Home » Archived » Sapphire » Case Insensitivity for XMLBinding
Case Insensitivity for XMLBinding [message #1715469] Mon, 23 November 2015 16:37 Go to next message
Is it possible to make the XMLBinding case-insensitive meaning I could have
<ComponentSpec></ComponentSpec>
or
<componentspec></componentspec>
and the form be able to handle both cases?
Re: Case Insensitivity for XMLBinding [message #1715471 is a reply to message #1715469] Mon, 23 November 2015 16:50 Go to previous messageGo to next message
There is currently no declarative way to do this (please open an enhancement request), but you can do this with a custom binding.
1. Extend StandardXmlValueBindingImpl and override read(), write() and getXmlNode() methods
2. Add @CustomXmlValueBinding( impl = YourCustomBinding.class ) to properties that need this behavior
List and element property bindings can be similarly customized.
Re: Case Insensitivity for XMLBinding [message #1715475 is a reply to message #1715471] Mon, 23 November 2015 17:32 Go to previous messageGo to next message
Thank you. Is there something similar for attributes as well?
Re: Case Insensitivity for XMLBinding [message #1715637 is a reply to message #1715475] Tue, 24 November 2015 15:49 Go to previous messageGo to next message
Yes, the same binding mechanism is used for attributes and elements.
[Updated on: Tue, 24 November 2015 15:50] by Moderator
Re: Case Insensitivity for XMLBinding [message #1723748 is a reply to message #1715637] Wed, 17 February 2016 10:17 Go to previous messageGo to next message
For the top level interface element, is the use of @CustomXmlValueBinding the same and if so, where does it get placed.
For instance I have an interface named application
public interface Application extends Element {
Currently I have @XmlBinding placed above the class declaration to make it lowercase in the xml, however I need to accept both upper and lower case.
@XmlBinding( path = "application" )
When I try to replace @XmlBinding with @CustomXmlValueBinding I get an error. Is there a different tag used at this level and if so what class would I need to overwrite?
Re: Case Insensitivity for XMLBinding [message #1729765 is a reply to message #1723748] Mon, 18 April 2016 13:48 Go to previous message
Sorry, I see that this follow-up question does not have a reply. In case you haven't figured it out already, for the root element, you need to use @CustomXmlRootBinding and implement a RootElementController.
Previous Topic:Is there a way to configure the font of a label in an sdef file
Next Topic:styling with css
Current Time: Tue Oct 28 06:00:58 EDT 2025
Powered by FUDForum. Page generated in 0.04635 seconds
