Home » Modeling » UML2 » UML diagram for model AND metamodel in MDA?
UML diagram for model AND metamodel in MDA? [message #1724356] Tue, 23 February 2016 05:53 Go to next message
following an MDA/MDSD approach, is it possible in Eclipse to have metamodel AND model both represented in UML?
All tutorials (using QVT and XPAND) were only having the metamodel in EMF also visualized as UML diagram, but the model then was just filled in bare Ecore tools.
Is there another way while still using QVT/XPAND?
Kind regards
Michael
I have been following these tutorials so far:
http://www.vogella.com/tutorials/EclipseEMF/article.html
http://redpanda.nl/index.php?p=tutorial9
http://www.peterfriese.de/getting-started-with-code-generation-with-xpand/
[Updated on: Tue, 23 February 2016 06:04] by Moderator
Re: UML diagram for model AND metamodel in MDA? [message #1724367 is a reply to message #1724356] Tue, 23 February 2016 06:40 Go to previous messageGo to next message
Hi, Michael,
I'm not sure I understand the question. Metamodeling is a restricted
case of modeling, in which you design the structure of models. That
uses only concepts of class, property, association, operation, and a
few others from the UML. It happens to be the subset that maps to
EMF's Ecore (rather deliberately) and, in the Eclipse implementation of
UML, metamodeling with UML does imply a translation to Ecore in order
to implement models based on your metamodel.
So, with the Eclipse tools, you can certainly use UML for definition of
a metamodel and then create an EMF generator model from your metamodel
to generate its implementation. This is exactly how the Eclipse UML
implementation, itself, is generated.
HTH,
Christian
On 2016-02-23 10:53:46 +0000, Michael Zach said:
> Hello,
> Kind regards
> Michael
Re: UML diagram for model AND metamodel in MDA? [message #1724369 is a reply to message #1724356] Tue, 23 February 2016 06:46 Go to previous messageGo to next message
UML provides a design / specification of your system; not an implementation.
If you want instances then you need an implementation approach for which
Ecore and Java are a very popular solution. But it won't work well if
you like C++.
That said, it is possible to model instances in UML using
InstanceSpecifications, but this is normally for design / documentation
/ test purposes. IMHO you would be mad to use InstanceSpecifications as
part of an implementation.
Ed Willink
On 23/02/2016 10:53, Michael Zach wrote:
> Hello,
> Kind regards
> Michael
Re: UML diagram for model AND metamodel in MDA? [message #1725210 is a reply to message #1724367] Tue, 01 March 2016 12:28 Go to previous messageGo to next message
Hello Christian! Hello Ed!
Yes of course. In my case the "metamodel" is the specification for the "model".
My problem is not to get some Java/C++ code at the end, but another Editor which is capable of defining a model in it following the constraints defined in the metamodel.
Hope my emplanation is confusing enough ;o)
Yes, this is exactly what I did.
I was just wondering, if there is an alternative/option for the generation of the implementation of the EMF generator model. Because all I get at the end is a property/value kind of editor which of course implements the classes, properties, constraints etc. of the metamodel.
What I was looking for was a way to get a graphical UML class diagram - style editor for the model at the end. That was what I was heading for:
* define an UML class diagram for the metamodel
* create an EMF generator model from it
* implement the metamodel and
* get a UML class diagram editor (kind of) where I can now graphically define the model (instead of having this tree/detail editor where I can only fill in the property/value pairs)
Hope you know what I mean.
I have now heard about GMF, but I am not sure if I can tweak it to really get UML style diagrams.
Thank you
Michael
Re: UML diagram for model AND metamodel in MDA? [message #1725216 is a reply to message #1725210] Tue, 01 March 2016 13:55 Go to previous message
For UML-like custom diagrams you probably want Sirius.
For genuinely UML diagrams you probably want Papyrus.
(Both of which use GMF behind the scenes.)
Ed Willink
>> implementation.
> "model".
> metamodel.
> Thank you
> Michael
Previous Topic:Stereotype definitions and applications in the same file
Next Topic:Problem loading UML in stand alone application
Current Time: Thu Jul 24 23:49:22 EDT 2025
Powered by FUDForum. Page generated in 0.08166 seconds
