Home » Eclipse Projects » Oomph » Apply setup to workspace
Apply setup to workspace [message #1724006] Fri, 19 February 2016 11:44 Go to next message
Hi anybody,
I want to place somewhere in git setups, that can be used by other developers in our company.
Can you please tell me how I can apply these .setup files to a new created workspace?
Thanks in advance
Cheers
Markus
[Updated on: Fri, 19 February 2016 12:41] by Moderator
Re: Apply setup to workspace [message #1724034 is a reply to message #1724006] Sat, 20 February 2016 00:31 Go to previous messageGo to next message
Hi Markus,
Your (project) setup files must be included in some (project) catalog. Either you maintain your own catalog or you
logically add it to an existing catalog as a "user project". Use the green plus button on the Projects page of the
advanced installer or in the "Projects Into Workspace" import wizard. From either of these facilities you can also
"connect" your workspace to these project setups.
Cheers
/Eike
http://www.esc-net.de
Am 19.02.2016 um 17:44 schrieb Markus Oley:
> Hi anybody,
> I want to place somewhere in git setups, that can be used by other developers in our company. Can you please tell mw
> who I can apply these .setup files to a new created workspace?
> Thanks in advance
> Cheers
> Markus
Re: Apply setup to workspace [message #1724042 is a reply to message #1724034] Sat, 20 February 2016 02:30 Go to previous messageGo to next message
Hi Eike,
thank you I will try
Re: Apply setup to workspace [message #1724768 is a reply to message #1724034] Thu, 25 February 2016 15:13 Go to previous messageGo to next message
Hi Eike,
can you give me a docu link to how I can manage my own product catalog without going via eclipse.org or github?
Thank you
Cheers
Markus
Re: Apply setup to workspace [message #1724796 is a reply to message #1724768] Fri, 26 February 2016 01:54 Go to previous messageGo to next message
Am 25.02.2016 um 21:13 schrieb Markus Oley:
> Hi Eike,
Please start here: https://wiki.eclipse.org/Eclipse_Oomph_Authoring#Hosting_your_own_index_.2F_catalogs
I think this forum has a few more threads about this topic, too.
Cheers
/Eike
Re: Apply setup to workspace [message #1724868 is a reply to message #1724796] Fri, 26 February 2016 11:12 Go to previous messageGo to next message
Hi Eike,
thanks for your post.
I really want to use oomph, because I think it's a good idea and could ease the life of our developers a lot.
I read it and have to admit that it seems to me really complicated to do, what I want to do. I want to get certain kinds of configuration (especially p2 actions) to our developer and don't think I can get them something done with mapping and so on...
So I searched a little bit further and found https://timdelbruegger.wordpress.com/2015/08/16/automating-project-specific-eclipse-setups-with-oomph/ which seems to me a little bit simpler, but I have the problem that the installer doesn't work good for me, because I live behind a proxy and even after configuring the proxy I get exceptions (NullPointerException)....
I found that there are three locations (workspace, installation and user) where these configurations are located. So I tried to add a snippet of xml myself into one of these locations:
<setupTask
      xsi:type="setup:EclipseIniTask"
      option="-Xmx"
      value="1024m"
      vm="true">
    <description>Set the heap space needed to work with the projects of modeling</description>
  </setupTask>
  <setupTask
      xsi:type="setup.p2:P2Task">
    <requirement
        name="org.eclipse.xtext.sdk.feature.group"
        versionRange="[2.9.0,2.9.99]"/>
    <repository       url="http://download.eclipse.org/modeling/tmf/xtext/updates/releases/2.9.0/"/>
    <description>Install the tools needed in the IDE to work with the source code for modeling</description>
  </setupTask>
whereas the first task was configured (memory) but the second one was removed from these locations after starting workspace and Performing setup tasks...
Can you tell me if I mustn't edit these files by myself or do I have an invalid xml snippet?
Cheers
Markus
Re: Apply setup to workspace [message #1724873 is a reply to message #1724868] Fri, 26 February 2016 11:55 Go to previous messageGo to next message
Am 26.02.2016 um 17:12 schrieb Markus Oley:
> Hi Eike,
> thanks for your post. I really want to use oomph, because I think it's a good idea and could ease the life of our
> developers a lot.
Sorry, I don't understand this.
It should work behind proxies. If it doesn't, it would be good to find out why not and how it can be fixed.
Unfortunately Ed and I can hardly test this because we don't work behind such proxies. The other day I found
https://wiki.eclipse.org/Disabling_Apache_Httpclient and I wonder if that helps?
> <setupTask
> option="-Xmx"
> value="1024m"
> vm="true">
> </setupTask>
> <setupTask
> <requirement
> </setupTask>
What do you mean by "removed"? Removed from where exactly?
That's okay.
The ones you showed look okay to me.
Cheers
/Eike
Re: Apply setup to workspace [message #1725017 is a reply to message #1724873] Mon, 29 February 2016 02:45 Go to previous messageGo to next message
[quote title=Eike Stepper wrote on Fri, 26 February 2016 17:55]Am 26.02.2016 um 17:12 schrieb Markus Oley:
OK, rereading my last post I guess it's written a little bit unclear.... Let's replay the docu in my own words: If I want to provide configurations to my projects I have to provide some kind of mapping, which I have to configure via system property in eclipse.ini. Everyone, who wants to use my project configurations has to also provide the mapping in his eclipse.ini, which I think is complicated. For me it would be nice, If I had the possibility to store the project wide configurations on a remote location (like in the git project or on an ftp server....) and to drag and drop it into an existing workspace or the configurations be automatically loaded if I open a project, that has configurations in a dedicated location (e.g. .project). I must admit that I did not understand what the mapping is for....
>It should work behind proxies. If it doesn't, it would be good to find out >why not and how it can be fixed.
>Unfortunately Ed and I can hardly test this because we don't work behind >such proxies. The other day I found
>https://wiki.eclipse.org/Disabling_Apache_Httpclient and I >wonder if that helps?
OK, thank you for your link, I will give it a try. I have tried to reproduce the NullPointer last Friday, but unfortunately the exception did not appear again. But I will contribute a bug report next time I see it....
>> tried to add a snippet of xml myself into one of these locations:.....
After clicking "Perform Setup Tasks..." this configuration was removed for example from the workspace.setup file...
>That's okay.
So could you imagine that if providing a feature like shown above (drag and drop a setup into eclipse) could get an official oomph feature? If yes, I could imagine to try to implement it and send as pull-request
Re: Apply setup to workspace [message #1725169 is a reply to message #1725017] Tue, 01 March 2016 05:53 Go to previous messageGo to next message
Markus,
This is a very long thread. And I'm a little confused about what
exactly is the focal point... The thread started with project
configurations and transformed into product catalogs at some point. I'll
try to address your commentary further inline below.
I'm not sure I follow this. Generally it's easy to share a project
setup by dragging and dropping it into one of the existing catalogs...
More advanced designers may want to maintain there own catalogs, but few
people do that...
Sorry, I'm not sure I know what mapping you mean. Generally project
setups should be available via an URL and that must be added to a
catalog once....
> for....
Yes, that's generally what should be working now. Commonly one uses a
raw view of a repository. I.e., if Oomph's setup wasn't already in the
catalog, one could drag and drop this link into the Eclipse.org project
catalog.
http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/Oomph.setup
>> find out >why not and how it can be fixed. Unfortunately Ed and I can
>> other day I found
>> that helps?
> see it....
What specifically is changed? Broken proxies are removed, is that the
problem?
>> That's okay.
> pull-request
But that's already working, so there must be some terminology issue.
One thing that I talked to recently with a customer is some type of
drag-and-drop support whereby one could provide a complete description
of all the selections one would make manually in the installer to
automate those steps...
Re: Apply setup to workspace [message #1725235 is a reply to message #1725169] Tue, 01 March 2016 17:08 Go to previous messageGo to next message
Hi Ed,
thanks for your post, answers below...
>More advanced designers may want to maintain there own catalogs, but >few
>people do that...
We have both plugins from eclipse ecosystem or third party plugins (such as anyedit), which we want to use, and two custom plugins, which handle modeling our persistence and masks with xtext. So these things we are not allowed to share with the outside world. So dragging and dropping it into one of the existing catalogs means sharing it on eclipse.org or github? If so, this is not possible for us.
>catalog once....
I mean the mapping shown in https://wiki.eclipse.org/Eclipse_Oomph_Authoring#Hosting_your_own_index_.2F_catalogs.
>> for....
>catalog.
Were can I drop it to? In the installer or in an already installed eclipse? Because this would be interesting not only at the point when I start the installation, but also later on, when I already have the eclipse instance running and some provides me further configurations which I should apply to my project. If this already is working, can you please give a hint were it is documented?
>problem?
As I have mentioned, I tried to configure p2 repositores and plugins, which should be installed. Unfortunately I didn't get any error messages or exceptions, so I cannot say if it was due to an proxy that was not configured well, but I will retry.
>> pull-request
Yes, probably it is.
So I will retry merging my configuration into the workspace.setup and will previously take a look at the proxy. And it would be nice if you could answer at least the thing if it is possible dragging and dropping configuration to eclipse ( not to the installer).
Thanks for your effort.
Cheers
Markus
Re: Apply setup to workspace [message #1725280 is a reply to message #1725235] Wed, 02 March 2016 04:07 Go to previous message
Markus,
Comments below.
On 01.03.2016 23:08, Markus Oley wrote:
> Hi Ed, thanks for your post, answers below...
>> catalogs... More advanced designers may want to maintain there own
>> catalogs, but >few people do that...
No, such extensions to the catalogs are maintained locally. They things
are only "virtually" in the index.
>> catalog once....
Well, if you host your own index, you should expect users to use your
stuff exclusively, and in that case you can ensure that all things you
install will include the redirections needed so that those installations
also refer to your index.
>>> mapping is for....
>> a raw view of a repository. I.e., if Oomph's setup wasn't already in
>> the catalog, one could drag and drop this link into the Eclipse.org
>> project catalog.
> eclipse?
Into the installer dialog or the project importer. I.e., in those
places where you see the green + and red - which do the same thing only
without drag and drop. Drag and drop often work poorly on Linux and Mac
because there is no proper feedback mechanism at the OS level during the
drag operation; only at drop time can you validate that what's being
dropped is sensible or not...
The + button on the project page supports this. Here you can provide a
link to a project setup.
>> the problem?
Certainly you'll need to run under debug control to get a sense of what
is going wrong...
>>> pull-request
Yes, project setups can be added to a project catalog in the project
import wizard.
> Thanks for your effort. Cheers
> Markus
Previous Topic:SetupTask with filter
Next Topic:setup tasks not started
Current Time: Sun Jul 27 14:33:55 EDT 2025
Powered by FUDForum. Page generated in 0.07881 seconds
