Re: Description Resource Path Location Type Bound mismatch: The generic method create(Class<T [message #1723872 is a reply to message #1723621] |
Thu, 18 February 2016 11:14   |
in the first -Xmx512M works well but when i changed my grammer i get this error
warning(200): ../org.xtext.example.armani/src-gen/org/xtext/example/mydsl3/parser/antlr/internal/InternalMyDsl.g:1820:1: Decision can match input such as "';'" using multiple alternatives: 1, 2, 3
As a result, alternative(s) 3,2 were disabled for that input
warning(201): ../org.xtext.example.armani/src-gen/org/xtext/example/mydsl3/parser/antlr/internal/InternalMyDsl.g:1820:1: The following alternatives are unreachable: 2
warning(208): ../org.xtext.example.armani/src-gen/org/xtext/example/mydsl3/parser/antlr/internal/InternalMyDsl.g:7692:1: The following token definitions are unreachable: RULE_FLOAT,RULE_BOOLEAN,RULE_LONG,RULE_INT
41077 [main] INFO or.validation.JavaValidatorFragment - executing generate for org.eclipse.xtext.generator.validation.JavaValidatorFragment
warning(200): ../org.xtext.example.armani.ui/src-gen/org/xtext/example/mydsl3/ui/contentassist/antlr/internal/InternalMyDsl.g:7071:51: Decision can match input such as "';'" using multiple alternatives: 1, 2
As a result, alternative(s) 2 were disabled for that input
warning(208): ../org.xtext.example.armani.ui/src-gen/org/xtext/example/mydsl3/ui/contentassist/antlr/internal/InternalMyDsl.g:21149:1: The following token definitions are unreachable: RULE_FLOAT,RULE_BOOLEAN,RULE_LONG,RULE_INT
49262 [main] INFO .emf.mwe2.runtime.workflow.Workflow - Done.
FUDForum. Page generated in 0.16330 seconds
