Home » Eclipse Projects » Mylyn » JIRA Connector for MARS
JIRA Connector for MARS [message #1700239] Wed, 01 July 2015 02:55 Go to next message
is there any planned release date for the JIRA connector usable with Eclipse MARS ?
The Mylyn connector discovery list showing up for 'Install more connectors..." in Eclipse MARS did not contain the JIRA connector.
Kind regards
Dominik
Re: JIRA Connector for MARS [message #1700763 is a reply to message #1700239] Mon, 06 July 2015 19:01 Go to previous messageGo to next message
I expect the discovery listing will be updated in a few days. In the mean time you can install the JIRA connector directly from Atlassian: https://confluence.atlassian.com/display/IDEPLUGIN/Installing+the+Eclipse+Connector
Sam
Re: JIRA Connector for MARS [message #1701273 is a reply to message #1700239] Fri, 10 July 2015 08:01 Go to previous messageGo to next message
Sadly, Atlassian retired the IDE connectors:
see their blog:
developer.atlassian.com/blog/2015/06/discontinuing-ide-connectors-support/
Re: JIRA Connector for MARS [message #1701605 is a reply to message #1700239] Tue, 14 July 2015 07:50 Go to previous messageGo to next message
Are there any plans on resurrecting the Mylyn JIRA Connector now that Atlassian is no longer supporting the Atlassian Connector?
Re: JIRA Connector for MARS [message #1701659 is a reply to message #1701605] Tue, 14 July 2015 13:55 Go to previous messageGo to next message
No, we have no plans to take on maintenance of a JIRA connector within the Mylyn project.
Sam
Re: JIRA Connector for MARS [message #1704879 is a reply to message #1700239] Mon, 10 August 2015 07:33 Go to previous messageGo to next message
It is neither listed under "Install more connectors" nor in the Eclipse MarketPlace. Still I managed to install it on Eclipse Mars without problems by using the Eclipse Update Site mentioned here.
Re: JIRA Connector for MARS [message #1723782 is a reply to message #1700239] Wed, 17 February 2016 16:24 Go to previous messageGo to next message
Looks like it is now an open source project. I installed it, but am getting an authentication error from MyLyn when trying to verify my Jira connection. Same username and password work fine with jira.
Error:
Client response status: 302. Https might be required.
My site does use https.
Here's the open source project if anyone wants to help out. (Won't let me post the entire link. Mad
bitbucket.org/atlassian/connector-eclipse
Re: JIRA Connector for MARS [message #1734498 is a reply to message #1723782] Wed, 08 June 2016 16:35 Go to previous messageGo to next message
Following up on this, while Atlassian has removed support for their JIRA connector, there is a new, supported JIRA connector available from Tasktop for $24/yr. See the Eclipse Marketplace listing or http://www.tasktop.com/tasktop-dev-pro.
Re: JIRA Connector for MARS [message #1838960 is a reply to message #1734498] Wed, 10 March 2021 08:06 Go to previous message
The Eclipse/Mylnn/Jira connector is no longer supported by Atlassian and even though the opensource jira-rest-java-client libraries have been updated to handle the api drift of Jira Cloud, I myself have been unable to figure out how to update/fix the plugin (Atlassian Connector for Eclipse / Atlassian JIRA Connector)
Does anyone else use Eclipse and would like a Task-based focus on their Jira workload? I imagine there are many of you out there... How do you do it? Is there another way? Have you handmade your own connector/plugins?
Many thanks if anyone can help.
Best,
Will
Previous Topic:[solved] Bundle 'org.eclipse.mylyn.tasks.bugs' cannot be resolved
Next Topic:Jettison error
Current Time: Tue Jun 03 00:59:28 EDT 2025
Powered by FUDForum. Page generated in 0.06460 seconds
