Home » Eclipse Projects » Eclipse Platform » How to set file mode
How to set file mode [message #171980] Thu, 18 December 2003 11:38 Go to next message
Originally posted by: member.silenceapi.com
i'm newbie at the Eclipse-Platform so my question may be very simple for
you.
How could i disable the write protection of a file using a shortcut on
my keybord?
I try to find a answer at google but without any result.
I allready know to do this with rihgt click and disabling "Read only"
checkbox.
Thanks in advance.
Stefan
Re: How to set file mode [message #172137 is a reply to message #171980] Thu, 18 December 2003 17:18 Go to previous messageGo to next message
Originally posted by: brendan.walker.cim.com.au
I'd also like to know the answer to this, but one question further, is it
possible to change the read/write status of multiple files at once? At the
moment, I use Windows Explorer to do this, but it'd be nice to be able to do
it through the Eclipse file navigator.
Brendan
"Stefan Theusner" <member@silenceapi.com> wrote in message
news:brskuu$kfo$1@eclipse.org...
> you.
> my keybord?
> checkbox.
> Thanks in advance.
> Stefan
Re: How to set file mode [message #172341 is a reply to message #171980] Fri, 19 December 2003 06:42 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
Stefan Theusner wrote:
> for you.
> my keybord?
You cannot.
> checkbox.
If the file is open in a text or Java editor then another possibility is
to click into the editor's status field.
Dani
> Thanks in advance.
> Stefan
Re: How to set file mode [message #172348 is a reply to message #172137] Fri, 19 December 2003 06:42 Go to previous messageGo to next message
No.
Dani
> At the
>Brendan
>>Hi,
>>you.
>>my keybord?
>>checkbox.
>>Thanks in advance.
>>Stefan
Re: How to set file mode [message #172362 is a reply to message #172341] Fri, 19 December 2003 07:35 Go to previous messageGo to next message
On 19.12.2003 12:42, Daniel Megert wrote:
> You cannot.
Ok thank you.
Stefan
Re: How to set file mode [message #172419 is a reply to message #171980] Fri, 19 December 2003 08:33 Go to previous messageGo to next message
You can do it in resource properties dialog with mouse (I don't know can
you associate shortcut with this action).
And you certainly and easy can add this function programmatically.
> you.
> my keybord?
> checkbox.
> Thanks in advance.
> Stefan
Re: How to set file mode [message #172565 is a reply to message #172137] Fri, 19 December 2003 13:47 Go to previous message
> is it possible to change the read/write status of multiple files
Eclipse's UI won't do this on its own. However, I've seen a sample
plugin out there that contributes an action for changing the read/write
status of all selected files. I can't remember where I saw it, but
Google should turn it up.
Laura
Previous Topic:[HELP]: 2.1.2: search for an non existant update site: cleaning the configuration??
Next Topic:Do you get WebSphere integration with Eclipse integration?
Current Time: Wed Oct 08 07:59:32 EDT 2025
Powered by FUDForum. Page generated in 0.13080 seconds
