Home » Eclipse Projects » NatTable » Custom Tree row rendering
Custom Tree row rendering [message #1723994] Fri, 19 February 2016 10:10
I'm using a tree to display some data from my application, and what I would like is to render the row data in a specific way.
The tree will display all of partitions from my PC. The root element should always show the occupied size.
The tree contains two columns, the first column shows the name of a folder or a file and the second column will show their size.
I would like to show the size of the folder only if the tree element is collapsed, so the files from the folder are not visible. If the folder element will be expanded then the folder size should not be displayed only the size of each file from the expanded folder.
Any suggestions are appreciated.
Csabi
Previous Topic:Combobox Multiselection setData
Next Topic:Insert new Row in the nattable
Current Time: Mon Jul 21 08:18:29 EDT 2025
Powered by FUDForum. Page generated in 0.04030 seconds
