Home » Modeling » TMF (Xtext) » Description Resource Path Location Type Bound mismatch: The generic method create(Class<T>) of
Description Resource Path Location Type Bound mismatch: The generic method create(Class<T>) of [message #1723434] Mon, 15 February 2016 11:18 Go to next message
i have a problem with my dsl i think that it's an error with ( *)* please any help
i have this error
Description Resource Path Location Type Bound mismatch: The generic method create(Class<T>) of type
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class<T> [message #1723440 is a reply to message #1723434] Mon, 15 February 2016 12:33 Go to previous messageGo to next message
Can you please give more context on how to reproduce this
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class<T> [message #1723527 is a reply to message #1723440] Tue, 16 February 2016 06:53 Go to previous messageGo to next message
I write my DSL when i call an expression in an other on my DSL i got this error
error(10): internal error: Can't get property javaCompressedTransition using method get/isJavaCompressedTransition from org.antlr.analysis.DFA instance : java.lang.OutOfMemoryError: Java heap space
java.lang.String.<init>(Unknown Source)
java.lang.StringBuffer.toString(Unknown Source)
org.antlr.analysis.DFA.encodeIntAsCharEscape(DFA.java:728)
org.antlr.analysis.DFA.getRunLengthEncoding(DFA.java:447)
org.antlr.analysis.DFA.getJavaCompressedTransition(DFA.java:399)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
java.lang.reflect.Method.invoke(Unknown Source)
org.antlr.stringtemplate.language.ASTExpr.invokeMethod(ASTExpr.java:563)
org.antlr.stringtemplate.language.ASTExpr.rawGetObjectProperty(ASTExpr.java:513)
org.antlr.stringtemplate.language.ASTExpr.getObjectProperty(ASTExpr.java:420)
org.antlr.stringtemplate.language.ActionEvaluator.attribute(ActionEvaluator.java:346)
org.antlr.stringtemplate.language.ActionEvaluator.expr(ActionEvaluator.java:131)
org.antlr.stringtemplate.language.ActionEvaluator.templateApplication(ActionEvaluator.java:211)
org.antlr.stringtemplate.language.ActionEvaluator.expr(ActionEvaluator.java:121)
org.antlr.stringtemplate.language.ActionEvaluator.action(ActionEvaluator.java:79)
org.antlr.stringtemplate.language.ASTExpr.write(ASTExpr.java:152)
org.antlr.stringtemplate.StringTemplate.write(StringTemplate.java:714)
org.antlr.stringtemplate.language.ASTExpr.write(ASTExpr.java:722)
org.antlr.stringtemplate.language.ASTExpr.writeAttribute(ASTExpr.java:659)
org.antlr.stringtemplate.language.ActionEvaluator.action(ActionEvaluator.java:81)
org.antlr.codegen.CodeGenerator.write(CodeGenerator.java:1132)
org.antlr.codegen.Target.genRecognizerFile(Target.java:94)
org.antlr.codegen.CodeGenerator.genRecognizer(CodeGenerator.java:439)
91214 [main] INFO .emf.mwe2.runtime.workflow.Workflow - Done.
i don't no what is the problem but i think that is with antlr
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class<T> [message #1723528 is a reply to message #1723527] Tue, 16 February 2016 06:56 Go to previous messageGo to next message
please any help
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class<T> [message #1723529 is a reply to message #1723528] Tue, 16 February 2016 07:02 Go to previous messageGo to next message
this error looks like your heap is to low.
did you try to increase xmx
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class<T> [message #1723537 is a reply to message #1723529] Tue, 16 February 2016 08:35 Go to previous messageGo to next message
I'm a beginner so I don't no how to solve the problem Mr. Christian Dietrich who oncrese the xmx
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class<T> [message #1723545 is a reply to message #1723537] Tue, 16 February 2016 09:07 Go to previous messageGo to next message
if you go to the launch config of the mwe2
you will find a -Xmx512m in Arguments/vm arguments.
increase that e.g. to -Xmx1G
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class<T> [message #1723573 is a reply to message #1723545] Tue, 16 February 2016 11:13 Go to previous messageGo to next message
in Arguments/vm I find no argument
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&lt;T [message #1723574 is a reply to message #1723573] Tue, 16 February 2016 11:17 Go to previous messageGo to next message
Did you go to
Run
Runconfigurations...
Select the mwe2 in the tree
Arguments tab
Can you post a screenshot of this
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&lt;T [message #1723576 is a reply to message #1723574] Tue, 16 February 2016 11:32 Go to previous messageGo to next message
i can't insert a screenshot because when I click insert image he asks image URL http://
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&lt;T [message #1723578 is a reply to message #1723576] Tue, 16 February 2016 11:34 Go to previous messageGo to next message
No Message Body
  • Attachment: mwe2.png
    (Size: 91.56KB, Downloaded 189 times)
[Updated on: Tue, 16 February 2016 11:42] by Moderator
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&lt;T [message #1723580 is a reply to message #1723578] Tue, 16 February 2016 11:42 Go to previous messageGo to next message
find screenshots attached
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&lt;T [message #1723583 is a reply to message #1723580] Tue, 16 February 2016 11:47 Go to previous messageGo to next message
yes i do that in the previous message i send the image i found the Arguments/vm but it's empty
    (Size: 91.56KB, Downloaded 171 times)
[Updated on: Tue, 16 February 2016 11:52] by Moderator
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&lt;T [message #1723585 is a reply to message #1723583] Tue, 16 February 2016 11:51 Go to previous messageGo to next message
yes but you can type -Xmx512M or -Xmx1G
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&lt;T [message #1723587 is a reply to message #1723585] Tue, 16 February 2016 11:54 Go to previous messageGo to next message
what is the best -Xmx512M or -Xmx1G ?
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&lt;T [message #1723589 is a reply to message #1723587] Tue, 16 February 2016 11:55 Go to previous messageGo to next message
try -Xmx512M first
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&lt;T [message #1723590 is a reply to message #1723589] Tue, 16 February 2016 11:56 Go to previous messageGo to next message
512M = 512 megabyte
1G = 1 Gigabye
(RAM)
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&lt;T [message #1723621 is a reply to message #1723590] Tue, 16 February 2016 15:30 Go to previous messageGo to next message
thanks a lot Mr. Christian Dietrich
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&lt;T [message #1723872 is a reply to message #1723621] Thu, 18 February 2016 11:14 Go to previous messageGo to next message
in the first -Xmx512M works well but when i changed my grammer i get this error
warning(200): ../org.xtext.example.armani/src-gen/org/xtext/example/mydsl3/parser/antlr/internal/InternalMyDsl.g:1820:1: Decision can match input such as "';'" using multiple alternatives: 1, 2, 3
As a result, alternative(s) 3,2 were disabled for that input
warning(201): ../org.xtext.example.armani/src-gen/org/xtext/example/mydsl3/parser/antlr/internal/InternalMyDsl.g:1820:1: The following alternatives are unreachable: 2
warning(208): ../org.xtext.example.armani/src-gen/org/xtext/example/mydsl3/parser/antlr/internal/InternalMyDsl.g:7692:1: The following token definitions are unreachable: RULE_FLOAT,RULE_BOOLEAN,RULE_LONG,RULE_INT
41077 [main] INFO or.validation.JavaValidatorFragment - executing generate for org.eclipse.xtext.generator.validation.JavaValidatorFragment
warning(200): ../org.xtext.example.armani.ui/src-gen/org/xtext/example/mydsl3/ui/contentassist/antlr/internal/InternalMyDsl.g:7071:51: Decision can match input such as "';'" using multiple alternatives: 1, 2
As a result, alternative(s) 2 were disabled for that input
warning(208): ../org.xtext.example.armani.ui/src-gen/org/xtext/example/mydsl3/ui/contentassist/antlr/internal/InternalMyDsl.g:21149:1: The following token definitions are unreachable: RULE_FLOAT,RULE_BOOLEAN,RULE_LONG,RULE_INT
49262 [main] INFO .emf.mwe2.runtime.workflow.Workflow - Done.
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1723875 is a reply to message #1723872] Thu, 18 February 2016 11:23 Go to previous messageGo to next message
This means you grammar is ambiguous. So you have to fix that
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1723991 is a reply to message #1723875] Fri, 19 February 2016 09:56 Go to previous messageGo to next message
the problem is in the past it work fine but now no i don't indrestand it can be an error technique??
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724041 is a reply to message #1723991] Sat, 20 February 2016 01:50 Go to previous messageGo to next message
hi can you share a minimal grammar that reproduces your problem?
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724078 is a reply to message #1724041] Sat, 20 February 2016 14:48 Go to previous messageGo to next message
what is more good determinate the error or used ANTLRWORKS for derterminate the error??
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724079 is a reply to message #1724078] Sat, 20 February 2016 14:54 Go to previous messageGo to next message
it always help to strip down the grammar to a mininmal set that reproduces the error
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724081 is a reply to message #1724079] Sat, 20 February 2016 15:12 Go to previous messageGo to next message
i don't know how i detecte the error please have you a Link how to install the antlrworks ?
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724082 is a reply to message #1724081] Sat, 20 February 2016 15:18 Go to previous messageGo to next message
i dont know any tutorial.
http://www.antlr3.org/works/
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724084 is a reply to message #1724082] Sat, 20 February 2016 16:48 Go to previous messageGo to next message
i install antlrworks and i have this error
[Updated on: Sat, 20 February 2016 16:50] by Moderator
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724085 is a reply to message #1724084] Sat, 20 February 2016 16:53 Go to previous messageGo to next message
Sry i cannot help you with the usage or error marker in antlrworks. But i recommend to generate and use the debug grammar in antlrworks since it is a pure grammar
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724086 is a reply to message #1724085] Sat, 20 February 2016 16:54 Go to previous messageGo to next message
Btw which xtext Version do you use
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724087 is a reply to message #1724086] Sat, 20 February 2016 16:59 Go to previous messageGo to next message
PS and make sure you use antlrworks 3 . i dont remember this was a eclipse Plugin. I remember a standalone swing APP delivered AS jar
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724088 is a reply to message #1724086] Sat, 20 February 2016 17:00 Go to previous messageGo to next message
Eclipse SDK
Version: 3.6.2
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724089 is a reply to message #1724088] Sat, 20 February 2016 17:02 Go to previous messageGo to next message
I mean the Version Of xtext
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724090 is a reply to message #1724089] Sat, 20 February 2016 17:07 Go to previous messageGo to next message
Xtext Runtime 1.0.2.v201102150722
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724091 is a reply to message #1724090] Sat, 20 February 2016 17:09 Go to previous messageGo to next message
Hi i dont know if
fragment = parser.antlr.debugantlrgeneratorfragment {}
Already works in that Version to generate the debug grammar.
Is there a reason you use sich an old version
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724092 is a reply to message #1724091] Sat, 20 February 2016 17:13 Go to previous messageGo to next message
ok i going to try reduce the version else i going to search the solution without antlrworks thanks
[Updated on: Sat, 20 February 2016 17:16] by Moderator
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724093 is a reply to message #1724092] Sat, 20 February 2016 17:16 Go to previous messageGo to next message
And AS said before. If you can post a grammar that reproduces the Probleme someone can have a look
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724094 is a reply to message #1724093] Sat, 20 February 2016 17:24 Go to previous messageGo to next message
it's a big grammar
PropertyDeclaration:
'Property' parse_PropertyDescription=Parse_PropertyDescription ';'
Parse_PropertyDescription:
('Property')? P=ID
':' propertyTypeDescription+=PropertyTypeDescription
( '=' propertyValueDeclaration=PropertyValueDeclaration )?
( parse_PropertyDescription+=Parse_PropertyDescription
(';' parse_PropertyDescription+=Parse_PropertyDescription | ';' )*
PropertyTypeDescription:
'Int' | 'Long' | 'Float' | 'Double' | 'String'
| 'true' | 'false' | nomm=ID
ParseRecordFieldDescription:
nomParseRecordField=ID (',' nnomParseRecordField+=ID )*
( ':' prop=PropertyTypeDescription )?
PropertyValueDeclaration:
INT | FLOAT | STRING
| acmeSetValue=AcmeSetValue | acmeSequenceValue=AcmeSequenceValue |
acmeRecordValue=AcmeRecordValue | nn=ID
[Updated on: Mon, 22 February 2016 06:47] by Moderator
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724095 is a reply to message #1724094] Sat, 20 February 2016 17:30 Go to previous messageGo to next message
No Message Body
[Updated on: Mon, 22 February 2016 06:44] by Moderator
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724096 is a reply to message #1724095] Sat, 20 February 2016 17:57 Go to previous messageGo to next message
there are some things you should not do:
- use whitespace in keywords 'a b' => 'a' 'b'
- combine multiple keywords together '};' => '}' ';'
have a look at this grammar:
PropertiesBlock:
'Properties {'
( ';' parse_PropertyDescription+=Parse_PropertyDescription | ';' )*
('Property')? P=ID
INT | STRING
and this debugantlrgrammar
 * generated by Xtext 2.9.1
grammar DebugInternalMyDsl;
// Rule PropertiesBlock
rulePropertiesBlock:
	'Properties {'
		ruleParse_PropertyDescription
// Rule Parse_PropertyDescription
ruleParse_PropertyDescription:
	'Property'?
	RULE_ID
	rulePropertyTypeDescription
		rulePropertyValueDeclaration
// Rule PropertyValueDeclaration
rulePropertyValueDeclaration:
		RULE_INT
		RULE_STRING
// Rule PropertyTypeDescription
rulePropertyTypeDescription:
		'Int'
		'Long'
		'Float'
		'Double'
		'String'
		'true'
		'false'
		RULE_ID
RULE_ID : '^'? ('a'..'z'|'A'..'Z'|'_') ('a'..'z'|'A'..'Z'|'_'|'0'..'9')*;
RULE_INT : ('0'..'9')+;
RULE_STRING : ('"' ('\\' .|~(('\\'|'"')))* '"'|'\'' ('\\' .|~(('\\'|'\'')))* '\'');
RULE_ML_COMMENT : '/*' ( options {greedy=false;} : . )*'*/' {skip();};
RULE_SL_COMMENT : '//' ~(('\n'|'\r'))* ('\r'? '\n')? {skip();};
RULE_WS : (' '|'\t'|'\r'|'\n')+ {skip();};
RULE_ANY_OTHER : .;
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724097 is a reply to message #1724096] Sat, 20 February 2016 17:59 Go to previous messageGo to next message
all the optional ';' in PropertiesBlock and Parse_PropertyDescription
where do they belong to?
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724098 is a reply to message #1724096] Sat, 20 February 2016 18:00 Go to previous messageGo to next message
why in the second grammar i don't have a problem and in the first i have??
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724099 is a reply to message #1724098] Sat, 20 February 2016 18:02 Go to previous messageGo to next message
i post the second when i don't have problem and i use a false syntax 'aa' not 'aa 'a'
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724100 is a reply to message #1724099] Sat, 20 February 2016 18:09 Go to previous messageGo to next message
he belongs to no party
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724101 is a reply to message #1724099] Sat, 20 February 2016 18:11 Go to previous messageGo to next message
the keyword thing is just a general hint.
the important difference is
in the Parse_PropertyDescription,
it is a clear terminating signal
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724102 is a reply to message #1724101] Sat, 20 February 2016 18:12 Go to previous messageGo to next message
p.s. that is all i can do for you. for the rest you you to digg yourself
(e.g. by using the debug grammar in antlrworks)
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724103 is a reply to message #1724102] Sat, 20 February 2016 18:17 Go to previous messageGo to next message
ok thanks a lot
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724107 is a reply to message #1724103] Sat, 20 February 2016 18:56 Go to previous messageGo to next message
just a last question it's normal thing that same time given an errror when i ran the grammar and other times time no it's innomal thing !!!
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724115 is a reply to message #1724107] Sun, 21 February 2016 03:59 Go to previous messageGo to next message
hi it depends on the situation. under some circumstances antlr decides to go the first path and mark the other paths as warning
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724233 is a reply to message #1724115] Mon, 22 February 2016 07:18 Go to previous messageGo to next message
what is the type of this error?
2209 [main] ERROR erator.parser.antlr.AntlrToolFacade - de.itemis.xtext.antlr.toolrunner.AntlrToolRunner
java.lang.ClassNotFoundException: de.itemis.xtext.antlr.toolrunner.AntlrToolRunner
at java.net.URLClassLoader.findClass(Unknown Source)
at org.eclipse.xtext.xtext.generator.parser.antlr.AntlrToolFacade.getToolClass(AntlrToolFacade.java:76)
at org.eclipse.xtext.xtext.generator.parser.antlr.AntlrToolFacade.isWorkable(AntlrToolFacade.java:164)
at org.eclipse.xtext.xtext.generator.parser.antlr.AbstractAntlrGeneratorFragment2.checkConfiguration(AbstractAntlrGeneratorFragment2.java:107)
at org.eclipse.xtext.xtext.generator.parser.antlr.XtextAntlrGeneratorFragment2.checkConfiguration(XtextAntlrGeneratorFragment2.java:1345)
at org.eclipse.xtext.xtext.generator.CompositeGeneratorFragment2.checkConfiguration(CompositeGeneratorFragment2.java:39)
at org.eclipse.xtext.xtext.generator.XtextGenerator.checkConfigurationInternal(XtextGenerator.java:126)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent2.checkConfiguration(AbstractWorkflowComponent2.java:21)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.preInvoke(Mwe2Bridge.java:65)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.preInvoke(AbstractWorkflowComponent.java:197)
at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.preInvoke(AbstractCompositeWorkflowComponent.java:29)
at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:18)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:102)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:78)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:36)
2232 [main] ERROR erator.parser.antlr.AntlrToolFacade - de.itemis.xtext.antlr.toolrunner.AntlrToolRunner
2235 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Problems running workflow org.xtext.example.mydsl.GenerateMyDsl:
[ERROR]:
*ATTENTION*
It is highly recommended to use ANTLR's parser generator (get it from 'http://xtext.itemis.com/').
As an alternative to ANTLR you could also use the alternative implementation shipped with Xtext.
To do so use the generator fragment 'org.eclipse.xtext.generator.parser.packrat.PackratParserFragment' in your mwe2 file instead.(Element: -UNKNOWN-; Reported by: XtextGenerator)
[ERROR]:
*ATTENTION*
java.lang.RuntimeException: Problems running workflow org.xtext.example.mydsl.GenerateMyDsl:
[ERROR]:
*ATTENTION*
[ERROR]:
*ATTENTION*
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:104)
Caused by: java.lang.RuntimeException:
[ERROR]:
*ATTENTION*
[ERROR]:
*ATTENTION*
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.handleIssues(Mwe2Bridge.java:56)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.preInvoke(Mwe2Bridge.java:66)
... 4 more
Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class&amp; [message #1724237 is a reply to message #1724233] Mon, 22 February 2016 07:52 Go to previous message
this means antlr sdk/generator cannot be downloaded. it should ask for it and you can answer with y on console do download.
alternatively you can install it from p2 update site http://download.itemis.com/updates/releases/2.1.1/
(which xtext version do you use)
Previous Topic:xtext 2.8 dependencies list
Next Topic:Understanding Rule Priority
Current Time: Fri Jul 25 23:37:57 EDT 2025
Powered by FUDForum. Page generated in 0.43520 seconds
