Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Edapt] Loading Resource in a Release other than the first one fails
[Edapt] Loading Resource in a Release other than the first one fails [message #1725069] Mon, 29 February 2016 09:22 Go to next message
this seems to be the same issue as reported here:
https://www.eclipse.org/forums/index.php?t=msg&th=805271&goto=1415184&#msg_1415184
I came across this while trying to create a simple sample project that imports UML model with edapt.
I think this is still an issue. And I did not find a BugReport on it. The requested stack trace is as follows:
	at org.eclipse.emf.edapt.history.reconstruction.EcoreReconstructorSwitchBase.add(EcoreReconstructorSwitchBase.java:49)
	at org.eclipse.emf.edapt.history.reconstruction.EcoreReconstructorSwitchBase.create(EcoreReconstructorSwitchBase.java:95)
	at org.eclipse.emf.edapt.internal.migration.execution.internal.MigrationReconstructor$MigrationReconstructorSwitch.caseCreate(MigrationReconstructor.java:388)
	at org.eclipse.emf.edapt.spi.history.util.HistorySwitch.doSwitch(HistorySwitch.java:218)
	at org.eclipse.emf.edapt.spi.history.util.HistorySwitch.doSwitch(HistorySwitch.java:104)
	at org.eclipse.emf.edapt.spi.history.util.HistorySwitch.doSwitch(HistorySwitch.java:90)
	at org.eclipse.emf.edapt.internal.migration.execution.internal.MigrationReconstructor.startChange(MigrationReconstructor.java:212)
	at org.eclipse.emf.edapt.history.reconstruction.CompositeReconstructorBase.startChange(CompositeReconstructorBase.java:146)
	at org.eclipse.emf.edapt.history.reconstruction.EcoreForwardReconstructor.startChange(EcoreForwardReconstructor.java:68)
	at org.eclipse.emf.edapt.history.reconstruction.ForwardReconstructorBase.doReconstruct(ForwardReconstructorBase.java:97)
	at org.eclipse.emf.edapt.history.reconstruction.ForwardReconstructorBase.doReconstruct(ForwardReconstructorBase.java:102)
	at org.eclipse.emf.edapt.history.reconstruction.ForwardReconstructorBase.doReconstruct(ForwardReconstructorBase.java:78)
	at org.eclipse.emf.edapt.history.reconstruction.ForwardReconstructorBase.doReconstruct(ForwardReconstructorBase.java:57)
	at org.eclipse.emf.edapt.history.reconstruction.CompositeReconstructorBase.reconstruct(CompositeReconstructorBase.java:74)
	at org.eclipse.emf.edapt.migration.execution.Migrator.migrate(Migrator.java:265)
	at org.eclipse.emf.edapt.migration.execution.Migrator.migrateAndLoad(Migrator.java:217)
	at my.MyEcoreTest.performMigration(MyEcoreTest.java:253)
	at my.MyEcoreTest.loadResource(MyEcoreTest.java:234)
	at my.MyEcoreTest.loadV1_0_Test(MyEcoreTest.java:211)
	at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
	at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
	at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
	at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:17)
	at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
	at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
	at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
	at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
	at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
	at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
	at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:26)
	at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
	at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:86)
	at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:459)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:675)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:382)
	at org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunner.main(RemotePluginTestRunner.java:62)
	at org.eclipse.pde.internal.junit.runtime.CoreTestApplication.run(CoreTestApplication.java:23)
	at org.eclipse.equinox.internal.app.EclipseAppContainer.callMethodWithException(EclipseAppContainer.java:587)
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:198)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
I add a simple eclipse project with two models, that reproduces the problem. If the add model changed is moved to the first release, everything works fine.
Thorsten
Re: [Edapt] Loading Resource in a Release other than the first one fails [message #1725284 is a reply to message #1725069] Wed, 02 March 2016 04:22 Go to previous message
thanks for the example. I opened a bugzilla: https://bugs.eclipse.org/bugs/show_bug.cgi?id=488828
Once the migration has reached the state where the source release, which was passed to the migrator, is fully reconstructed, the MigrationReconstructor is enabled. This is the point where not only the metamodel but also the model has to be loaded and migrated. This means that in order to load the outdated model we need to create the suitable metamodel at this point.
(This also means, that you don't have to move the composite change to the first release, but it has to be in a release before or in the source release.)
To solve this problem we need to create a mechanism to contribute new EPackages to (and not only change or update them) the created Metamodel after its initial creation.
Cheers
Johannes
Previous Topic:[Edapt] Problem when migrating models that reference UML
Next Topic:[ECP] Table Custom Control
Current Time: Sat Jul 26 12:13:05 EDT 2025
Powered by FUDForum. Page generated in 0.03181 seconds
