IllegalStateException for specific text [message #1724402] |
Tue, 23 February 2016 12:18  |
Hi ,
I get an exception at the following part of code.
def private ContentAssistContext[] getContexts(XtextResource resource, String text, ITextRegion selection,
int caretOffset) {
if (caretOffset > text.length)
return #[]
val contextFactory = contextFactoryProvider.get() => [pool = Executors.newCachedThreadPool]
contextFactory.create(text, selection, caretOffset, resource)
This happens when the input is
"plot abc by tim by adviser by"
This does not happen when the input
"plot abc by tim by adviser"
my grammar :
Model:
greetings=Query;
Query:
(key=QTypekeyWord)? (aggregation=Aggregation)? (measure=MeasureList) ((groupBy=GroupList)? &(condition=Condtition)? &(range=Transition)?) ;
QTypekeyWord:
qKeyword='plot'
Aggregation:
agg=('average'|'number of'|'total')
Condtition:
con+='for' dimVal=DimensionValue 'as' dim=Dimension ('and' dimValue=DimensionValue 'as' dimen=Dimension)*
MeasureList : names+=Measure ("and" names+=Measure)*;
Measure:ID+;
Dimension:
dimensions+=ID+
DimensionValue:
value=ID+
GroupList:
(=> "by" (timeGroups+=TimeGroup|dimensionGroups+=Dimension))+
Transition:
'from' dateStart=Date 'to' dateEnd=Date
TimeGroup:
timeGroup=('day'|'week'|'month'|'quarter'|'year')
Date:
d=Day m=Month y=Year ;
Day : INT ;
Month : 'Jan'|'Feb'|'Mar'|'Apr' ;
Year : INT ;
java.util.concurrent.ExecutionException: java.lang.IllegalStateException: expected element: 'org.eclipse.xtext.impl.RuleCallImpl@26d83c77 (cardinality: null, predicated: false, firstSetPredicated: false) (explicitlyCalled: false)', but was: 'org.eclipse.xtext.impl.GroupImpl@7cac903 (cardinality: +, predicated: false, firstSetPredicated: false)'
at java.util.concurrent.FutureTask.report(FutureTask.java:122) ~[?:1.8.0_45]
at java.util.concurrent.FutureTask.get(FutureTask.java:192) ~[?:1.8.0_45]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.doCreateContexts(ContentAssistContextFactory.java:173) [org.eclipse.xtext.ide-2.9.1.jar:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.create(ContentAssistContextFactory.java:123) [org.eclipse.xtext.ide-2.9.1.jar:?]
at com.einsights.suggestions.dsl.StandAloneContentAssistService.getContexts(StandAloneContentAssistService.java:72) [classes/:?]
at com.einsights.suggestions.dsl.StandAloneContentAssistService.createProposals(StandAloneContentAssistService.java:50) [classes/:?]
at com.einsights.suggestions.dsl.EinDslExecutor.executeContentAssistor(EinDslExecutor.java:51) [classes/:?]
at com.einsights.suggestions.service.SuggestionsServiceImpl.getContentAssist(SuggestionsServiceImpl.java:243) [classes/:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_45]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_45]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_45]
at java.lang.reflect.Method.invoke(Method.java:497) ~[?:1.8.0_45]
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:302) [spring-aop-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:190) [spring-aop-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157) [spring-aop-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.validation.beanvalidation.MethodValidationInterceptor.invoke(MethodValidationInterceptor.java:139) [spring-context-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179) [spring-aop-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:208) [spring-aop-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at com.sun.proxy.$Proxy144.getContentAssist(Unknown Source) [?:?]
at com.einsights.suggestions.controller.SuggestionsController.getContentAssist(SuggestionsController.java:119) [classes/:?]
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:222) [spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:137) [spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:110) [spring-webmvc-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:814) [spring-webmvc-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:737) [spring-webmvc-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:85) [spring-webmvc-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959) [spring-webmvc-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893) [spring-webmvc-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:969) [spring-webmvc-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:871) [spring-webmvc-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:648) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:845) [spring-webmvc-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) [tomcat-embed-websocket-8.0.30.jar:8.0.30]
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.springframework.boot.actuate.autoconfigure.EndpointWebMvcAutoConfiguration$ApplicationContextHeaderFilter.doFilterInternal(EndpointWebMvcAutoConfiguration.java:237) [spring-boot-actuator-1.3.2.RELEASE.jar:1.3.2.RELEASE]
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) [spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.apache.shiro.web.servlet.ProxiedFilterChain.doFilter(ProxiedFilterChain.java:61) [shiro-web-1.2.4.jar:1.2.4]
at org.apache.shiro.web.servlet.AdviceFilter.executeChain(AdviceFilter.java:108) [shiro-web-1.2.4.jar:1.2.4]
at org.apache.shiro.web.servlet.AdviceFilter.doFilterInternal(AdviceFilter.java:137) [shiro-web-1.2.4.jar:1.2.4]
at org.apache.shiro.web.servlet.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:125) [shiro-web-1.2.4.jar:1.2.4]
at org.apache.shiro.web.servlet.ProxiedFilterChain.doFilter(ProxiedFilterChain.java:66) [shiro-web-1.2.4.jar:1.2.4]
at org.apache.shiro.web.servlet.AbstractShiroFilter.executeChain(AbstractShiroFilter.java:449) [shiro-web-1.2.4.jar:1.2.4]
at org.apache.shiro.web.servlet.AbstractShiroFilter$1.call(AbstractShiroFilter.java:365) [shiro-web-1.2.4.jar:1.2.4]
at org.apache.shiro.subject.support.SubjectCallable.doCall(SubjectCallable.java:90) [shiro-core-1.2.4.jar:1.2.4]
at org.apache.shiro.subject.support.SubjectCallable.call(SubjectCallable.java:83) [shiro-core-1.2.4.jar:1.2.4]
at org.apache.shiro.subject.support.DelegatingSubject.execute(DelegatingSubject.java:383) [shiro-core-1.2.4.jar:1.2.4]
at org.apache.shiro.web.servlet.AbstractShiroFilter.doFilterInternal(AbstractShiroFilter.java:362) [shiro-web-1.2.4.jar:1.2.4]
at org.springframework.boot.actuate.trace.WebRequestTraceFilter.doFilterInternal(WebRequestTraceFilter.java:111) [spring-boot-actuator-1.3.2.RELEASE.jar:1.3.2.RELEASE]
at org.springframework.web.filter.RequestContextFilter.doFilterInternal(RequestContextFilter.java:99) [spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.filter.HttpPutFormContentFilter.doFilterInternal(HttpPutFormContentFilter.java:87) [spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.filter.HiddenHttpMethodFilter.doFilterInternal(HiddenHttpMethodFilter.java:77) [spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121) [spring-web-4.2.4.RELEASE.jar:4.2.4.RELEASE]
at org.springframework.boot.actuate.autoconfigure.MetricsFilter.doFilterInternal(MetricsFilter.java:103) [spring-boot-actuator-1.3.2.RELEASE.jar:1.3.2.RELEASE]
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:212) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:141) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:521) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1096) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:674) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1500) [tomcat-embed-core-8.0.30.jar:8.0.30]
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1456) [tomcat-embed-core-8.0.30.jar:8.0.30]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_45]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_45]
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) [tomcat-embed-core-8.0.30.jar:8.0.30]
at java.lang.Thread.run(Thread.java:745) [?:1.8.0_45]
Caused by: java.lang.IllegalStateException: expected element: 'org.eclipse.xtext.impl.RuleCallImpl@26d83c77 (cardinality: null, predicated: false, firstSetPredicated: false) (explicitlyCalled: false)', but was: 'org.eclipse.xtext.impl.GroupImpl@7cac903 (cardinality: +, predicated: false, firstSetPredicated: false)'
at org.eclipse.xtext.ide.editor.contentassist.antlr.internal.AbstractInternalContentAssistParser.after(AbstractInternalContentAssistParser.java:202) ~[org.eclipse.xtext.ide-2.9.1.jar:?]
at org.xtext.example.mydsl.ide.contentassist.antlr.internal.InternalEinDslParser.rule__Query__GroupByAssignment_3_0(InternalEinDslParser.java:4980) ~[classes/:?]
at org.xtext.example.mydsl.ide.contentassist.antlr.internal.InternalEinDslParser.rule__Query__UnorderedGroup_3__Impl(InternalEinDslParser.java:4484) ~[classes/:?]
at org.xtext.example.mydsl.ide.contentassist.antlr.internal.InternalEinDslParser.rule__Query__UnorderedGroup_3__0(InternalEinDslParser.java:4634) ~[classes/:?]
at org.xtext.example.mydsl.ide.contentassist.antlr.internal.InternalEinDslParser.rule__Query__UnorderedGroup_3(InternalEinDslParser.java:4398) ~[classes/:?]
at org.xtext.example.mydsl.ide.contentassist.antlr.internal.InternalEinDslParser.rule__Query__Group__3__Impl(InternalEinDslParser.java:2443) ~[classes/:?]
at org.xtext.example.mydsl.ide.contentassist.antlr.internal.InternalEinDslParser.rule__Query__Group__3(InternalEinDslParser.java:2401) ~[classes/:?]
at org.xtext.example.mydsl.ide.contentassist.antlr.internal.InternalEinDslParser.rule__Query__Group__2(InternalEinDslParser.java:2317) ~[classes/:?]
at org.xtext.example.mydsl.ide.contentassist.antlr.internal.InternalEinDslParser.rule__Query__Group__1(InternalEinDslParser.java:2217) ~[classes/:?]
at org.xtext.example.mydsl.ide.contentassist.antlr.internal.InternalEinDslParser.rule__Query__Group__0(InternalEinDslParser.java:2117) ~[classes/:?]
at org.xtext.example.mydsl.ide.contentassist.antlr.internal.InternalEinDslParser.ruleQuery(InternalEinDslParser.java:230) ~[classes/:?]
at org.xtext.example.mydsl.ide.contentassist.antlr.internal.InternalEinDslParser.rule__Model__GreetingsAssignment(InternalEinDslParser.java:4795) ~[classes/:?]
at org.xtext.example.mydsl.ide.contentassist.antlr.internal.InternalEinDslParser.ruleModel(InternalEinDslParser.java:145) ~[classes/:?]
at org.xtext.example.mydsl.ide.contentassist.antlr.internal.InternalEinDslParser.entryRuleModel(InternalEinDslParser.java:102) ~[classes/:?]
at org.xtext.example.mydsl.ide.contentassist.antlr.EinDslParser.getFollowElements(EinDslParser.java:87) ~[classes/:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.AbstractContentAssistParser.getFollowElements(AbstractContentAssistParser.java:322) ~[org.eclipse.xtext.ide-2.9.1.jar:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.createContextsForLastCompleteNode(ContentAssistContextFactory.java:274) ~[org.eclipse.xtext.ide-2.9.1.jar:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.handleLastCompleteNodeIsPartOfLookahead(ContentAssistContextFactory.java:209) ~[org.eclipse.xtext.ide-2.9.1.jar:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory$3.call(ContentAssistContextFactory.java:164) ~[org.eclipse.xtext.ide-2.9.1.jar:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory$3.call(ContentAssistContextFactory.java:1) ~[org.eclipse.xtext.ide-2.9.1.jar:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:1.8.0_45]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) ~[?:1.8.0_45]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) ~[?:1.8.0_45]
... 1 more
FUDForum. Page generated in 0.54022 seconds
