Home » Language IDEs » ServerTools (WTP) » Application running twice, once again
Application running twice, once again [message #172352] Sat, 24 June 2006 15:29 Go to next message
Originally posted by: pecanov.mt.net.mk
I've been absent from the forums for quite a while, since I switched to
MyEclipse.
The reason for this was an annoying problem of WTP. The web application
was starting twice, and the probable cause was the structure of it.
After some debating, it was concluded that a context.xml in META-INF was
causing the problems.
However, 6 months later the context.xml is gone, 1.5 WTP is here ... and
the problem is still present.
Is this a problem for someone else at the moment (there were quite a few
people experiencing this with WTP 1.0).
Has a bug been filed?
Should it be?
Thank you
Re: Application running twice, once again [message #172360 is a reply to message #172352] Sat, 24 June 2006 20:43 Go to previous messageGo to next message
I haven't experiencied this problem but please go ahead and open a bug
with the specifics of how to reproduce it from an empty workspace (or from
an existing workspace that you provide in the bug report). I'd always
prefer that bugs be opened due to misunderstandings or that have already
been fixed rather than not hearing about your problem at all.
Lawrence
Re: Application running twice, once again [message #172383 is a reply to message #172352] Sun, 25 June 2006 12:47 Go to previous messageGo to next message
Perhaps this one accounts for what you are seeing:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=125364
Larry
> MyEclipse.
> Should it be?
> Thank you
Re: Application running twice, once again [message #172391 is a reply to message #172383] Mon, 26 June 2006 02:33 Go to previous message
Seem like the correct symptoms, except the deployment to "webapps" in
Tomcat.
Thanks, it's most probably what I was looking for.
> Cheers,
> Larry
> > MyEclipse.
> > Should it be?
> > Thank you
Previous Topic:refactoring affecting JSP
Next Topic:web tools download
Current Time: Wed Jul 23 22:59:08 EDT 2025
Powered by FUDForum. Page generated in 0.25527 seconds
