Home » Modeling » TMF (Xtext) » Using xtend in RCP
Using xtend in RCP [message #1724825] Fri, 26 February 2016 07:00 Go to next message
Hello everybody,
can someone tell me how to use the xtend framework in my RCP. I added the jdt and xtend plugins to the dependency, But everytime I run my application, there are a unresolved problem with the antlr bundle 3.2.0.
Are there any solutions?
Many thanks.
dim
Re: Using xtend in RCP [message #1724830 is a reply to message #1724825] Fri, 26 February 2016 07:17 Go to previous messageGo to next message
Could you share what kind of problems you have specifically?
Re: Using xtend in RCP [message #1724834 is a reply to message #1724830] Fri, 26 February 2016 07:33 Go to previous messageGo to next message
When I clicked on the Validation-Button of the Launch-Config-Dialog, I got this:
http://i64.tinypic.com/2rvyjib.jpg
Here is a part of the stack trace.
  Unresolved requirement: Require-Bundle: org.eclipse.xtend; bundle-version="2.2.0"
    -> Bundle-SymbolicName: org.eclipse.xtend; bundle-version="2.2.0.v201512150757"
       org.eclipse.xtend [418]
         Unresolved requirement: Require-Bundle: org.antlr.runtime; bundle-version="[3.2.0,3.2.1)"
	at org.eclipse.osgi.container.Module.start(Module.java:434)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.emf.mwe2.language 4 0 2016-02-26 13:28:40.871
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.mwe2.language [320]
  Unresolved requirement: Require-Bundle: org.eclipse.xtext; bundle-version="2.8.0"
    -> Bundle-SymbolicName: org.eclipse.xtext; bundle-version="2.10.0.v201601040857"; singleton:="true"
       org.eclipse.xtext [427]
         Unresolved requirement: Require-Bundle: org.antlr.runtime; bundle-version="[3.2.0,3.2.1)"; visibility:="reexport"
[Updated on: Fri, 26 February 2016 07:34] by Moderator
Re: Using xtend in RCP [message #1724839 is a reply to message #1724834] Fri, 26 February 2016 07:57 Go to previous messageGo to next message
Add org.antlr.runtime to the launch configuration. If it's missing in the available plugins table, add it to the target platform. org.antlr.runtime ist part of the eclipse common repository, but could also be installed using eclipse orbit updatesite.
Re: Using xtend in RCP [message #1724840 is a reply to message #1724839] Fri, 26 February 2016 08:03 Go to previous message
Hi Dennis,
this plugin is already installed in the eclipse plugin folder.
I download the plugin from orbit, but I think it is only a java project and not a osgi bundle.
So what is to do?
Dim
P.S. After Removing the new version of antlr org.antlr.runtime_4.3.0.v201502022030, it works Smile
[Updated on: Fri, 26 February 2016 08:19] by Moderator
Previous Topic:Issues with Clean & Auto Build in Xtext 2.9
Next Topic:Updating error markers after invoking validate
Current Time: Sun Jul 27 16:32:46 EDT 2025
Powered by FUDForum. Page generated in 0.03124 seconds
