Home » Eclipse Projects » Gendoc » Retrieving Stereotype Information(Retrieving Stereotype Information when profile is not in workspace directory)
Retrieving Stereotype Information [message #1724493] Wed, 24 February 2016 03:56 Go to next message
A project (called projectX) exists in a workspace (called workspaceX). A profile (called profileY) exists in a directory that is not in workspaceX.
In the above situation, the Stereotype information does not display.
If I copy profileY into workspaceX and then refactor the model to point to the copy of profileY, the stereotype information displays.
I found this because I had a profile in a GIT repository and my local GIT directory is not underneath the workspace directory.
thoughts?
Re: Retrieving Stereotype Information [message #1724549 is a reply to message #1724493] Wed, 24 February 2016 10:03 Go to previous messageGo to next message
Some errors can occur in this case. Can you tell me how the profile is referenced in your model ?
(open the uml file with text editor and find reference to your profile searching its name)
Re: Retrieving Stereotype Information [message #1728947 is a reply to message #1724549] Fri, 08 April 2016 11:35 Go to previous messageGo to next message
Actually i think i have the same issue. I would like to access on the propeties of a specific stereotype. With a default sysml stereotype it works good. But with my own it doesn't work. I also have my profile in a other workspace (because of git). Maybe i do something wrong:
Loading of the profile:
<eAnnotations xmi:type="ecore:EAnnotation" xmi:id="_n1FyIPzFEeWnQpiBpzKiUg" source="http://www.eclipse.org/uml2/2.0.0/UML">
<references xmi:type="ecore:EPackage" href="../Sysmod/Sysmod.profile.uml#_8-eSwPzdEeWLBbdJDAaZLA"/>
</eAnnotations>
<appliedProfile xmi:type="uml:Profile" href="../Sysmod/Sysmod.profile.uml#_voikEOwhEeWIdZ7Wttd0Rw"/>
Stereotype i want to access:
<Sysmod.Requirements:Objective xmi:id="_xY31gPzFEeWnQpiBpzKiUg" base_Class="__jD4wPzEEeWnQpiBpzKiUg" text="Sourcecodeverwaltungssystem (Git, Svn, usw.)" id="1"/>
Code in word:
Sysmod:
[for (r : uml::Class | uml::Class.allInstances()->select(not getAppliedStereotype('Sysmod::Requirements:Objective').oclIsUndefined()))]
text : [r.getValue(getAppliedStereotype('Sysmod::Requirements:Objective'),'text')/]
[/for]
Best regards
Benny
Re: Retrieving Stereotype Information [message #1728956 is a reply to message #1728947] Fri, 08 April 2016 12:05 Go to previous messageGo to next message
Can you try
Sysmod::Requirements::Objective
instead of Sysmod::Requirements:Objective ?
You can find the qualified name of your stereotype in the advanced property view when you select the stereotype in the profile definition
Re: Retrieving Stereotype Information [message #1728961 is a reply to message #1728956] Fri, 08 April 2016 12:20 Go to previous messageGo to next message
No it also doen't work with copying the name from the advanced property:
Sysmod:
[for (r : uml::Class | uml::Class.allInstances()->select(not getAppliedStereotype('Sysmod::Requirements::Objective').oclIsUndefined()))]
text : [r.getValue(getAppliedStereotype('Sysmod::Requirements::Objective'),'text')/]
[/for]
Greetings
Re: Retrieving Stereotype Information [message #1729090 is a reply to message #1728961] Mon, 11 April 2016 03:01 Go to previous messageGo to next message
Can you try this query and do a copy paste :
Class.allInstances().getAppliedStereotypes()->asSet().qualifiedName.clean() ?
Re: Retrieving Stereotype Information [message #1729366 is a reply to message #1729090] Wed, 13 April 2016 08:39 Go to previous messageGo to next message
After trying with your data on my configuration it seems it is working.
My Installation :
papyrus : from https://eclipse.org/papyrus/download.html (windows 64 bits),
Gendoc 0.5.1
Sysml 1.4 from Help > Install new software > Papyrus > Papyrus Sysml 1.4 feature
What is the difference with what you built ?
icon10.gif  Re: Retrieving Stereotype Information [message #1729389 is a reply to message #1729366] Wed, 13 April 2016 11:39 Go to previous message
The solution for me was to change the location of the profile. First i had the profile somewhere on my disk and i imported the profile project into the workspace. In this case i had the troubles with the stereotypes. Then i copied the profile project into the workspace and imported it from there. Now everything works fine. I think there is a problem storing projects outside the workspace.
Greetings
Benny
Previous Topic:Accessing images
Next Topic:Problems when generating images from Papyrus diagrams
Current Time: Sun Jul 20 22:00:04 EDT 2025
Powered by FUDForum. Page generated in 0.05736 seconds
