is being modified every time.
This is really weird!
Previous Topic:Create standalone for Eclipse application.
Next Topic:toolbar buttons
Current Time: Sat Jul 26 21:50:41 EDT 2025
Powered by FUDForum. Page generated in 0.31039 seconds
