Sirius runtime as standalone applicatio (rcp?) [message #1725088] |
Mon, 29 February 2016 10:48  |
I made Sirius Tutorials with Family model and now I would like to make standalone runtime application.
Is there any way to run sirius application from tutorial in standalone (not by runing one Eclipse and there run another Eclipse instance with application)?
Re: Sirius runtime as standalone applicatio (rcp?) [message #1725934 is a reply to message #1725088] |
Tue, 08 March 2016 09:52   |
> application)?
It depends on what you mean by "standalone".
Sirius modelers are plain Eclipse plug-ins with no specific build
requirements, so they can be built/packaged, published and then
installed in an existing Eclipse installation using the same tools and
techniques as any other Eclipse plug-ins (the details go beyond the
scope of this forum).
If you want a "ready-to-use" executable product with your modeler
already installed, this is possible too, but requires creating an
Eclipse product. Again, nothing Sirius-specific here, but you can find a
concrete example at https://github.com/ObeoNetwork/UML-Designer.
By default the resulting product will very much look like a "classic"
Eclipse IDE with Sirius and you modeler pre-installed. If you want to
streamline the UI to hide the most scary parts from your end-users, it's
also possible, but only in part and require more work.
https://github.com/mbats/arduino is an example of such a simplified UI.
Underneath there's a full Eclipse and Sirius running, but a lot of it is
hidden (see
https://github.com/mbats/arduino/wiki/Tutorial-:-How-to-create-a-new-project-%3F
for example).
Pierre-Charles
Pierre-Charles David - Obeo
FUDForum. Page generated in 0.03867 seconds
