Home » Modeling » GMF (Graphical Modeling Framework) » [xpand] How to use xpand outside GMF?
[xpand] How to use xpand outside GMF? [message #171919] Fri, 08 February 2008 13:30 Go to next message
Hi all,
We want to generate code as part of our MDA project. JET2 is an option, but
the new kid on the block is xpand. This one is included in GMF, but can it
also be used for different models than gmfgen? Anyone experience with it? Or
is it still too early to use and can I better wait for a release of xpand
from the M2M project?
Kind regards,
Jaap
Re: [xpand] How to use xpand outside GMF? [message #172065 is a reply to message #171919] Mon, 11 February 2008 08:26 Go to previous messageGo to next message
Hello Jaap,
XPand is a part of eclipse m2t project: http://www.eclipse.org/modeling/m2t/,
so you can use it from there. In addition GMF contaiins sligtly modified
version of XPand and still you can use it - corresponding plugin are independent
from GMF.
Alex Shatalin
Re: [xpand] How to use xpand outside GMF? [message #172264 is a reply to message #171919] Tue, 12 February 2008 04:26 Go to previous messageGo to next message
--------------040807060201080608060902
Jaap Reitsma a
Re: [xpand] How to use xpand outside GMF? [message #172340 is a reply to message #172264] Tue, 12 February 2008 16:13 Go to previous message
well, personally I think xPand (open Architecture Ware) is more powerful
with e.g. aspects, parametric polymorphism. The only better feature I've
seen with acceleo is that you could trace which template generated that
specific code. But that feature is afaik just in the pro version.
-stefan
Stéphane Bouchet wrote:
> Jaap Reitsma a écrit :
>> Hi all,
>> option, but the new kid on the block is xpand. This one is included in
>> GMF, but can it also be used for different models than gmfgen? Anyone
>> experience with it? Or is it still too early to use and can I better
>> wait for a release of xpand from the M2M project?
>> Kind regards,
>> Jaap
> You could also try Acceleo, which is a very good code generator ;)
> You could use it without GMF, and you could use your own metamodels, or
> EMF, UML2 ...
> Have a look here : www.acceleo.org
> Cheers,
> Stéphane
Previous Topic:GMF Error Message
Next Topic:Which xPand Version is used in GMF?
Current Time: Fri Jul 18 19:35:56 EDT 2025
Powered by FUDForum. Page generated in 0.07484 seconds
