Home » Modeling » TMF (Xtext) » Cross-reference issues
Cross-reference issues [message #1724499] Wed, 24 February 2016 04:12 Go to next message
I have issues with the cross-references to develop a simple editor with variables.
VariableDeclaration:
	(prefix='ext' | prefix='in' | prefix='out')? 'var' name=STR ('=' value=Expression)?
VariableAssignment:
	ref=[VariableDeclaration|STR] '=' value=INT
while editor validates the code, VariableAssignment class have the "ref" attribute initialized. But when you run the script, value is the only attribute initialized.
My java classes are generated by a .mwe2 file. Do I have something specific to add in this file to take care of cross-referencing ? Or something else in an other file ?
Re: Cross-reference issues [message #1724552 is a reply to message #1724499] Wed, 24 February 2016 10:10 Go to previous messageGo to next message
Are the referenced locally (the this should work out of the box) or
globally (other file)
In both case having a look at your script runner would be interesting
Re: Cross-reference issues [message #1724559 is a reply to message #1724552] Wed, 24 February 2016 11:01 Go to previous messageGo to next message
I want to create the variables locally with the runner.
I can't show you all the runner beacuse it's really big but its initialized like this:
 InputStream is = new StringInputStream(s);
                Reader reader = new InputStreamReader(is);
                IParseResult result = parser.parse(reader);
                EObject eRoot = result.getRootASTElement();
s is the editor String. and parser is a AbstractAntlrParser child
grammar rules are made like this (not complete):
Script:
	instructions+=Instruction*;
Instruction:
	statemement=Statement ';'
Statement:
	function=VariableDeclaration |
	function=VariableAssignment
to get the variableDeclaration we want assign I get it like this:
VariableAssignment var =  ((VariableAssignmentImpl)statement.getFunction()).getRef()
But ref attribute is null.
Re: Cross-reference issues [message #1724560 is a reply to message #1724559] Wed, 24 February 2016 11:06 Go to previous messageGo to next message
you simply call the parse.
the parser itself does not know anything about resolving cross refs.
thus you should do something like
https://wiki.eclipse.org/Xtext/FAQ#How_do_I_load_my_model_in_a_standalone_Java_application.C2.A0.3F
Re: Cross-reference issues [message #1724562 is a reply to message #1724560] Wed, 24 February 2016 11:25 Go to previous messageGo to next message
my parser is initialized like this:
            Injector guiceInjector = new ScriptStandaloneSetup().createInjectorAndDoEMFRegistration();
            parser = guiceInjector.getInstance(ScriptParser.class);
I'm going to try with the link you gave to me
Re: Cross-reference issues [message #1724568 is a reply to message #1724562] Wed, 24 February 2016 11:55 Go to previous messageGo to next message
Sorry I'm beginner, and I'm on an old project that use Xtext.
The fact is that when you generate files with .mwe2 it generates a Main.java file, but I don't know where it's used. Is it important ?
This is the runGenerator method called by this main:
    protected void runGenerator(String string) {
        // load the resource
        ResourceSet set = resourceSetProvider.get();
        Resource resource = set.getResource(URI.createURI(string), true);
        // validate the resource
        List<Issue> list = validator.validate(resource, CheckMode.ALL, CancelIndicator.NullImpl);
        if (!list.isEmpty()) {
            for (Issue issue : list) {
                System.err.println(issue);
            return;
        // configure and start the generator
        fileAccess.setOutputPath("src-gen/");
        generator.doGenerate(resource, fileAccess);
[Updated on: Wed, 24 February 2016 11:56] by Moderator
Re: Cross-reference issues [message #1724569 is a reply to message #1724568] Wed, 24 February 2016 12:00 Go to previous messageGo to next message
The pregenerated main is just an option / starting point
Re: Cross-reference issues [message #1724570 is a reply to message #1724568] Wed, 24 February 2016 12:00 Go to previous messageGo to next message
And no it is not used until you actually use it by calling it
Re: Cross-reference issues [message #1724655 is a reply to message #1724570] Thu, 25 February 2016 05:15 Go to previous messageGo to next message
Ok so I wrote this:
                 Injector injector = new ScriptStandaloneSetup().createInjectorAndDoEMFRegistration();
                XtextResourceSet resourceSet = injector.getInstance(XtextResourceSet.class);
                resourceSet.addLoadOption(XtextResource.OPTION_RESOLVE_ALL, Boolean.TRUE);
                Resource resource = resourceSet.createResource(URI.createURI("platform:/resource/fr.untel.example.script/src-gen/fr/untel/example/script/Script.genmodel"));
                InputStream in = new ByteArrayInputStream(s.getBytes());
                resource.load(in, resourceSet.getLoadOptions());
                this.script = (Script) resource.getContents().get(0);
s is the string typed by the user in editor
I have this error when I call resource.load :
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Content is not allowed in prolog.
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:195)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:253)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
Re: Cross-reference issues [message #1724658 is a reply to message #1724655] Thu, 25 February 2016 05:26 Go to previous messageGo to next message
a genmodel file is not a xtext file. did you name your language genmodel ?!?
[Updated on: Thu, 25 February 2016 05:26] by Moderator
Re: Cross-reference issues [message #1724660 is a reply to message #1724658] Thu, 25 February 2016 05:27 Go to previous messageGo to next message
I have the same error with the .xtext file
Re: Cross-reference issues [message #1724664 is a reply to message #1724660] Thu, 25 February 2016 05:44 Go to previous messageGo to next message
Ok finally I found that the extension should be ".fml" as described in .mwe2 file. i didn't find any file with this extension so I thought it was not the good extension.
Now it works fine.
Thank you very much Christian, and sorry to be a noob in xtext devlopment
Re: Cross-reference issues [message #1724665 is a reply to message #1724664] Thu, 25 February 2016 05:48 Go to previous message
no problem. feel free to ask any question
Previous Topic:IllegalStateException for specific text
Next Topic:Xtext 2.8.4 with Maven but without Tycho
Current Time: Sat Jul 26 23:24:21 EDT 2025
Powered by FUDForum. Page generated in 1.12027 seconds
