Home » Modeling » Epsilon » EObject type in Epsilon
EObject type in Epsilon [message #1723595] Tue, 16 February 2016 12:21 Go to next message
I want to know how I could set the eType of an EReference to EObject by EOL instruction.
I try something like this:
ref.eType = Ecore!EObject;
However, it is incorrect.
I also want to check that whether an object is type of EObject or not but the below code is not correct:
...object.isTypeOf(EObject)...
Bests,
Leila
Re: EObject type in Epsilon [message #1723636 is a reply to message #1723595] Tue, 16 February 2016 17:39 Go to previous messageGo to next message
Hi Leila,
The following should do the trick.
ref.eType = EClass.all.selectOne(c|c.name="EObject");
object.isKindOf(EObject); // EObject is an abstract class
Dimitris
Re: EObject type in Epsilon [message #1723640 is a reply to message #1723636] Tue, 16 February 2016 20:29 Go to previous messageGo to next message
Hi Dimitris,
Because I use two metamodels, I try something like this:
ref.eType = Ecore!EClass.all.selectOne(c|c.name="EObject");
There is not any error, but the eType of ref will be empty. It is shown that there is no any EClass with name "EObject"!
My metamodels are similar to your paper:
Engineering a DSL for Software Traceability
http://link.springer.com/chapter/10.1007%2F978-3-642-00434-6_10
Bests,
Leila
Re: EObject type in Epsilon [message #1723713 is a reply to message #1723640] Wed, 17 February 2016 05:45 Go to previous messageGo to next message
Hi Leila,
Could you please provide a minimal example [1] that we can use to reproduce this?
Dimitris
[1] https://www.eclipse.org/epsilon/doc/articles/minimal-examples/
Re: EObject type in Epsilon [message #1723719 is a reply to message #1723713] Wed, 17 February 2016 06:10 Go to previous messageGo to next message
Hi Dimitris,
The minimal Example can be found in the attached file:
an ETL transformation from GeneralTrace to Ecore.
The output of the transformation should be generated in SpecialTraceMetamodel.ecore
My question is about line 111 in the ETL program.
Bests,
Leila
Re: EObject type in Epsilon [message #1723723 is a reply to message #1723719] Wed, 17 February 2016 06:17 Go to previous messageGo to next message
Hi Leila,
I see. I think that you need to add Ecore.ecore to your transformation as a third model (e.g. EcoreEcore). To do this you can select the "Registered EMF EPackage" model type in the "Select type of model" configuration dialog, set the name of the model to EcoreEcore and type/select the following metamodel URI: http://www.eclipse.org/emf/2002/Ecore. Line 111 of your code should then be modified as follows:
ref.eType := EcoreEcore!EClass.all.selectOne(c|c.name = "EObject");
Dimitris
Re: EObject type in Epsilon [message #1723729 is a reply to message #1723723] Wed, 17 February 2016 06:57 Go to previous messageGo to next message
Hi Dimitris,
Thank you very much.
Your suggested trick solved the problem.
Bests,
Leila.
Re: EObject type in Epsilon [message #1739941 is a reply to message #1723729] Fri, 05 August 2016 14:44 Go to previous messageGo to next message
How can I pass a registered EMF EPackage (Ecore) to ETL module as a model programmatically?
Bests,
Leila.
Re: EObject type in Epsilon [message #1739944 is a reply to message #1739941] Fri, 05 August 2016 14:58 Go to previous messageGo to next message
Hi Leila,
You need to create an instance of org.eclipse.epsilon.emc.emf.EmfMetaModel, configure it and then add it to module.getContext().getModelRepository() as usual.
Dimitris
Re: EObject type in Epsilon [message #1739967 is a reply to message #1739944] Sat, 06 August 2016 02:34 Go to previous messageGo to next message
Thanks Dimitris.
I write the below code to create an EMFMetaModel:
protected EmfMetaModel createEmfMetaModel(String name, String metamodelUri,
			boolean readOnLoad, boolean storeOnDisposal)
			throws EolModelLoadingException, URISyntaxException {
	EmfMetaModel emfMetaModel = new EmfMetaModel(name,metamodelUri);
	emfMetaModel.setReadOnLoad(readOnLoad);
	emfMetaModel.setStoredOnDisposal(storeOnDisposal);
	return emfMetaModel;
However, I don't know how I can access the ecore metamodel uri.
Bests,
Leila
Re: EObject type in Epsilon [message #1739995 is a reply to message #1739967] Sun, 07 August 2016 06:12 Go to previous messageGo to next message
Hi Leila,
You can access it through EcorePackage.eINSTANCE.getNsURI().
Dimitris
Re: EObject type in Epsilon [message #1739996 is a reply to message #1739995] Sun, 07 August 2016 07:03 Go to previous messageGo to next message
Thanks Dimitris.
I have called the createEmfMetaModel in this way:
models.add(createEmfMetaModel("EcoreM",EcorePackage.eINSTANCE.getNsURI(),true,false));
and it causes errors:
Internal error: java.lang.NullPointerException
	at org.eclipse.epsilon.emc.emf.AbstractEmfModel.getPackageRegistry[AbstractEmfModel.java:117]
	at org.eclipse.epsilon.emc.emf.AbstractEmfModel.classForName[AbstractEmfModel.java:197]
	at org.eclipse.epsilon.emc.emf.AbstractEmfModel.hasType[AbstractEmfModel.java:557]
	at org.eclipse.epsilon.eol.types.EolModelElementType.<init>[EolModelElementType.java:69]
	at org.eclipse.epsilon.eol.dom.NameExpression.getModelElementType[NameExpression.java:117]
	at org.eclipse.epsilon.eol.dom.NameExpression.execute[NameExpression.java:48]
	at org.eclipse.epsilon.eol.dom.NameExpression.execute[NameExpression.java:90]
	at org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST[ExecutorFactory.java:109]
	at org.eclipse.epsilon.eol.dom.PropertyCallExpression.execute[PropertyCallExpression.java:39]
	at org.eclipse.epsilon.eol.dom.PropertyCallExpression.execute[PropertyCallExpression.java:72]
	at org.eclipse.epsilon.eol.dom.FirstOrderOperationCallExpression.execute[FirstOrderOperationCallExpression.java:74]
	at org.eclipse.epsilon.eol.dom.AssignmentStatement.execute[AssignmentStatement.java:59]
	at org.eclipse.epsilon.eol.dom.ExecutableBlock.executeBlockOrExpressionAst[ExecutableBlock.java:65]
	at org.eclipse.epsilon.eol.dom.ExecutableBlock.execute[ExecutableBlock.java:88]
	at org.eclipse.epsilon.eol.dom.ExecutableBlock.execute[ExecutableBlock.java:117]
	at org.eclipse.epsilon.eol.dom.ExecutableBlock.execute[ExecutableBlock.java:49]
	at org.eclipse.epsilon.etl.dom.TransformationRule.executeSuperRulesAndBody[TransformationRule.java:206]
	at org.eclipse.epsilon.etl.dom.TransformationRule.transform[TransformationRule.java:160]
	at org.eclipse.epsilon.etl.strategy.FastTransformationStrategy.executeTransformations[FastTransformationStrategy.java:165]
	at org.eclipse.epsilon.etl.strategy.FastTransformationStrategy.getEquivalents[FastTransformationStrategy.java:62]
	at org.eclipse.epsilon.etl.strategy.FastTransformationStrategy.getEquivalent[FastTransformationStrategy.java:79]
	at org.eclipse.epsilon.etl.execute.operations.EquivalentOperation.execute[EquivalentOperation.java:48]
	at org.eclipse.epsilon.eol.dom.OperationCallExpression.execute[OperationCallExpression.java:131]
	at org.eclipse.epsilon.etl.strategy.FastTransformationStrategy.getEquivalents[FastTransformationStrategy.java:100]
	at org.eclipse.epsilon.etl.strategy.FastTransformationStrategy.getEquivalent[FastTransformationStrategy.java:92]
	at org.eclipse.epsilon.etl.strategy.FastTransformationStrategy.getEquivalent[FastTransformationStrategy.java:1]
	at org.eclipse.epsilon.etl.execute.operations.EquivalentOperation.execute[EquivalentOperation.java:46]
	at org.eclipse.epsilon.eol.dom.OperationCallExpression.execute[OperationCallExpression.java:105]
	at org.eclipse.epsilon.eol.dom.StatementBlock.execute[StatementBlock.java:43]
	at org.eclipse.epsilon.eol.dom.ForStatement.execute[ForStatement.java:88]
	at org.eclipse.epsilon.etl.strategy.FastTransformationStrategy.transformModels[FastTransformationStrategy.java:157]
	at org.eclipse.epsilon.etl.EtlModule.execute[EtlModule.java:134]
Would you please guide me to solve the problem?
Bests,
Leila.
Re: EObject type in Epsilon [message #1739997 is a reply to message #1739996] Sun, 07 August 2016 07:04 Go to previous messageGo to next message
Hi Leila,
Could you please send me a minimal example [1] I can can use to reproduce this?
Dimitris
Re: EObject type in Epsilon [message #1739998 is a reply to message #1739997] Sun, 07 August 2016 09:15 Go to previous messageGo to next message
Hi Dimitris,
The minimal example contains SpecificTrace.java file. Please run it to see the errors.
I use Eclipse Mars with Epsilon 1.3.0.
Bests,
Leila.
  • Attachment: TestETL.zip
    (Size: 19.99KB, Downloaded 136 times)
Re: EObject type in Epsilon [message #1740108 is a reply to message #1739998] Tue, 09 August 2016 06:06 Go to previous messageGo to next message
Hi Leila,
The problem seems to be that you're not calling the load() method of your instance of EmfMetaModel. Adding a call to load() seems to be doing the trick.
	emfMetaModel.load();
Dimitris
[Updated on: Tue, 09 August 2016 06:06] by Moderator
Re: EObject type in Epsilon [message #1740109 is a reply to message #1740108] Tue, 09 August 2016 06:15 Go to previous message
Hi Dimitris,
Thank you very much. It works well.
Bests,
Leila
Previous Topic:Eunit JunitClasses missing in jars?
Next Topic:EVL GMF Integration
Current Time: Fri Jul 25 23:10:08 EDT 2025
Powered by FUDForum. Page generated in 0.07548 seconds
