Home » Eclipse Projects » NatTable » MoveSelectionCommand with multiple cells selected
MoveSelectionCommand with multiple cells selected [message #1724541] Wed, 24 February 2016 08:48 Go to next message
is there a way to move all selected cells by MoveSelectionCommand? Or is there may be another way to
move all selections?
As fare as I noticed only one cell is selected after the MoveSelectionCommand command was done.
Any hints are appreciated, Martin
Re: MoveSelectionCommand with multiple cells selected [message #1724547 is a reply to message #1724541] Wed, 24 February 2016 09:58 Go to previous messageGo to next message
Not supported out of the box. You need to implement this yourself. The default implementation only considers the selection anchor that would move on UI interactions.
Re: MoveSelectionCommand with multiple cells selected [message #1724667 is a reply to message #1724547] Thu, 25 February 2016 06:08 Go to previous messageGo to next message
OK noted, thanks.
My task is to move rows up and down. All selected rows shall move and I want to keep the selection
on the moved rows. As my underlying model has to reflect this moved row order I modified the EMF
model by a command and the issue an NatTable command to move the selection.
May be my way to implement the task (moving row up/down) is not perfect. What you be your
recommendation?
Martin
Dirk Fauth schrieb am 24.02.2016 um 15:58:
Re: MoveSelectionCommand with multiple cells selected [message #1724675 is a reply to message #1724667] Thu, 25 February 2016 06:49 Go to previous messageGo to next message
So it is only to keep the selection on moved rows? Do you have row selection enabled? In that case it is quite simple. Use the RowSelectionModel which tracks the selection by unique row id you have to specify. On cell level it is the PreserveSelectionModel (I think that is the name).
Re: MoveSelectionCommand with multiple cells selected [message #1724727 is a reply to message #1724675] Thu, 25 February 2016 10:36 Go to previous messageGo to next message
Yes it is only to keep the selection on moved rows.
After looking up the examples found at github I added the PreserveSelectionModel but now I cant
select cells/rows any more.
The BodyLayerStack code is as follow:
public class BodyLayerStack extends AbstractLayerTransform {
private SelectionLayer mSelectionLayer;
private DataLayer mBodyDataLayer;
public BodyLayerStack(IDataProvider dataProvider) {
mBodyDataLayer = new DataLayer(dataProvider);
mBodyDataLayer.setColumnPercentageSizing(true);
mBodyDataLayer.setColumnWidthPercentageByPosition(0, 20);
mBodyDataLayer.setColumnWidthPercentageByPosition(1, 20);
mBodyDataLayer.setColumnWidthPercentageByPosition(2, 20);
mBodyDataLayer.setColumnWidthPercentageByPosition(3, 13);
mBodyDataLayer.setColumnWidthPercentageByPosition(4, 13);
mBodyDataLayer.setColumnWidthPercentageByPosition(5, 14);
mSelectionLayer = new SelectionLayer(mBodyDataLayer,false);
mSelectionLayer.setSelectionModel(new
PreserveSelectionModel<CorridorItem>(mSelectionLayer, (IRowDataProvider<CorridorItem>) dataProvider,
new IRowIdAccessor<CorridorItem>() {
public Serializable getRowId(CorridorItem rowObject) {
return rowObject.getClass().hashCode();
ViewportLayer viewportLayer = new ViewportLayer(mSelectionLayer);
setUnderlyingLayer(viewportLayer);
public SelectionLayer getSelectionLayer() {
return mSelectionLayer;
public DataLayer getBodyDataLayer() {
return mBodyDataLayer;
May be it has to do with enable row selection. But how to do this?
Martin
Dirk Fauth schrieb am 25.02.2016 um 12:49:
Re: MoveSelectionCommand with multiple cells selected [message #1724729 is a reply to message #1724727] Thu, 25 February 2016 10:44 Go to previous messageGo to next message
my mistake was to use
bu should have used
mSelectionLayer = new SelectionLayer(mBodyDataLayer); //without the false parameter
Now I am able to select a single cell but the whole column is highlighted. Without the selection
model I can select individual cells which I prefer. But how to do this with PreserveSelectionModel?
Martin
Martin Jacob schrieb am 25.02.2016 um 16:36:
> dataProvider, new IRowIdAccessor<CorridorItem>() {
> @Override
> Martin
Re: MoveSelectionCommand with multiple cells selected [message #1724734 is a reply to message #1724729] Thu, 25 February 2016 10:57 Go to previous messageGo to next message
The whole column is highlighted? Sounds more like an issue regarding your IRowIdAccessor implementation. And looking into it, that is exactly the case. Why should the hashCode of the class of your row object differ between objects?
Re: MoveSelectionCommand with multiple cells selected [message #1724739 is a reply to message #1724734] Thu, 25 February 2016 11:08 Go to previous messageGo to next message
The hashCode is individually per row, each row has an individual CorridorItem object instance. Still
problematic?
Dirk Fauth schrieb am 25.02.2016 um 16:57:
Re: MoveSelectionCommand with multiple cells selected [message #1724741 is a reply to message #1724739] Thu, 25 February 2016 11:10 Go to previous messageGo to next message
And by click at the row header the whole table gets highlighted.
Re: MoveSelectionCommand with multiple cells selected [message #1724744 is a reply to message #1724734] Thu, 25 February 2016 11:25 Go to previous message
oh man, what a rookie mistake!
is changed to
return rowObject.toString();
thanks for your help!
Previous Topic:Insert new Row in the nattable
Next Topic:Print & fit to page
Current Time: Mon Jul 21 07:48:41 EDT 2025
Powered by FUDForum. Page generated in 0.75924 seconds
