CTabFolder content display issue in combination with ScrolledComposite [message #1724013] |
Fri, 19 February 2016 14:41  |
I have a CTabFolder with 3 CTabItem each one of which contains a ScrolledComposite. The issue is that the content of the second and third tabs is invisible until the window is either resized or after the user repeatedly clicks through the tabs. Please help!
public class TestCTabFolder {
private CTabFolder tabFolder;
public void run() {
Display display = new Display();
Shell shell = new Shell(display);
shell.setText("Show CTabFolder");
createContents(shell);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
display.dispose();
private void createContents(Shell shell) {
shell.setLayout(new GridLayout(1, true));
// Create the tabs
tabFolder = new CTabFolder(shell, SWT.TOP);
tabFolder.setBorderVisible(true);
tabFolder.setLayoutData(new GridData(GridData.FILL_BOTH));
tabFolder.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
tabFolder.getSelection().notifyListeners(SWT.SELECTED, new Event());
CTabItem firstTab = addTab("tab1");
addTab("tab2");
addTab("tab3");
tabFolder.setSelection(firstTab);
private CTabItem addTab(String title) {
CTabItem tabItem = new CTabItem(tabFolder, SWT.NONE);
tabItem.setText(title);
final ScrolledComposite scrolledComp = new ScrolledComposite(tabFolder, SWT.V_SCROLL);
final Composite comp = new Composite(scrolledComp, SWT.NONE);
scrolledComp.setContent(comp);
comp.setLayout(new GridLayout(1, true));
comp.setLayoutData(new GridData(GridData.FILL_BOTH));
for (int i = 0; i < 30; i++) {
Label label = new Label(comp, SWT.NONE);
label.setText(title + ": label" + i);
scrolledComp.setExpandVertical(true);
scrolledComp.setExpandHorizontal(true);
scrolledComp.setMinSize(comp.computeSize(SWT.DEFAULT, SWT.DEFAULT));
tabItem.setControl(scrolledComp);
tabItem.addListener(SWT.SELECTED, new Listener() {
public void handleEvent(Event event) {
scrolledComp.layout(true);
return tabItem;
new TestCTabFolder().run();
Artem
FUDForum. Page generated in 0.03778 seconds
